Crystals' Shunt & Load Capacitance
Discussion in 'Electronic Basics' started by quanghoc@gmail.com, Aug 11, 2006.
  1. Guest
    , Aug 11, 2006
    #1
    1. Advertisements
  2. PeteS Guest
    wrote:
    > My question refers to this spec
    > http://www.raltron.com/products/pdfspecs/crystal_rse_a_b_c_d.pdf
    > What is Shunt Capacitance and Load Capacitance?
    > Can you explain it to an engineer idiot by using some kinda analogy? I
    > don't know much about these stuffs since I am new. Thanks...
    The shunt capacitance is the total capacitance of the device itself
    across it's terminals.
    The load capacitance is **normally** the loading capacitance required
    to operate the device nominally.
    Once you know those numbers, you can calculate the required loading
    caps (necessary to operate the device properly).
    As circuit stray capacitance and amplifier capacitance vary, the
    crystal mfrs simply specify what the crystal has (for shunt which is
    also sometimes the static capacitance, Co).
    Note that different manufacturers have different notations, so in this
    case Cs may refer to the capacitance of the terminals when mounted on a
    circuit board, in which case it becomes part of the stray capacitance
    below, rather than being the internal static capacitance, which affects
    equivalent resistance and drive levels.
    So if:
    CL = loading capacitance from datasheet
    Cs = Circuit stray capacitance
    Cx1 and Cx2 are loading caps we have to put on the circuit, which may
    be the same value, but sometimes are not (see below)
    Then for proper operation CL = Cs + [(Cx1 * Cx2) / (Cx1 + Cx2)]
    In some cases, oscillators won't start up properly unless they are
    deliberately capacitively imbalanced, in which case the crystal loading
    caps will be different (a ratio of 1.5:1 - 2:1 is typical).
    Cheers
    PeteS
    PeteS, Aug 11, 2006
    #2
    1. Advertisements
  3. Guest
    Wow, that's way more complicated than I thought. But thanks so much.
    So, I know the load capacitance and its use. I still don't get the
    shunt capacitance on its usefulness. Why do we need to know this? How
    does it affect the purchasing decision?
    Thanks.
    > So if:
    > Cheers
    > PeteS
    , Aug 11, 2006
    #3
  4. PeteS Guest
    > Thanks.
    > > So if:
    > > Cheers
    > > PeteS
    In this particular case, the shunt capacitance is *probably* the
    capacitance of the package and must be used in the Cs (above) to
    calculate the proper loading capacitors. It's also important when
    choosing an amplifier (or choosing a crystal for a particular chip that
    has an internal oscillator).
    Cheers
    PeteS
    PeteS, Aug 11, 2006
    #4
    1. Advertisements
Similar Threads
  1. Wong
    What is load capacitance
    Wong, Sep 17, 2003, in forum: Electronic Basics
    4
    16,846
  2. usmgn
    load capacitance of a quartz
    usmgn, Nov 6, 2003, in forum: Electronic Components
    11
    863
    usmgn
    Nov 9, 2003
  3. frank
    Typical shunt capacitance of xtals
    frank, Aug 31, 2004, in forum: Electronic Components
    1,008
    Christian Rausch
    Aug 31, 2004
  4. Don Kelly
    Re: Shunt Capacitance VARs
    Don Kelly, Jan 31, 2009, in forum: Electrical Engineering
    1,597
    Don Kelly
    Jan 31, 2009
  5. Gadgetastic
    To shunt or not to shunt?
    Gadgetastic, Jun 22, 2013, in forum: General Electronics Chat
    8
    591
    Gadgetastic
    Jun 23, 2013
Loading...
