EPROM Programming
Discussion in 'Electronic Components' started by Davis, Sep 9, 2005.
  1. Davis
    Davis Guest
    Looking a resources where I can learn about modifying the code (Hex) on
    EPROMs. Any links to places I can learn to understand what I'm looking at.
    I've been a programmer for over 10 years, but never tackled anything in this
    area.
    I have some older equipment I'm repairing and the system code is on a
    MBM27256. I've loaded the EPROM into the reader software and can see the
    data.
    Also, is there such a software as a decompiler for BIN files that would
    return the
    data into Assembler or Zilog code for example?
    Davis, Sep 9, 2005
    #1
    1. Advertisements
  2. Davis
    Bill Janssen Guest
    Davis wrote:
    >Hi,
    >area.
    >data.
    >return the
    >Thanks
    Yes dis-assemblers are available. You have to know what processor you have
    so as to get the correct dis-assembler
    Be advised that the first run of a dis-assembler will probably have many
    errors.
    You then have to go through the code and find those errors. If data is
    mixed in
    with the instructions things can get complicated.
    Been there - done that.
    Good luck
    Bill K7NOM
    Bill Janssen, Sep 9, 2005
    #2
    1. Advertisements
  3. Davis
    Rich Webb Guest
    On Fri, 09 Sep 2005 00:10:51 GMT, Bill Janssen <> wrote:
    [snip...snip...]
    >mixed in
    Especially if they've deliberately obscured things by having pieces of
    the data run as legitimate machine language.
    I also seem to recall a (possibly apocryphal) story of a ROM for an
    early computer (an Apple?) that had instructions in interleaved reading
    frames. Ah, those were the days ...
    Rich Webb Norfolk, VA
    Rich Webb, Sep 9, 2005
    #3
  4. Am Fri, 09 Sep 2005 01:57:58 GMT schrieb Rich Webb:
    > [snip...snip...]
    >>mixed in
    On some machines address and data lines on the bus have been interchanged
    to do some kind of "scrambling". This can also be a problem for a
    disassembler.
    You have to know if the connectio of the lines is comletely 1:1
    Alexander
    Alexander Peter, Sep 9, 2005
    #4
  5. Davis
    Dave Platt Guest
    In article <>,
    I once disassembled the PROM for a Synertek KTM-3, a simple "terminal
    emulator built into a keyboard". Standard PC-size keyboard, a serial
    port connection on the back, and a monochrome-video output to go to a
    monochrome monitor display.
    It was implemented using a 6502 (if I recall correctly) architecture.
    One of the oddities of this micro was that its memory bus interface
    was driven during only one-half of each clock cycle. It's possible
    for two micros to share the same bus (and thus share RAM and PROM) if
    one of them has its clock line inverted.
    That's just what the KTM-3 did... it had two 6502s, one to run the
    terminal emulator code, and the other to act as the video encoder
    (reading the data out of RAM, doing table lookups to construct the
    scan lines, and shoving the resulting bits into a shift register which
    clocked them out to create the video signal). The second 6502 had
    some odd reordering and inversions done to its address and data lines,
    so that its code was broken up into a few blocks of "data" in the PROM
    image executed by the main (terminal emulator) 6502.
    It worked. It also made my brain hurt.
    Dave Platt <> AE6EO
    Hosting the Jade Warrior home page: http://www.radagast.org/jade-warrior
    I do _not_ wish to receive unsolicited commercial email, and I will
    boycott any company which has the gall to send me such ads!
    Dave Platt, Sep 9, 2005
    #5
  6. "Davis" <> schreef in bericht
    news:gh4Ue.7607$...
    > Hi,
    > at.
    > this
    > area.
    > data.
    > return the
    > Thanks
    Well... Such software is called a "Disassembler" or sometimes "Unassembler".
    I wrote several of them over time. Having over 10 years programming
    experience it should be the easy part for you. Although a little Googling
    will make you find free disassmeblers for all of the old beasts. But what
    about the hardware? Of course you need to know what processor you're dealing
    with but some overview of the "system" may be necessary as well. If your
    EPROM is straight forward connected with address- and databus it's easy but
    you need to know. The same counts for the I/O-addresses and the hardware
    they control. A hexdump will be handy to locate (ASCII)data in the code.
    Running a disassembler is no problem. But the result. You will have several
    hundreds or even thousends lines of assemblercode without comments, symbolic
    names or other support. 32k assemblercode is quite a lot. The largest one I
    ever fully disassembled was 4k of 8051 code and it took weeks to have it all
    pointed out. (Including partial reverse engineering of the circuit,
    especially the I/O). So I guess the hardware part will be the hard part for
    you. Nevertheless succes.
    petrus bitbyter
    petrus bitbyter, Sep 10, 2005
    #6
  7. Davis
    Davis Guest
    > But what about the hardware? Of course you need to know what processor
    you're dealing
    but
    several
    symbolic
    I
    all
    for
    > petrus bitbyter
    Thanks for all this advice. I was able to locate a specific Z80
    disassembler. I extracted the EPROM and disassembled it. I now have the
    listing. Here is the first 19 lines of 9110.
    Z80 DISASSEMBLER LISTING
    Line Addr Opcodes Label Instruction
    0001 0000 3E 78 L1063: LD A,78H
    0002 0002 D3 88 OUT (88H),A
    0003 0004 C3 CE 0E JP L0001
    0004 0007 00 NOP
    0005 0008 08 EX AF,AF'
    0006 0009 D9 L0591: EXX
    0007 000A ED 40 IN B,(C)
    0008 000C 7D L0594: LD A,L
    0009 000D D3 98 OUT (98H),A
    0010 000F 7C LD A,H
    0011 0010 D3 9C OUT (9CH),A
    0012 0012 23 INC HL
    0013 0013 1B DEC DE
    0014 0014 7A LD A,D
    0015 0015 B3 OR E
    0016 0016 D9 EXX
    0017 0017 28 02 JR Z,L0002
    0018 0019 08 EX AF,AF'
    0019 001A C9 RET
    It only has labels and code as you said. I do have a repair and theory
    manual for the hardware. It contains
    block diagrams and schematics. I guess that should help alot, but I have a
    lot of studying and learning to do.
    Davis, Sep 11, 2005
    #7
    > you're dealing
    > but
    > several
    > symbolic
    > I
    > all
    > for
    >> petrus bitbyter
    > Hi,
    > 0004 0007 00 NOP
    > 0010 000F 7C LD A,H
    > 0012 0012 23 INC HL
    > 0013 0013 1B DEC DE
    > 0014 0014 7A LD A,D
    > 0015 0015 B3 OR E
    > 0016 0016 D9 EXX
    > 0019 001A C9 RET
    > Thanks
    I missed the front end of this conversation, but it looks like you are
    trying to fix an old Z80 system. The best tool I know of for figuring
    these out WITHOUT a schematic or memory map (or disassembling the
    code!) is the Fluke series of Microprocessor testers. The original
    Fluke 9010A with a Z80 pod has alearn function that will do a pretty
    good job of identifying the ROM locations, RAM and I/O. You can then
    use the probe to check chip selects and find out more the memory
    layout. The later Fluke Series 90 Z80 Microprocessor Tester is a bit
    easier to use than the original 9010, but it is rarer and not well
    understood.
    I support a tech tools mail list that you can join if you wish to
    discuss using these Fluke (or other brands) of CPU test devices. We
    mostly chat about the 9010A...but burners (Data I/O for example) and
    other stuff fits in fine:
    http://seven.pairlist.net/mailman/listinfo/techtoolslist
    John :-#)#
    (Please post followups or tech enquires to the newsgroup) John's
    Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call
    (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, Video Games)
    www.flippers.com "Old pinballers never die, they
    just flip out."
    John Robertson, Sep 15, 2005
    #8
    1. Advertisements
Similar Threads
  1. Mr. Phil
    Z80 control board / EPROM Programming
    Mr. Phil, Nov 19, 2003, in forum: General Electronics
    813
    Ken Taylor
    Nov 19, 2003
  2. Andy Rabagliati
    Programming FM27C256Q EPROM
    Andy Rabagliati, Aug 18, 2003, in forum: Electronic Components
    601
    Andy Rabagliati
    Aug 18, 2003
  3. Mr. Phil
    Mr. Phil, Nov 19, 2003, in forum: Electronic Components
    11
    1,268
    Mr. Phil
    Nov 23, 2003
  4. Steve Lewinsky
    2532 EPROM to 2732 EPROM
    Steve Lewinsky, Jan 22, 2005, in forum: Beginner Electronics
    4,950
    Brian Gregory [UK]
    Jan 23, 2005
  5. Kubas
    Copying of eprom to eprom
    Kubas, May 16, 2011, in forum: Microcontrollers and Programming
    4
    2,344
Loading...
