Difference btw PWB and PCB
Discussion in 'Misc Electronics' started by Alex C, Aug 11, 2003.
  1. Alex C
    Alex C Guest
    Can anyone kind to tell me what's the difference btw PWB (printed Wiring
    Board) and PCB (printed Circuit board)?
    I can't find it in the net.... I heard some refer to PCB others said about
    PWB, but any difference(s)
    #1
    1. Advertisements
  2. "Alex C" <> wrote in message news:<bh8ahf$r3v$>...
    > Hi,
    > Thanks
    They're the same thing.
    Harry C.
    Harry Conover, Aug 11, 2003
    #2
    1. Advertisements
  3. Alex C
    Blake Guest
    Alex C wrote:
    > Hi,
    As far as I can tell, if you've worked at TI you call it a PWB. Everyone
    else calls it a PCB.
    Blake
    Drop 'pants' to reply by email
    Blake, Aug 11, 2003
    #3
  4. Alex C
    JeffM Guest
    >what's the difference btw PWB (printed Wiring Board)
    >Alex C
    Depends on whom you ask.
    There is no industry-wide standard.
    I call a finished subassembly a PCB
    and a bare, unstuffed board a PWB.
    JeffM, Aug 11, 2003
    #4
  5. Alex C
    Fred Abse Guest
    Not quite. At one time, printed circuit boards quite commonly used
    screen-printed-on components in addition to wiring, whilst printed wiring
    boards were just that - wiring.
    I remember Philco radios with printed resistors.
    The practice has now fallen into disuse, apart from circuits fired onto a
    ceramic substrate, and etched coils, so the two terms have become
    synonymous.
    I wonder if anyone here remembers (or has heard of) the "Tinkertoy"
    ceramic printed circuit assemblies of the 1940s?
    Then there's duct tape ...
    (Garrison Keillor)
    Fred Abse, Aug 11, 2003
    #5
  6. Alex C
    Gary Tait Guest
    On Mon, 11 Aug 2003 21:40:42 +0100, Fred Abse
    I have some stereos from the 1980s (quite possibly made in the same
    plant), that have traces and resistors screened onto the component
    side of the board. I
    Gary Tait, Aug 11, 2003
    #6
  7. Alex C
    DarkMatter Guest
    On Mon, 11 Aug 2003 22:50:13 +0800, "Alex C"
    <> Gave us:
    >Hi,
    >Thanks
    They are one and the same. PWB is the old, archaic term, and PCB is
    the new current usage.
    DarkMatter, Aug 12, 2003
    #7
  8. Alex C
    DarkMatter Guest
    On Mon, 11 Aug 2003 18:06:30 GMT, Blake <> Gave
    us:
    >Alex C wrote:
    >> Hi,
    There are several monikers. PWB PCB PWA CCA UUT, etc.
    Printed Wiring Board.
    Printed Circuit Board
    Printed Wiring Assembly
    Circuit Card Assembly
    Unit Under Test. (a stretch)
    #8
  9. Alex C
    DarkMatter Guest
    On 11 Aug 2003 13:13:02 -0700, (JeffM) Gave us:
    >>Alex C
    Sure there is. It is more about era than standards.
    When they were first introduced, they were referred to as Printed
    Wiring Assemblies, Or Printed Wiring Board(s). Once Printed Circuit
    Board came into vogue, the other is used primarily by old foggeys <sp>
    that are still entrenched in the past, or just to familiar with it to
    change, but these days, PCB is pretty much the accepted norm.
    #9
  10. Alex C
    Blake Guest
    Actually the "assembly" terms apply to the loaded boards, where the PCB/PWB
    apply only to the bare board.
    Blake
    Blake, Aug 12, 2003
    #10
  11. Alex C
    DarkMatter Guest
    On Tue, 12 Aug 2003 04:04:30 GMT, Blake <> Gave
    us:
    Actually, contract manufacturers refer to assemblies as PCBs. Only
    those of us that actually do the developments of products make the
    distinctions you outline, and know the difference.
    All of the acronyms that have an "A" in them are obviously about
    loaded assemblies. Since they have military roots, it is unlikely
    that you will hear today's commercial contract houses using any of
    them. They jus' call 'em PCBs. Loaded or not. There has been a BIG
    relaxation in the industry. When I was learning it, ALL personnel on
    the lab floor had electronic training. Now we gotz idiot on the line
    that can't even read assembly drawing OR speak in the language of the
    country they are living and working in. Pretty sad, that.
    #11
  12. Alex C
    Fred Abse Guest
    > plant), that have traces and resistors screened onto the component side
    > of the board. I
    That's pretty late. I was thinking back to the '50's and '60s.
    Do that a lot these days. Sad isn't it?
    (Garrison Keillor)
    Fred Abse, Aug 12, 2003
    #12
  13. Alex C
    DarkMatter Guest
    On Tue, 12 Aug 2003 22:30:12 +0100, Fred Abse
    <> Gave us:
    Hell, back then, most of them were point to point wired!
    Hahahahahah...
    DarkMatter, Aug 13, 2003
    #13
  14. Alex C
    DarkMatter Guest
    On 13 Aug 2003 07:27:13 GMT, (AtPCLogic) Gave us:
    >Read the latest magazines from IEEE, this is coming back because of a need to
    >reduce board size.
    Have you ever even seen an 0402 resistor? What about 0201? They
    are both in use... Today. ANY film screen process could not possibly
    control the value with repeatable enough results for it to be
    economical to do at those sizes, on the fly. Thousands of resistors
    get trimmed at one time on a chip manufacturing line, once the average
    slicing point is determined, then they get culled again after glazing
    for the one percent units Probing and laser trimming on a custom PCB
    AIN'T cheap. I doubt that you'll be beating the 0402 or 0201 form
    factors any time soon. Both for automated assembly reasons, AND
    precision.
    So... what exactly is "coming back"?
    #14
  15. Alex C
    DarkMatter Guest
    On Wed, 13 Aug 2003 10:56:43 +0200, Jean-Michel Friedt
    <> Gave us:
    >When I visited Georgia Tech 3 years ago they had a whole department
    >working on the development of methods for integrating passive components
    >in the layers of PCB for hi-density hi-frequency boards.
    Still a ways off as far as a low cost, high volume, quick turn
    manufacturing process, however.
    #15
  16. Alex C
    Blake Guest
    >>PCB/PWB apply only to the bare board.
    Pretty funny, I read my reply later and thought that the "actually" sounded
    pretty authoritative, and I was only guessing. Oh well. The hazards of
    being a know-it-all.
    Blake
    Blake, Aug 13, 2003
    #16
    1. Advertisements
Similar Threads
  1. OP
    difference btw H/W & S/W implementations
    OP, Feb 25, 2004, in forum: General Electronics
    3
    443
    Bill Sloman
    Feb 26, 2004
  2. DaveC
    DVD disc compatibility btw computer and DVD player
    DaveC, Mar 26, 2005, in forum: Electronic Equipment
    5
    568
    CWatters
    Mar 27, 2005
  3. DaveC
    5
    522
    CWatters
    Mar 27, 2005
  4. yeahright
    Roland MC505 - LCD PWB delaminated. Need Help
    yeahright, Aug 27, 2005, in forum: Electronic Repair
    1,198
    mistermaniac
    Aug 31, 2005
  5. DaveC
    5
    688
    CWatters
    Mar 27, 2005
Loading...
