Concord Express
Discussion in 'Security Alarms' started by Bob La Londe, Aug 2, 2005.
  1. Bob La Londe
    Bob La Londe Guest
    Any quick easy ways to get into program mode on these? I'm faced with a
    takeover of one. An existing cusotmer just bought a business that has one
    of these and he wants me to get it working or change it out for him.
    Not much on the system, so I really don't have any problem with ripping it
    out and replacing it with a new system. I'll need to add some devices to
    bring it up to his standards anyway. Still if I can save us both a couple
    bucks.
    Bob La Londe
    http://www.YumaBassMan.com
    #1
    1. Advertisements
  2. Jim Rojas
    Jim Rojas Guest
    The concord express requires a alpha keypad to plug directly to the panel to
    program it. Or you can download it if you know the installer code.
    The eprom is in a socket, and cannot be erased. It must be loaded with a
    default program in order for the panel to function at all.
    Jim Rojas
    "Bob La Londe" <> wrote in message
    news:...
    > bucks.
    > Bob La Londe
    Jim Rojas, Aug 2, 2005
    #2
    1. Advertisements
  3. Mark Leuck
    Mark Leuck Guest
    You have to have a 60-746 alpha keypad
    news:...
    > bucks.
    > Bob La Londe
    Mark Leuck, Aug 2, 2005
    #3
  4. Mark Leuck
    Mark Leuck Guest
    "Jim Rojas" <> wrote in message
    news:pnBHe.10583$DJ5.7646@trnddc07...
    to
    > Jim Rojas
    You don't need to know the installer code but you do need to know the dealer
    code if programmed, and the account number and the CSID
    #4
  5. Mark Leuck
    Mark Leuck Guest
    "WhoCares" <> wrote in message
    news:...
    > There is a reset jumper (the pins may not actually soldered in, but the
    > pads are on the circuit board)...Power down the system (remove both AC
    > power and battery), short across this jumper, power the system up, and
    > it should bring you back to the factory config....
    Unless the dealer code has been programmed then your screwed
    > Then you will need the 2 line display LCD or VFD keypad attached to it
    > (the "fixed" display keypads don't work for programming)....press "8" to
    > enter programming "4321" for the installer password then "00" to enter
    > installer programming.....
    > The programming is menu driven...use the "A" and "B" keys on the keypad
    > to scroll through the menus....
    > The installer manual is available at www.itii.com ... You simply need to
    > do a free registrastion as a security professional...
    > The Conord Express is a very good system...You're basicly getting 8 free
    > wireless zone (for use with keychain transmitters, or for sensors in
    > hard to reach places..)
    Wait till you see the Concord Express v4, awsome panel compared to the old
    Express
    Mark Leuck, Aug 4, 2005
    #5
  6. Mark Leuck
    Mark Leuck Guest
    "Russell Brill" <> wrote in message
    news:ADgIe.556$...
    > "Mark Leuck" <> wrote in message
    > news:...
    old
    > > Express
    > What goodies did the boys & girls at GE add to the panel???
    > Russ......
    For the Express 32 zones, X-10 built-in, 2-way voice built-in, be able to
    use all standard Concord modules and lots of little things like finally the
    ability to send a silent panic signal, the standard Concord will now have 6
    partitions instead of 2
    A few others that I can't remember this early in the morning but by far a
    much better panel
    #6
    1. Advertisements
Similar Threads
  1. James Barnes
    ITI Concord Express
    James Barnes, Nov 6, 2003, in forum: Security Alarms
    868
    Jim Rojas
    Nov 6, 2003
  2. JOhn
    11
    5,543
    Frank Olson
    Nov 12, 2003
  3. Concord Express Siren Time-Out
    , Jan 10, 2006, in forum: Security Alarms
    6
    722
    JoeRaisin
    Jan 11, 2006
  4. Les H
    Ge Concord Express 60-806 Missing Codes
    Les H, Mar 18, 2007, in forum: Security Alarms
    1,755
    Frank Olson
    Mar 19, 2007
  5. Replies:
    706
Loading...
Share This Page
