Correct way to write 24 hour-time? Decimalpoint too.
Discussion in 'Electrical Engineering' started by Alex Coleman, May 27, 2006.
  1. Alex Coleman
    Alex Coleman Guest
    (1) I see several worthy attempts to write the time in a 24-hour
    format. Does a definitive format exist?
    I want to leave out the seconds. Also note that I am NOT referring
    to computer conventions of any sort.
    QUESTION: If it is 11 minutes past six in the evening then what is
    the correct format?
    1816 hrs
    18:16 hrs
    18:16 hours
    18:16 h
    18:16
    18.16
    18-16
    Does it vary between being written by a word processor and by hand?
    See below.
    (2) What is the correct way to write a decimal point? I am English
    and that means that a comma is not the correct symbol for the decomal
    point.
    But ISTR that when the decimal point was written by hand it was in
    the air about half the height of the digits. Typewriters and word
    prorcessors did not offer that half-way character so a full stop was
    used. But is it more correct to handwrite the decimal point as half
    way up the height of the digits?
    posted to 3 groups whose members probably
    need to be accurate about time recording
    #1
    1. Advertisements
  2. Alex Coleman
    Sam Wormley Guest
    Sat May 27 15:32:17 UTC 2006
    15:32
    Sam Wormley, May 27, 2006
    #2
    1. Advertisements
  3. Alex Coleman
    Guest
    > the correct format?
    > 1816 hrs
    > 18:16 hrs
    > 18:16 hours
    > 18:16 h
    > 18:16
    > 18.16
    > 18-16
    > See below.
    > point.
    Ignoring computers leaves military and aviation as users of 24 hour
    time.
    By their convention, when written, the time would be 1816Z if in UTC,
    some other letter if a different time zone.
    When spoken, it would be eighteen sixteen zulu if in UTC, or eighteen
    sixteen local.
    Jim Pennino
    Remove .spam.sux to reply.
    , May 27, 2006
    #3
  4. Alex Coleman
    Alex Coleman Guest
    >> referring to computer conventions of any sort.
    >> is the correct format?
    >> 1816 hrs
    >> 18:16 hrs
    >> 18:16 hours
    >> 18:16 h
    >> 18:16
    >> 18.16
    >> 18-16
    >> hand? See below.
    >> English and that means that a comma is not the correct symbol for
    >> the decomal point.
    >> was used. But is it more correct to handwrite the decimal point
    >> as half way up the height of the digits?
    > time.
    That was not my intention. I am thinking of this purely for use by the
    layman.
    As this forum is accessed by computer then I wanted to be clear that
    wideley used Unix or Microsoft time formats (however standard in
    computing) are not relevant here.
    > UTC, some other letter if a different time zone.
    > eighteen sixteen local.
    #4
  5. Alex Coleman
    Alex Coleman Guest
    > 15:32
    You would not put in "hours" or "hrs" then to qualify "15:32"?
    #5
  6. Alex Coleman
    Guest
    > >> 1816 hrs
    > >> 18:16 hrs
    > >> 18:16 hours
    > >> 18:16 h
    > >> 18:16
    > >> 18.16
    > >> 18-16
    > >> hand? See below.
    > >> the decomal point.
    > > time.
    > layman.
    Then you are SOL since "layman" don't use 24 hour time and it confuses
    most of them.
    24 hour time is not relevant at all to most people.
    For those that it is, I gave you the convention.
    For a time to be meaningful to geographically separated people, you
    also need to account for time zones. Those too confuse "layman".
    Jim Pennino
    , May 27, 2006
    #6
  7. Alex Coleman
    Guest
    > > 15:32
    To avoid confusing it with weeks or fortnights perhaps?
    The ":32" isn't in hours.
    Jim Pennino
    , May 27, 2006
    #7
  8. Alex Coleman
    The Sorcerer Guest
    "Alex Coleman" <> wrote in message
    news:Xns97D0A6DB6CBFB71F3M4@127.0.0.1...
    "Definitive" means how you define it.
    So leave them out. Nobody is forcing you to put them in.
    | the correct format?
    | 1816 hrs
    | 18:16 hrs
    | 18:16 hours
    | 18:16 h
    | 18:16
    | 18.16
    | 18-16
    Any of
    hhmm hrs
    hh:mm hrs
    hh:mm hours
    hh:mm h
    hh:mm
    hh.mm
    hh-mm
    18:11
    I dunno how you got from 11 minutes past to 16 minutes past.
    I noted that you are NOT referring to computer conventions of any sort.
    | See below.
    Is that by ballpoint, fountain pen, pencil, chalkstick, typewriter, on a
    barn door,
    on paper, in a movie, or some other media? Some people simply stab the
    implement,
    others write a tiny circle.
    | I am English
    | point.
    I am part Welsh, part English, but that doesn't prevent me from reading
    Deutsch (I don't speak it well, though).
    "Beispiele ähnlicher Art, sowie die mißlungenen Versuche, eine Bewegung
    der Erde relativ ..."
    Err... yes.
    Oops, I used three decimal points as periods (or as full stops) together as
    an ellipsis.
    http://www.m-w.com/dictionary/ellipsis
    I wonder if you'll see the difference? The spacing between the dots isn't
    quite right.
    Get over your hang-up, all you really need is to be understood and
    English is known worldwide. Those that pretend not to understand are trolls,
    those that do not understand are either morons or simply uneducated. Learn
    their language or wait until they learn English. In the meantime continue
    to write in English.
    Androcles
    The Sorcerer, May 27, 2006
    #8
  9. Alex Coleman
    Sam Wormley Guest
    >>15:32
    Why complicate it... one typically knows what it mean from the
    context in which it is used.
    #9
    Depends on how you define "most people".
    You may be right as long as you stick to your island :)
    The "rest of the world" uses 24 hours time :)
    17:45:03 GMT
    HTH.
    C.
    Charles D. Bohne, May 27, 2006
    #10
  11. Alex Coleman
    Guest
    The majority of the people in a civilian supermarket, shopping mall or
    movie theater.
    Start asking people at random after noon what time it is.
    How many respond in 24 hour time?
    > 17:45:03 GMT
    > HTH.
    > C.
    Jim Pennino
    , May 27, 2006
    #11
  12. Alex Coleman
    The Sorcerer Guest
    "Jan Panteltje" <> wrote in message
    news:e5a555$pe$...
    | On a sunny day (Sat, 27 May 2006 16:24:09 +0100) it happened Alex Coleman
    | <> wrote in <Xns97D0A6DB6CBFB71F3M4@127.0.0.1>:
    | >the correct format?
    | 18:16 hr
    Typical... Five minutes in error.
    18:11 hr
    #12
    >movie theater.
    I don't know for sure what country YOU live in. And what you mean by
    "civilian" ;-).
    Did that all my life ...
    60 to 80 percent (in this part of the world).
    German rule*) is the use of one point and the word "Uhr"
    e.g. 17.30 Uhr , or 19.20 Uhr, 23.45 Uhr
    in any written text.
    C.
    *) Includes Austria, Switzerland, Lichtenstein, Luxembourg ...
    and a couple of other European countries. The word "Uhr"
    may vary according to the local language.
    And yes, I know that Americans think that's just for use
    in the military :->
    #13
  14. Alex Coleman
    Art Deco Guest
    >>movie theater.
    >"civilian" ;-).
    >C.
    >in the military :->
    And your anti-American bigotry has led you to another false conclusion,
    Chu*k.
    Official Associate AFA-B Vote Rustler
    Official Overseer of Kooks and Saucerheads in alt.astronomy
    Co-Winner, alt.(f)lame Worst Flame War, December 2005
    "And without accurate measuring techniques, how can they even
    *call* quantum theory a "scientific" one? How can it possibly
    be referred to as a "fundamental branch of physics"?"
    -- Painsnuh the Lamer
    "Well, orientals moved to the U.S. and did amazingly well on
    their own, and the races are related (brown)."
    -- "Honest" John pontificates on racial purity
    Art Deco, May 28, 2006
    #14
  15. Charles D. Bohne, May 28, 2006
    #15
  16. Alex Coleman
    krw Guest
    In article <4B3eg.225909$>,
    _f says...
    > news:e5a555$pe$...
    > | >the correct format?
    > | 18:16 hr
    > 18:11 hr
    I was wondering when someone would pick up the troll.
    Keith
    krw, May 28, 2006
    #16
  17. Alex Coleman
    The Sorcerer Guest
    "krw" <> wrote in message
    news:...
    | _f says...
    | > news:e5a555$pe$...
    Coleman
    | > | >the correct format?
    | > | 18:16 hr
    | > 18:11 hr
    They do not pay attention to detail.
    This is a more serious and costly trawl by the worst troll:
    http://www.androcles01.pwp.blueyonder.co.uk/DominoEffect.GIF
    Androcles.
    | Keith
    The Sorcerer, May 28, 2006
    #17
  18. Alex Coleman
    Alex Coleman Guest
    confuses
    > most of them.
    Here in Europe we use 24 hour time a great deal.
    Laymen and even old ladies both use it.
    If you make a contention that applies only to the US then that's ok
    but that is not where I live.
    Alex Coleman, May 30, 2006
    #18
  19. It's been .761 days since midnight.
    Hi Alex_Coleman,
    For myself, I write 18 hours 16 minutes after midnight as 6.16 P.
    If it was something that happened 18 hours 16 minutes ago,
    I write it as .761 days... ( 18 + 16 / 60 ) / 24 .
    Jeff…Relf, May 30, 2006
    #19
  20. On Tue, 30 May 2006 09:17:21 GMT, Jan Panteltje
    <> wrote:
    >Wel, i did some introspection, as European, if in the Netherlands at
    >say 16:48h somebody askes you 'what time is it' (in Dutch: Weet U ook
    >hoe laat het is?), I would reply with '12 voor 5' (12 to five).
    >Because of the context people usually KNOW if it is morning or evening.
    Maybe - but you wouldn't do that on the phone with someone calling from
    "het buitenland" :)
    C.
    Charles D. Bohne, May 30, 2006
    #20
    1. Advertisements
Similar Threads
  1. aussiblu
    3
    1,717
    Luke O'Zade
    Jan 17, 2009
  2. Glenn Ashmore
    20 hour vs. 50 hour battery rating
    Glenn Ashmore, Dec 25, 2006, in forum: Boat Electronics
    4
    879
    Glenn Ashmore
    Dec 25, 2006
  3. shaheen
    1,544
    rob_croxford
    Oct 26, 2010
  4. podface
    24 hour time delay circuit
    podface, Apr 14, 2011, in forum: Electronic Projects
    6
    1,948
    podface
    Apr 19, 2011
  5. Kashif Hameed
    6
    212
    Colin Mitchell
    Jan 24, 2016
Loading...
