Datamarine wind instrument
Discussion in 'Boat Electronics' started by GBM, Oct 12, 2005.
  1. GBM
    GBM Guest
    I have an old Datamarine Wind Instruments - LX-360, I think. It has worked
    fine up until now, but this year, the wind speed just reads 0.00, while
    direction works fine.
    I plugged the masthead unit directly into the back of the display, and there
    is no change, so presumably cable is OK.
    I see from http://www.dmimarine.com/ that there is a masthead speed rebuild
    kit. Has anyone done this? Are there any checks that I could make to see
    whether problem is in head or in masthead unit?
    GBM, Oct 12, 2005
    #1
    1. Advertisements
  2. Lynn Coffelt
    Lynn Coffelt Guest
    "GBM" <> wrote in message
    news:uYZ2f.8054$...
    worked
    there
    rebuild
    Yes, and yes. It's been a while, but in a prior life, did lots of
    masthead rebuilds. Testing can be simple if you can find the "pinout"
    (connections) on the connectors. (I don't have that data anymore)
    The masthead speed unit is a sort of AC generator, and with a scope,
    old analog multimeter, or even a pair of headphones you can see or hear the
    output of the generator while spinning the rotor by hand.
    The indicator can be tested for basic function by driving the speed
    input pins with a fairly low frequency square wave from a function
    generator.
    Big problem was having schematics of the connectors to see just what
    pins were to be connected to the poor man's test equipment.
    For a long time, Datamarine wind instruments used the same connectors,
    and it was usually easy to spot a spinning Datamarine masthead unit on your
    same dock. Visit (with best manners, and maybe a couple of cool ones in
    hand) and ask to hook up your instrument to his functioning masthead unit.
    (power connections too)
    Old Chief Lynn
    Lynn Coffelt, Oct 12, 2005
    #2
    1. Advertisements
  3. GBM
    GBM Guest
    "Lynn Coffelt" <> wrote >
    the
    > generator.
    connectors,
    your
    > Old Chief Lynn
    Hi Lynn,
    If I switch the head on/off several times quickly, I get a read out on the
    windspeed. This 'may' say that the head is OK. The shaft in the masthead
    unit is "sloppy" - I contacted DMI and they say that the bearing goes and
    takes out the windspeed. They have a rebuild that costs $79.00. Probably
    worth a try? I will open it up first and see what gives.
    Thanks for the reply!
    GBM, Oct 12, 2005
    #3
  4. Lynn Coffelt
    Lynn Coffelt Guest
    news:1D83f.8270$...
    scope,
    > the
    > > generator.
    what
    > connectors,
    > your
    unit.
    > > Old Chief Lynn
    > Hi Lynn,
    Yes, by all means, take the head apart first. I'm sure, from what you say,
    it's shot, but half the problems in using the rebuild kit are in
    successfully getting the head apart without ruining something.
    Good Luck!
    Lynn
    #4
    1. Advertisements
Similar Threads
  1. Theo Weber
    ST60 Wind Instrument Calibration
    Theo Weber, May 22, 2004, in forum: Boat Electronics
    1,498
  2. Mihow
    Datamarine link 5000 display? WTB or Repair
    Mihow, Dec 10, 2004, in forum: Boat Electronics
    736
    Mihow
    Dec 10, 2004
  3. Theo Weber
    Raymarine ST60 Wind Instrument Mast Connection
    Theo Weber, Jul 10, 2005, in forum: Boat Electronics
    5
    1,069
    Peter Hendra
    Jul 13, 2005
  4. MazingTree
    Stowe wind instrument sticking
    MazingTree, Jul 12, 2005, in forum: Boat Electronics
    541
    MazingTree
    Jul 12, 2005
  5. GBM
    Datamarine Instrument Repair
    GBM, Nov 28, 2005, in forum: Boat Electronics
    4
    1,034
Loading...
Share This Page
