DC current limiter
Discussion in 'Misc Electronics' started by Kamus of Kadizhar, Jan 22, 2004.
  1. Is there a currrent limiter that can limit 12VDC to < 60 amps?
    I have a situation with a deep cycle lead-acid battery where the 60 amp
    breaker trips when charging. I'd like to limit the current to reasonable
    levels and have continuous charging rather than spikes of > 60 amp
    current, breaker trips, resets, spikes, etc....
    --Kamus
    o__ | If you're old, eat right and ride a decent bike.
    ,>/'_ | Q.
    (_)\(_) | Usenet posting`
    #1
    1. Advertisements
  2. "Kamus of Kadizhar" <> wrote in message
    news:p...
    You can make a current limiter for any current.
    But, There is a voltage burden in doing so.
    > --Kamus
    > ,>/'_ | Q.
    | __O Thomas C. Sefranek
    |_-\<,_ Amateur Radio Operator: WA1RHP
    (*)/ (*) Bicycle mobile on 145.41, 448.625 MHz
    http://hamradio.cmcorp.com/inventory/Inventory.html
    http://www.harvardrepeater.org
    Thomas C. Sefranek, Jan 22, 2004
    #2
    1. Advertisements
  3. Kamus of Kadizhar
    Roger Gt Guest
    in message
    news:p...
    to < 60 amps?
    spikes of > 60 amp
    > --Kamus
    What are the cause of the spikes, what is the peak
    value (if known) and how long do they last?
    Roger Gt, Jan 22, 2004
    #3
  4. On Thu, 22 Jan 2004 18:08:26 +0000, Roger Gt wrote:
    > What are the cause of the spikes, what is the peak value (if known) and
    This is part of an RV charging system. There is a 60A breaker followed by
    a solenoid. When the engine is off, the solenoid is open and the starter
    battery is isloated from the RV battery.
    The problem comes in when the RV battery is depleted and you start the
    engine to charge it. The solenoid closes and the engine starts to charge
    teh RV battery. The current is greater than 60 A, so the breaker trips.
    It resets autmatically, but trips again and again until a series of these
    short cycles charges the battery enough so that less than 60 amps is
    required for charging.
    The problem is that some sort of breaker is needed; loads on RV batteries
    can be 100A or greater for short times (like when using a microwave) and
    you really want to isolate the car alternator from having to deal with
    loads like that.
    A battery isolator introduces a voltage drop (0.7 V or so) so I'm trying
    to see if a current limiter of some sort exists that does not have a
    current drop like that.
    --Kamus
    ,>/'_ | Q.
    Kamus of Kadizhar, Jan 23, 2004
    #4
  5. "Kamus of Kadizhar" <> wrote in message
    news:p...
    > loads like that.
    Current drop like what? Did you confuse the voltage drop for a current
    drop?
    Current limiting is inherently a voltage drop!
    > --Kamus
    > ,>/'_ | Q.
    Thomas C. Sefranek, Jan 23, 2004
    #5
  6. In article <>,
    mentioned...
    > news:p...
    > > loads like that.
    > drop?
    He could put a low resistance across the breaker, say about 1 ohm.
    That would allow about a dozen amps to flow even when the breaker is
    tripped. What would make a cheap low resistance? Well, how 'bout a
    car headlamp? They're not expensive and they're easy to find. You
    might consider going to a junkyard to buy a sockete for it.
    > > --Kamus
    @@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
    Watson A.Name - Watt Sun, Dark Remover, Jan 23, 2004
    #6
    > drop?
    Fat finger typo.
    Well, yes. But I guess I'm looking for some sort of "intelligent" current
    limiter - one that gets out of the way if the current is less than 60 amps.
    I've found a DC-DC charger that might work; I'll contact the manufacturer.
    #7
  8. Kamus of Kadizhar
    Ross Mac Guest
    news:p...
    > loads like that.
    > --Kamus
    > ,>/'_ | Q.
    There are battery isolators that have almost no drop..
    Here is one you might consider... http://www.hellroaring.com/nodiode.htm
    Just do a google search and you will find others such as MasterVolt....Happy
    RVing.....Ross
    Ross Mac, Jan 23, 2004
    #8
    1. Advertisements
Similar Threads
  1. Claudio Bonavolta
    Current limiter or current booster
    Claudio Bonavolta, Jan 26, 2004, in forum: Electronic Basics
    4
    1,137
    Claudio Bonavolta
    Jan 28, 2004
  2. Klaus Kragelund
    Need a simple DC output current limiter
    Klaus Kragelund, May 6, 2009, in forum: Electronic Design
    22
    939
    Jim Thompson
    May 11, 2009
  3. John Doe
    961
    Oppie
    Feb 24, 2012
  4. John Doe
    584
    Oppie
    Feb 24, 2012
  5. KUMARA SHP
    design 1A current limiter for my 300V dc supply
    KUMARA SHP, Aug 1, 2014, in forum: Off-Topic Members Lounge
    6
    1,727
    KrisBlueNZ
    Aug 3, 2014
Loading...
