Detecting when a calling party hangs up the telephone line
Discussion in 'Electronic Basics' started by Linden, Oct 20, 2004.
  1. Linden
    Linden Guest
    So ive got the ring detection circuit done fine.
    Problem now is when I 'answer' the phone (by detecting the ring signal
    and making a microcontroller switch a relay to connect to a line
    transformer) I cant get the solid state relay or even a mechanical relay
    to switch off and disconnect the circuit.
    I need to know how can I detect when the other party has hang up the
    phone so I can disconnect the line. Otherwise the line will stay
    connected indefinately and no one will be able to get through.
    Help appreciated, thanks !
    #1
    1. Advertisements
  2. Linden
    Dbowey Guest
    Linden posted:
    << So ive got the ring detection circuit done fine.
    There is no local change of state when the far-end hangs-up.
    Build a device to detect the voiceband signal amplitude, and use it to open the
    loop after there is no signal detected for several seconds. I would back that
    up with a timer to open the loop after about 3 minutes after the initial
    answer, no matter what.
    If you need some ideas, email me.
    Don
    Don
    Dbowey, Oct 20, 2004
    #2
    1. Advertisements
  3. Linden
    Dbowey Guest
    Jamie posted: last time i knew the polarity switches.
    In which country or system?
    Don
    #3
  4. Linden
    Chris Osborn Guest
    In article <4176153e$0$15798$>,
    All I've ever been able to do is wait for the dial tone to come back.
    See all the insanity of giant K'nex kinetic sculptures
    Pictures, movies, and more! http://buildfest.com/
    Coming soon: An arcade cabinet made of K'nex!
    Chris Osborn, Oct 20, 2004
    #4
  5. Linden
    Jamie Guest
    Dbowey wrote:
    > Linden posted:
    > Don
    > Don
    Jamie, Oct 20, 2004
    #5
  6. Linden
    Linden Guest
    I'm in Australia. I've heard some systems use polarity reversal im not
    sure about here and I dont really want to have to make something to
    detect dial tone frequencies.
    With all the telephone operated devices out there surely there is an
    easy method to detect hang-up.
    I may end up just forcing the other side to press a # to hang up.
    Otherwise time-out after not receiving a key press for a minute or two.
    - Linden.
    Linden, Oct 21, 2004
    #6
  7. Linden
    Dbowey Guest
    Linden posted:
    << > All I've ever been able to do is wait for the dial tone to come back.
    In the US there are no central offices that normally send polarity reversal on
    LINES. There are offices that send a reversal on TRUNKS, for PBX and some
    multi-function systems.
    It isn't likely, but you can easily test if you receive polarity reversal from
    the C.O. by puting a voltmeter across the line while the far end hangs-up. Let
    us know what you find.
    Don
    Dbowey, Oct 21, 2004
    #7
  8. Linden
    Bob Masta Guest
    On Wed, 20 Oct 2004 17:36:10 +1000, Linden <>
    wrote:
    >Hi,
    I think this may be non-trivial. I've got an answering machine
    that purported to not save anything in the event that the
    caller hung up without leaving a message. But it usually gets
    confused by ambient line noise and records that until the
    dial tone comes back. I think if you set the threshold too low
    you get this symptom; set it too high, and soft-voiced callers
    won't register.
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Bob Masta, Oct 21, 2004
    #8
  9. Linden
    Linden Guest
    >>Hi,
    > won't register.
    Hmm, no polarity reversal when the call is hung up. 47.5V on hook and
    down to 1.5V when on-hook and connected to the line transformer.
    Still stays at 1.5V when other caller hangs up. Need to disconnect line
    from the transformer to go back to 47.5V off hook condition.
    - Linden.
    #9
  10. Linden
    Dbowey Guest
    Linden posted:
    (snip)
    << Hmm, no polarity reversal when the call is hung up. 47.5V on hook and
    Which brings us back to needing a solution: Use a delay or use audio detection
    or a combination of both.
    Your voltage readings indicate a problem in your design. The DC resistance of
    your equipment is too low. The equipment puting the line off hook should place
    less than about 230 Ohms DC across the line.
    Don
    #10
  11. Linden
    Rich Grise Guest
    On Thu, 21 Oct 2004 16:44:18 +0000, Dbowey wrote:
    > Linden posted:
    > (snip)
    I'm sure you mean "less load" - 230 ohms is the _minimum_ resistance,
    _maximum_ load. I've heard that you should use a 600 ohm resistor for
    "hold", so I'd say that would be a minimum for the resistance value.
    But detecting when the far end hangs up, you'd have to ask the telco.
    Good Luck!
    Rich
    Rich Grise, Oct 21, 2004
    #11
  12. Linden
    Dbowey Guest
    Rich posted:
    << On Thu, 21 Oct 2004 16:44:18 +0000, Dbowey wrote:
    > Linden posted:
    > (snip)
    detection
    of
    place
    It's an age thing--- I meant to say "...should place no less...." Thanks.
    Also my memory failed me about the 230 Ohms; It is 330 Ohms - see below. I
    really hate to add to the confusion perfusion.
    I think the 600 Ohm idea comes from info passing through too many hands, and
    may be a result of the incorrect insight that telephone lines are all 600 Ohms
    (impedance). This is one of the faults of the internet; there is a great deal
    of information available, but so much of it is wrong or at least twisted.
    On a long enough loop from a C.O., 600 Ohms DC resistance *might not* place a
    loop in the off-hook condition. If a 330 Ohm closure is used to answer the
    call, and then 600 Ohms resistance is placed on the line before removing the
    330 Ohms, then the 600 Ohms will probably hold the loop in off-hook. Given a
    properly zoned phone line, a 330 Ohm resistance will always provide at least
    18.5 mA. of loop current at least 6.6 Volts across the resistance.
    By the way, 330 Ohms is the Standard resistance for a rotary dial phone and 430
    Ohms is the Standard resistance for a "touchtone" phone.
    Don
    Dbowey, Oct 22, 2004
    #12
  13. Linden
    Bill Bowden Guest
    (Dbowey) wrote in message news:<>...
    So, how does an answering machine know when to stop recording
    after the caller hangs up?
    -Bill
    Bill Bowden, Oct 22, 2004
    #13
  14. Linden
    Rich Grise Guest
    In all fairness, I heard it in 1988. ;-) And, of course, just took the
    guy's word for it, because he was older and wiser, and answered with such
    certainty that it _had_ to be right. :)
    Is that where that "Western Electric 430" comes from? :)
    Rich
    Rich Grise, Oct 22, 2004
    #14
  15. Linden
    Dbowey Guest
    Rich posted:
    (big snip)
    >and 430
    That could be...... 430pm was the WECo Day shift installation crew quitting
    time, and held dearly by so many that they might have memorialized it. It's
    the only 430 I can recall.
    Ok, what's a 430?
    Don
    #15
    1. Advertisements
Similar Threads
  1. news2020-Aug04
    3
    606
    news2020
    Aug 20, 2010
  2. news2020-Aug04
    743
    news2020
    Mar 27, 2010
  3. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    560
  4. Replies:
    570
  5. telephone calling cards
    , Jul 20, 2013, in forum: Electronic Repair
    5
    348
    Geoffrey S. Mendelson
    Jul 22, 2013
Loading...
