Craftsman garage door opener blinking code
Discussion in 'Electronic Repair' started by Dwayne, Nov 27, 2003.
  1. Dwayne
    Dwayne Guest
    I'm having a problem with my Sears Craftsman garage door opener.
    Yesterday, when I came home from work, I opened the garage door using
    the remote. After driving in, I tried to close the door, but it only
    clicked and would not close. I get the same response from either the
    remote or the switch in the garage. There is an indicator light on
    the back of the opener that is normally associated with reprogramming
    remotes. This light blinks 5 times, pauses, then blinks 5 times
    again, repeatedly. I assume this is some sort of code, but I have not
    been able to determine the meaning of the code.
    The opener is a model 139.53674SRT1. It is a 1/2 hp Craftsman opener
    on a wooden one-car garage door.
    I would appreciate any advice anyone can give me on this problem.
    #1
    1. Advertisements
  2. Guest
    I do not have a Craftsman opener, but I would assume it might be made
    by someone like Genie. Have you taken the cover off the unit? My unit
    has a reset button inside and that might be all that you need to do
    since the flashing might be an error code of sorts. Also, there is a
    switch with several spring contacts on my unit, and that might need
    cleaning with fine emery cloth.
    , Nov 27, 2003
    #2
    1. Advertisements
  3. WbSearch
    WbSearch Guest
    The blinking light usually indicates either the door hit something on the way
    down, or the LED beam sensors at the door near the floor are inop. If the unit
    closes when you hold the manual push button down, but stops when you release
    it, it is more than likely the LED beam is inop. or out of adjustment.
    WbSearch, Nov 27, 2003
    #3
  4. Bob Shuman
    Bob Shuman Guest
    I agree with the possible causes below, but will also add that the problem
    could be with the door or track itself. For instance, if one of the torsion
    springs broke the weight of the door would not be properly balanced and
    could cause the door to jam on the track. Check the tracks, door, springs,
    pulley/wheels and wires on either side to make sure they are OK.
    Then check the opener itself to make sure it is still mounted soundly and
    has not moved and that the drive mechanism is OK.
    If everything looks good, then there is usually a sensitivity adjustment
    that can be tweaked to a lower sensitivity. My unit has adjustments for
    both up and down directions.
    "WbSearch" <> wrote in message
    news:...
    way
    unit
    release
    Bob Shuman, Nov 28, 2003
    #4
    1. Advertisements
Similar Threads
  1. Jean-Marc Delaplace
    Craftsman garage door opener extra remote does not work
    Jean-Marc Delaplace, Apr 1, 2006, in forum: Electronic Repair
    4
    2,058
    Jean-Marc Delaplace
    Apr 2, 2006
  2. Jean-Marc Delaplace
    Craftsman garage door opener schematic
    Jean-Marc Delaplace, Apr 2, 2006, in forum: Electronic Repair
    1,037
    carlosm3011
    Apr 11, 2006
  3. Replies:
    722
    jakdedert
    Jul 19, 2006
  4. Replies:
    815
  5. shrtrnd
    Craftsman 139.53920DM Garage Door Opener
    shrtrnd, Aug 6, 2013, in forum: Electronics Repair
    4
    710
    shrtrnd
    Aug 13, 2013
Loading...
