crackling on DECT cordless phones, is this a registration problem?
Discussion in 'Electronic Basics' started by licensedtoquill@gmail.com, Nov 11, 2013.
  1. Guest
    I had a Panasonic KX-TG1033s cordless phone on which the base station became flooded and stopped charging its handset a few years ago. So we carried on using the external handsets for charging, which worked OK for a few years.. Then the problems began when we moved the units from a wood-framed singlefamily house to another home, - a 1980s apartment building. I figured either the corroding from the flood which destroyed the base station charging circuits has now (eg) got into pots all over the whole circuit board OR the new home cant handle a 1.9 GHz setup? The whole phone system crackled and gave awful range, as little as 20ft if there is an apartment dividing wall in between!
    So I bought a new base station yesterday and got one new handset. Panasonictold me to de-register and re-register all the handsets which got all of them to link up but possibly not actually work properly. The range is terrible and the person being rung reports that they crackle like mad all the time. (All phones report no problem with battery charge state)
    Is the real situation that these similar units from the same manufacturer with different features all have the same basic circuitry and in reality allgive the same performance anyway? And that the real problem may be that some homes handle 1.9 better while other homes handle 2.4 or 5.8, - or even 900MHz better? We have in fact used a half dozen different phones in this apartment over the years and NONE have worked as badly as this 1.9GHz Panasonic.
    Or is this new one possibly (Panasonic says) just another lousy base station!
    , Nov 11, 2013
    #1
    1. Advertisements
  2. Guest
    > more likely then new building has metal studs in the wall - there is
    > nothing you can do about it.
    But what does that mean in practice? That i have identified that no 1.9 GHz phone will ever work so I cant use any Panasonic DECT?
    And the awful crackling happens when i am five feet from the base station in direct line-of-sight?
    , Nov 11, 2013
    #2
    1. Advertisements
  3. On Monday, November 11, 2013 2:08:27 PM UTC-5, wrote:
    > I had a Panasonic KX-TG1033s cordless phone on which the base station became flooded and stopped charging its handset a few years ago. So we carriedon using the external handsets for charging, which worked OK for a few years. Then the problems began when we moved the units from a wood-framed single family house to another home, - a 1980s apartment building. I figuredeither the corroding from the flood which destroyed the base station charging circuits has now (eg) got into pots all over the whole circuit board ORthe new home cant handle a 1.9 GHz setup? The whole phone system crackledand gave awful range, as little as 20ft if there is an apartment dividing wall in between!
    Maybe just a bad phone line? Do you have a phone that plugs directly into the wall to try?
    George H.
    > So I bought a new base station yesterday and got one new handset. Panasonic told me to de-register and re-register all the handsets which got all ofthem to link up but possibly not actually work properly. The range is terrible and the person being rung reports that they crackle like mad all the time. (All phones report no problem with battery charge state)
    > Is the real situation that these similar units from the same manufacturerwith different features all have the same basic circuitry and in reality all give the same performance anyway? And that the real problem may be that some homes handle 1.9 better while other homes handle 2.4 or 5.8, - or even900MHz better? We have in fact used a half dozen different phones in thisapartment over the years and NONE have worked as badly as this 1.9GHz Panasonic.
    George Herold, Nov 12, 2013
    #3
  4. Guest
    I need to get another Multitalk handset to replace the one with the broken off aerial which this newer one supposedly replaced. it was 2.4 GHz
    , Nov 13, 2013
    #4
  5. Shaun Epp
    Shaun Epp Guest
    wrote in message
    news:...
    Panasonic.
    station!
    DECT phones by Panasonic are usually 6Ghz frequency. I have never heard of
    cordless phones on 1.9GHz
    Shaun Epp, Nov 25, 2013
    #5
  6. Guest
    It is called DECT 6.0 but it operates in the 1.9GHz freq they say. I think the 6.0 is meaningless as few DECT devices can speak to each other, even when from the same manufacturer
    , Nov 26, 2013
    #6
    1. Advertisements
Similar Threads
  1. Elmer Bataitis
    European Phones and US phones
    Elmer Bataitis, Jul 16, 2003, in forum: Electronic Repair
    4
    780
    Jerry Greenberg
    Jul 17, 2003
  2. Gerhard
    Reviving a submarine cordless DECT phone
    Gerhard, Apr 10, 2005, in forum: Electronic Repair
    635
  3. Replies:
    1,259
  4. Amanda Riphnykhazova
    1,547
    Dec 15, 2012
  5. Danny D'Amico
    29
    16,620
    Danny D'Amico
    Jan 10, 2014
Loading...
