Compact flash programming and specs
Discussion in 'Electronic Design' started by Bernie, Sep 23, 2004.
  1. Bernie
    Bernie Guest
    Can someone help me out with finding specs/protocol for programming
    compact flash. I am logging data with an A/D and need to save it to a
    compact flash card which will be read by a card reader on a laptop. I
    read another thread that talked about needing to use the FAT32
    protocol for MS Windows. I don't know how to do that either, but also
    need info on connections and reading/writing to Compact Flash cards.
    Thanks in advance,
    Bernie
    #1
    1. Advertisements
  2. Tim Wescott
    Tim Wescott Guest
    > Thanks in advance,
    > Bernie
    You've searched the web?
    As far as I know any flash card will come to you as a mass of blank
    storage. I don't know if the standard is for NAND flash only or if it
    supports NOR flash -- but that should be on the web. Either way, if you
    want it to be readable as a disk you need to impose a file system on it.
    Generally with DOS-derived machines this is done by treating the
    memory as if it were a disk and writing the usual sectorized data (with
    a FAT in the case of a Windows system). I've forgotten the details of
    FAT-16 and never learned the details of FAT-32 but again -- this should
    be on the web.
    You'll find that writing the FAT 32 file system requires reading lots of
    picky, poorly documented details (remember this is Microsoft you're
    dealing with). You can, however, buy file system software from various
    vendors. I know that US Software sells this, but I don't know their
    current name. You _can_ search the web for this, but you'd be better
    off to buy a copy of some magazine that addresses the embedded systems
    marketplace (Embedded Systems Programming, Nuts & Volts, etc.) and look
    at the ads in the back. Embedded Systems is hard to get subscriptions
    to, so you might want to see if you can find ads on their website.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Tim Wescott, Sep 23, 2004
    #2
    1. Advertisements
    >> Thanks in advance,
    >> Bernie
    > Generally with DOS-derived machines this is done by treating the memory
    > as if it were a disk and writing the usual sectorized data (with a FAT
    > in the case of a Windows system). I've forgotten the details of FAT-16
    > and never learned the details of FAT-32 but again -- this should be on
    > the web.
    You might try looking at the open source drivers used by Linux
    Dirk
    The Consensus:-
    The political party for the new millenium
    http://www.theconsensus.org
    Dirk Bruere at Neopax, Sep 23, 2004
    #3
    1. Advertisements
Similar Threads
  1. Mad Scientist Jr
    compact flash pinout question
    Mad Scientist Jr, Apr 19, 2004, in forum: Electronic Basics
    9
    833
  2. Abe Cd
    Compact Flash interface
    Abe Cd, Jan 6, 2005, in forum: Electronic Basics
    509
    Abe Cd
    Jan 6, 2005
  3. Puneet
    Compact flash connectors
    Puneet, Oct 14, 2004, in forum: Electronic Components
    389
    Puneet
    Oct 14, 2004
  4. VN
    Interfacing to compact flash port
    VN, Feb 27, 2006, in forum: Electronic Components
    493
    William P.N. Smith
    Feb 27, 2006
  5. a
    3
    564
Loading...
Share This Page
