Computer fan speed control pot?
Discussion in 'Hobby Electronics' started by NormL, May 24, 2005.
  1. NormL
    NormL Guest
    Hi All;
    I installed another fan in my computer case. Now it sounds like a Jumbo
    Jet taking off. I realised that I only need the fan when the weather is hot.
    I got to wondering if I couldn't install a pot in series with the fan to
    slow down it's speed and, by turning slower, quiet it down.
    Trouble is I don't know what size of pot (in ohms) to put in the line.
    Any suggestions?
    Norm
    NormL, May 24, 2005
    #1
    1. Advertisements
  2. "NormL" <> wrote in message
    news:d6v8l8$4tj$...
    > Hi All;
    > hot.
    > Any suggestions?
    > Norm
    There's all sorts of things you can do.
    Have a look at
    http://www.cpemma.co.uk/index.html
    Or consider an off the shelf item like
    www.zalman.co.kr/eng/product/view.asp?idx=70&code=017
    IMHO pots present problems, either use PWM or a switched diode voltage
    dropper
    Rob
    Robert Murphy, May 24, 2005
    #2
    1. Advertisements
  3. NormL
    David Segall Guest
    "NormL" <> wrote:
    >Hi All;
    >Any suggestions?
    > Norm
    I don't have a direct answer to your question but I installed a second
    fan and DPDT Center Off switch to switch them in series, parallel or
    off. It works well so I guess that a pot of about the same resistance
    as your fan should be OK.
    David Segall, May 24, 2005
    #3
  4. NormL
    Gary Slater Guest
    Or... try here?.....
    http://www.almico.com/speedfan.php
    news:d6v8l8$4tj$...
    > Hi All;
    > hot.
    > Any suggestions?
    > Norm
    Gary Slater, May 29, 2005
    #4
    1. Advertisements
Similar Threads
  1. Fritz Oppliger
    ceiling fan speed control
    Fritz Oppliger, Jan 23, 2004, in forum: Electronic Basics
    9
    2,216
    Fritz Oppliger
    Jan 30, 2004
  2. Father Haskell
    Pot value for motor speed control
    Father Haskell, Mar 19, 2006, in forum: Electronic Design
    4
    706
    Rich Grise
    Mar 22, 2006
  3. N_Cook
    Golf Caddy - totally worn out speed control pot
    N_Cook, Oct 4, 2009, in forum: Electronic Repair
    426
    N_Cook
    Oct 4, 2009
  4. ToddB73
    404
    (*steve*)
    Dec 15, 2014
  5. DiamondsareMine
    What Potentiometer should I get to control the speed of a computer fan?
    DiamondsareMine, Jul 19, 2015, in forum: General Electronics Chat
    21
    499
    DiamondsareMine
    Jul 20, 2015
Loading...
