Do coffee makers etc. use electricity when off?
Discussion in 'Electronic Repair' started by Chris, Dec 20, 2005.
  1. Chris
    Chris Guest
    My girlfriend watched some show, I don't know which, & heard that
    thing like coffee makers & cordless kettles use electricity if they
    are plugged in, even if they're turned off.
    I know things like stereos need power for memory, or some coffee
    makers with timers need power for internal clocks, but do appliances
    like kettles & toasters still use electricity if they are off?
    Chris
    Chris, Dec 20, 2005
    #1
    1. Advertisements
  2. James Sweet
    James Sweet Guest
    > Chris
    Not unless they have a clock or timer or some electronic control. If
    they have a standard rocker or toggle switch then turning the switch off
    turns it completely off.
    James Sweet, Dec 20, 2005
    #2
    1. Advertisements
  3. Ralph Mowery
    Ralph Mowery Guest
    "Chris" <> wrote in message
    news:...
    Not unless they have somekind of timmer or clock in them. Then they will
    use a very small ammount to keep the clock going.
    Ralph Mowery, Dec 20, 2005
    #3
  4. Arfa Daily
    Arfa Daily Guest
    "Ralph Mowery" <> wrote in message
    news:bb%pf.8405$...
    > news:...
    All electronic / electrical equipment will draw tiny amounts of current when
    plugged in, irrespective of whether they have timers or clocks or double
    pole isolating switches in them. This is due to leakage in suppression
    components connected across the supply, insulation leakage, and capacitive
    leakage, which any AC powered equipment will exhibit.
    Obviously, we're not talking anything that your household electricity
    consumption meter is going to " see ", but never-the-less, enough to be
    measurable with sensitive test equipment.
    Arfa
    Arfa Daily, Dec 21, 2005
    #4
  5. Ralph Mowery
    Ralph Mowery Guest
    "Arfa Daily" <> wrote in message
    news:SU2qf.2691$...
    > news:bb%pf.8405$...
    > > news:...
    will
    when
    > Arfa
    Sure they will. There is always some current being used. The resistance
    between the wires going from the wall socket to the device and across the
    switch insulation will use some current. Maybe a tenth to one microamp.
    Not really enough to call using electricity in a normal sense.
    Now for your next answer, tell us how many rat droppings are in a 5 lb bag
    of flour.
    They are there , that is why most of it is bleached.
    Ralph Mowery, Dec 21, 2005
    #5
  6. In article <>,
    says...
    It depends on how it's turned on and off. I assume many newer ones use
    a relay and timer to shut it off after a certain amoutn of time so it
    doesn't start a fire. It depends on if the power switch directly
    switches the power or just tells some electronics to turn a relay on and
    off. You may need to take it apart to tell!
    If there is a no_junk in my address, please REMOVE it before replying!
    All junk mail senders will be prosecuted to the fullest extent of the
    law!!
    http://home.att.net/~andyross
    Andrew Rossmann, Dec 21, 2005
    #6
    1. Advertisements
Similar Threads
  1. Peter O. Brackett
    Circulators, Scatterometers, etc, etc...
    Peter O. Brackett, Nov 13, 2003, in forum: Electronic Design
    424
    Jens Tingleff
    Nov 14, 2003
  2. mc
    21
    927
  3. Troye Kauffman
    Replacement lights for West Bend Coffee makers
    Troye Kauffman, Oct 29, 2003, in forum: Beginner Electronics
    337
    Troye Kauffman
    Oct 29, 2003
  4. pityocamptes
    Will a 555 timer switch on and off, on and off, etc?
    pityocamptes, Sep 25, 2012, in forum: Electronic Projects
    20
    1,255
    CocaCola
    Sep 27, 2012
  5. efiste2
    Pc program calculates voltages,currents etc etc in a circuit
    efiste2, Sep 25, 2013, in forum: Electronics Homework Help
    4
    578
    Rob_K
    Oct 2, 2013
Loading...
Share This Page
