CTC187 remote control doesn't function/ breaks up picture
Discussion in 'Electronic Repair' started by Spit, Apr 29, 2005.
  1. Spit
    Spit Guest
    I have a 32 inch RCA with a CT187CH3 chassis. I got it 2nd hand so I
    don't know any of it's service history. Had no picture or sound got,
    Resoldered multiple spots on board and then got an hourglass shaped
    raster. Resoldered a diode CR4403 I think and got picture back.
    Picture looks great tunes and adjusts fine with manual
    buttons on front of set.
    But when I use a working RCA remote on the set..doesn't matter if I hit
    volume up/down or channel up/down I get the same result. Picture
    breaks up and sound cuts out..sometimes picture/screen blacks out..as
    soon as I let off the button picture returns on the same station and
    volume setting as before. I get the same result regardless what key on
    the remote I hit.
    I think I may have caused a solder bridge somewhere...Anybody have an
    idea where? or any other ideas. Like what pins on an IC might control
    the remote? and be a problem? I did some soldering around the outside
    of the tuner grounds? could I have screwed something up there?
    I tried to clear up some potential solder bridges with some solder
    wick...and the remote did work for about 5 minutes then went right back
    to same behavior.
    I am a novice so give me advice in detail.
    Spit
    Spit, Apr 29, 2005
    #1
    1. Advertisements
Similar Threads
  1. Steve
    4
    1,320
    Steve
    Nov 1, 2003
  2. Spit
    462
  3. James Sweet
    CTC187 picture too big
    James Sweet, Aug 15, 2006, in forum: Electronic Repair
    5
    452
    Bill S.
    Aug 18, 2006
  4. Replies:
    5
    1,276
    Michael A. Terrell
    Dec 27, 2006
  5. jeff_wisnia
    Faulty ALL Function on Comcast Remote Control
    jeff_wisnia, Nov 19, 2010, in forum: Electronic Repair
    5
    808
Loading...
Share This Page
