Electronic ballast (?) problem
Discussion in 'Lighting' started by Mark F, Mar 27, 2008.
  1. Mark F
    Mark F Guest
    VEB82234 drives two circline bulbs, FC12T9 and FT16T9
    Very short bulb life, one fixture refuses to start at all,
    replaced bulbs in two, died almost immediately.
    Pulled a ballast apart, brown gunk leaked from somewhere,
    couple of electrolytic (68uF / 200v) caps seem to be a bit
    swollen....
    Is it worth fixing / troubleshooting, or simply take my
    100 dollar lumps (home depot canada pricing) and use
    something different...
    thanks / mark
    #1
    1. Advertisements
  2. Mark F
    Mark F Guest
    > swollen....
    > thanks / mark
    It gets worse - all the diodes are open (bridge input),
    so I'm betting on a power spike. Caps were just
    victims of this / mark
    #2
    1. Advertisements
  3. On Thu, 27 Mar 2008 19:11:06 GMT, Mark F <>
    >swollen....
    >thanks / mark
    It all depends how much your time is worth. You may be
    able to fix it, since the ballast still powers the lamp, and
    also turn it into a learning experience; but it may take
    many hours to find and repair all the problems. And,
    without a circuit diagram there is no assurance you will be
    successful.
    Vic Roberts
    http://www.RobertsResearchInc.com
    To reply via e-mail:
    replace xxx with vdr in the Reply to: address
    or use e-mail address listed at the Web site.
    This information is provided for educational purposes only.
    It may not be used in any publication or posted on any Web
    site without written permission.
    Victor Roberts, Mar 28, 2008
    #3
    1. Advertisements
Similar Threads
  1. Dario
    A electronic ballast circle?
    Dario, Apr 14, 2004, in forum: Electronic Basics
    484
    Dario
    Apr 14, 2004
  2. tuck279
    667
    R.Legg
    Jul 25, 2003
  3. Dario
    Electronic ballast circle building...HELP!!!!
    Dario, Apr 14, 2004, in forum: Electronic Design
    4
    621
    Dave Cole
    Apr 20, 2004
  4. mercer7
    10
    2,252
    Homer J Simpson
    Nov 27, 2006
  5. Electronic ballast/ electronic choke
    , Dec 22, 2006, in forum: Electronic Basics
    1,067
    Eeyore
    Dec 22, 2006
Loading...
