Delco DS-501 Transistor ?
Discussion in 'Electronic Components' started by pgtr, Nov 15, 2004.
  1. pgtr
    pgtr Guest
    Anybody heard of this transistor or know if there is an equivalent
    available?
    I have an old (early 1970s) GM car radio/stereo that uses an external
    'convector' (which I do not have) - it should be a large external
    heatsink w/ two(2) DS-501 transistors on it is all. I wonder if I can
    fabricate an equivalent unit out of modern items? I'm guessing all I
    need is a pair of large Delco DS-501 transistors (or modern equiv?)
    mounted to a large externally mounted heatsink and 6 wires (3 for each
    transistor) going to the radio unit.
    I have access to one such 'convector' I can inspect. The radio works
    fine w/ the 'borrowed' convector.
    pgtr, Nov 15, 2004
    #1
    1. Advertisements
  2. On Mon, 15 Nov 2004 02:00:35 -0600, pgtr
    <pgtr@(changesomething}bigfoot..com> wrote:
    I understand that the 2N235A is equivalent to the DS501, but probably
    not now easy to directly replace.
    2n235A is a TO3 case Germanium PNP power transistor.
    Ic max 3 amp,
    Ib max 150ma,
    BV(cbo) = 50 volt
    With Ic=500mA hfe=40
    >available?
    Peter Dettmann, Nov 16, 2004
    #2
    1. Advertisements
  3. "pgtr" <pgtr@(changesomething}bigfoot..com> wrote in message
    news:...
    > available?
    Are you sure you don't mean 'convertor'?
    The NTE (paper) crossref and catalog gives the sub for DS-501 as NTE105.
    Find out more at www.nteinc.com.
    Watson A.Name - \Watt Sun, the Dark Remover\, Nov 18, 2004
    #3
  4. "Peter Dettmann" <> wrote in message
    news:...
    > Ic max 3 amp,
    > Ib max 150ma,
    > BV(cbo) = 50 volt
    The Delco DS-501 is in the big TO-36 doorknob package, and can dissipate
    150 Watts, much greater than the 2N235A.
    > >available?
    each
    #4
  5. pgtr
    pgtr Guest
    On Wed, 17 Nov 2004 19:59:50 -0800, "Watson A.Name - \"Watt Sun, the
    Actually I don't know. The General Motors Manual (for the car, not the
    radio or stereo) calls it a "convector" for a mono radio and an
    "adapter" for a stereo radio.
    The difference between these two parts is size of the aluminum heat
    sink and one or two DS-501s. The stereo version is twice the size of
    alum sink and a pair of DS501s and the mono radio has only a single
    DS501 on it's smaller heat sink. (basically cut it in half) The
    harness connecting the two is 6 wires or 3 wires respectively.
    In radio or electronics parlance not sure what I'd call it. Heat Sink
    w/ 'driver' transisters for the amp I'd guess at describing it as.
    Here's some images front and back of a stereo version. There is a 6
    wire connector and the brown discs on the bottom are caps:
    http://www.photohost.org/gallery/data/501/5632converter1.JPG
    http://www.photohost.org/gallery/data/501/5632converter2.JPG
    Thanks! I've already bookmarked that site and finding all kinds of
    useful info in addition to this!
    pgtr, Nov 18, 2004
    #5
  6. pgtr
    Luddite Guest
    > available?
    I have two pairs of those and some delco 2n277's as well,make an offer
    Luddite, Nov 23, 2004
    #6
    1. Advertisements
Similar Threads
  1. Sidney
    Sears Canada vcr model:30089,chassis:501-41415
    Sidney, Sep 18, 2003, in forum: Electronic Repair
    643
    Sidney
    Sep 18, 2003
  2. Yde
    MDS-501 minidisk
    Yde, Jan 11, 2004, in forum: Electronic Repair
    696
  3. Hann Wagner
    ROBOT Melfa / Mitsubishi RM 501 Movemaster
    Hann Wagner, Feb 13, 2004, in forum: Electronic Repair
    1,437
    Hann Wagner
    Feb 13, 2004
  4. Perion
    Tracing into my Sony STR-501
    Perion, Oct 18, 2004, in forum: Electronic Repair
    3
    654
    Perion
    Oct 18, 2004
  5. crazzyotto
    delco DS 501
    crazzyotto, Jul 5, 2011, in forum: Datasheets, Schematics, Manuals and Parts
    6
    2,537
    crazzyotto
    Jul 6, 2011
Loading...
