dc power on-off with single pole momentary switch
Discussion in 'Electronic Design' started by John Bachman, Feb 13, 2008.
  1. John Bachman
    John Bachman Guest
    The subject tells the goal. Here is the rest of the story. There is
    no micro available. It is preferred to use a dual comparator such as
    393 as one of those is already part of the design and having two of
    one device is preferable to one of these and one of those.
    I have tried and failed. Others care to give it a crack?
    John
    #1
    1. Advertisements
  2. Jim Thompson
    Jim Thompson Guest
    On Wed, 13 Feb 2008 13:15:11 -0500, John Bachman
    >John
    Input Voltage?
    How much "stand-by" power can be drawn by the switching circuitry?
    Load Current?
    ...Jim Thompson
    | James E.Thompson, P.E. | mens |
    | Analog Innovations, Inc. | et |
    | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    | Phoenix, Arizona Voice:(480)460-2350 | |
    | E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
    | http://www.analog-innovations.com | 1962 |
    America: Land of the Free, Because of the Brave
    Jim Thompson, Feb 13, 2008
    #2
    1. Advertisements
  3. On a sunny day (Wed, 13 Feb 2008 13:15:11 -0500) it happened John Bachman
    <> wrote in
    >John
    Use a 74HC74 flipflop, it has reset for correct power up too.
    Screw the comparator.
    Jan Panteltje, Feb 13, 2008
    #3
  4. John Bachman
    John Bachman Guest
    On Wed, 13 Feb 2008 11:27:02 -0700, Jim Thompson
    >>John
    >Input Voltage?
    >Load Current?
    9 volt battery supply. Load is 12 ma. I figure a pass transistor
    operated by the switch and/or circuitry will be fine.
    Ideally the switching circuitry is on the load side of the pass
    transistor, hence no quiescent draw. That may not be possible. If it
    must draw quiescent current then I will have to assess the feasibility
    of it. Two switches is not the end of the world, just not as elegant.
    John
    #4
  5. John Bachman
    John Bachman Guest
    On Wed, 13 Feb 2008 18:42:44 GMT, Jan Panteltje
    ><> wrote in
    >>John
    Yeah, I know. Sigh.
    John
    #5
    > >>John
    > >Input Voltage?
    > >Load Current?
    Is there any reason why you can't use a straightforward single pole
    toggle switch? It is cheap, ergonomic to operate, draws no quiescent
    current when open, gives negligible volt-drop when closed - and is
    self-indicating.
    If they had only just been invented, they would be regarded as one of
    the biggest steps forward in technology of the past 30 years.
    ~ Adrian Tuddenham ~
    (Remove the ".invalid"s and add ".co.uk" to reply)
    www.poppyrecords.co.uk
    Adrian Tuddenham, Feb 13, 2008
    #6
  7. linnix
    linnix Guest
    > > >>no micro available.
    Why not? Bad design!
    > toggle switch?
    Yes, it can't turn itself off.
    > self-indicating.
    Except for wasting batteries. Auto off is the second biggest step
    forward ...
    linnix, Feb 13, 2008
    #7
    > John
    Go down to your local hardware store. They have lamp switches that push
    on, push off. All done mechanically.
    Paul Hovnanian
    Procrastinators: The leaders for tomorrow.
    Paul Hovnanian P.E., Feb 13, 2008
    #8
    > > toggle switch?
    > > self-indicating.
    > forward ...
    Unless the item is a camera which switches itself off just in time to
    miss as the shot you have been waiting for !
    #9
  10. linnix
    linnix Guest
    > > John
    But many customers just push on and leave on battery devices. On
    second thought, I am going to randomly disable the auto-off feature.
    I am starting a batteries on-line business.
    > Paul Hovnanian
    #10
  11. linnix
    linnix Guest
    On Feb 13, 1:48 pm, (Adrian
    > > > toggle switch?
    > > > self-indicating.
    > > forward ...
    But the camera button (trigger) should be auto-on as well.
    > (Remove the ".invalid"s and add ".co.uk" to reply)www.poppyrecords.co.uk
    #11
  12. Tam
    Tam Guest
    "Paul Hovnanian P.E." <> wrote in message
    news:...
    >> John
    > Paul Hovnanian
    And if you need to switch more current than the lamp switch can handle, use
    it to operate a power relay. BTW, if you go the 7474 route, be sure to
    debounce the switch.
    Tam
    Tam, Feb 13, 2008
    #12
  13. Arie
    Arie Guest
    "John Bachman" <> wrote in message
    news:...
    > John
    Something like this?
    100k GND- 10n -------o o------ 1uF -- GND +
    | | |\ 1M 10k
    |-- 100k ----------|-\ | |
    |-- 100k ----------|+/ |
    | ----- 100k ---
    100k
    GND
    The comparator is self-latching, after power-on output is high (for minimum
    current drawn).
    Alternative: connect the 10n to +, then it starts with output low.
    Pressing the switch less than 1 sec switches the state.
    Repeating the switch presses fast does not switch state (slow debounce).
    Arie de Muynck
    Arie, Feb 13, 2008
    #13
  14. John Bachman
    John Bachman Guest
    On Wed, 13 Feb 2008 20:31:17 +0000, lid
    >> >>John
    >> >Input Voltage?
    >> >Load Current?
    >self-indicating.
    Cost is the only objection. A tactile momentary costs .16. A toggle
    is a buck or more. When the total product part cost is $12 then $.84+
    is lot.
    Two momentaries cost $.32 and will do the job, but Oh, that is ugly.
    John
    #14
    > >> >>John
    > >> >Input Voltage?
    > >> >Load Current?
    > >self-indicating.
    > is lot.
    I'd be willing to pay the extra for a decent switch, but I suppose it
    depends on which sector of the market the product is aimed at.
    Adrian Tuddenham, Feb 14, 2008
    #15
  16. On a sunny day (Wed, 13 Feb 2008 23:13:22 +0100) it happened "Arie"
    <> wrote in <47b36c49$0$85784$4all.nl>:
    > | | |\ 1M 10k
    > | ----- 100k ---
    > 100k
    > GND
    >current drawn).
    >Arie de Muynck
    I must say I am impressed, a nice solution.
    As to the issue what is 'nest', this uses 10 components, 2 of which are capacitors.
    Placing, board size, vias....
    I did say 74HC74, but even that requires some debounce, as others have pointed out,
    so at least 2 more components.
    The OP says he has no micro.
    But how a about a simple 8 pin PIC?
    Use the internal osc, internal pullup at an input pin, trigger interrupt,
    flip output, hang some milliseconds in interrupt routine as debounce.....
    It is all there, with *1* component, say a PIC 12F629, only 67 cent in volume.
    http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=1001&mid=10&lang=en&pageId=74
    And, it also has a build in comparator that perhaps can replace some part
    of the rest of the circuit.....
    I would definitely go that way, have been using that PIC to replace simple circuits
    no several times.
    That way you need to have only 1 part in store.
    Jan Panteltje, Feb 14, 2008
    #16
  17. Tam
    Tam Guest
    "Jan Panteltje" <> wrote in message
    news:fp19s3$fur$...
    >> | | |\ 1M 10k
    >> | ----- 100k ---
    >> 100k
    >> GND
    >>minimum
    >>current drawn).
    >>Arie de Muynck
    > capacitors.
    > pointed out,
    Actually, that is not that bad, because you use the other half of the HC74
    package to debounce. However, to do it right you need a SPDT switch: no
    capacitors needed.
    Tam
    > volume.
    > circuits
    > no several times.
    Tam, Feb 14, 2008
    #17
    1. Advertisements
Similar Threads
  1. Chris W
    Turning a light on and off with momentary switch
    Chris W, Feb 16, 2005, in forum: Electronic Basics
    47
    2,313
    Michael A. Terrell
    Feb 28, 2005
  2. Asimov
    AC shaded pole single phase induction pole motor
    Asimov, Apr 25, 2005, in forum: Electronic Repair
    4
    1,329
    Sam Goldwasser
    Apr 26, 2005
  3. John Bachman
    John Bachman, Feb 13, 2008, in forum: Electronic Repair
    9
    642
    John Bachman
    Feb 14, 2008
  4. John Gilmer
    Re: Double-pole single toggle switch vs. 3-way switch?
    John Gilmer, Jun 24, 2004, in forum: Electrical Engineering
    4,705
    John Gilmer
    Jun 24, 2004
  5. BBourdage
    11
    645
    KrisBlueNZ
    Feb 11, 2013
Loading...
Share This Page
