CMOS inverter dynamic behavior!
Discussion in 'Electronic Basics' started by Francesco, Jun 23, 2006.
  1. Francesco
    Francesco Guest
    I'm studyng CMOS inverter dynamic behavior, and in my book I read at
    first that the two transistor NMOS and PMOS ohw compose the inverter are
    forbidden or in saturation for all the first half of the logical
    excursion (until the 50%)
    I think that ,for example if at the output I have logic level H (VDD)
    and I turn on the NMOS, it is in saturation until VDS>=VDD-VT (VT is the
    threshold voltage), then it go on linear mode.
    Obviously the same situation for the PMOS in the L-->H excursion.
    What I don't understand?
    Sorry for my english!
    Francesco
    To answer me remove the numbers!
    #1
    1. Advertisements
  2. Hi Francesco,
    This is how we would describe the CMOS inverter switching behavior.
    Assume at the beginning, the input is at 0V. (Vin = 0V). As it
    increases,
    when Vin < Vthn, NMOS is off. And PMOS is ON. So the Vout is Vdd. This
    means that the PMOS is in linear region.
    When Vin> Vthn, NMOS is ON. And Vout decreases. Since Vout is still
    high, NMOS is in saturation region. At the beginning, PMOS is still in
    linear region. But as Vin increases more and Vout decreases more, there
    is a point that PMOS will go into saturation region. And there is
    another point NMOS will go into linear region (because Vout will be so
    low that Vin-Vout=Vgate-Vdrain>Vth).
    Eventually, when Vin is > Vdd - |Vthp|, PMOS is off and NMOS is in
    linear region. Now, the Vout = 0V.
    In short, as Vin changes from 0V to VDD: PMOS: Linear => Sat = >OFF,
    and NMOS: OFF=>sat=>Linear
    And at 50% point, since Vin=Vout, (That means Vg = Vd for both NMOS and
    PMOS), both are at saturation region.
    Send us an email if you need more explanation.
    KodKodKod Learning Consulting
    http://www.kodkodkod.com
    > Francesco
    KodKodKod Learning Consulting, Jun 25, 2006
    #2
    1. Advertisements
  3. Francesco
    Francesco Guest
    KodKodKod Learning Consulting ha scritto:
    _cut_
    I agree this, but before the 50% point, has you see, then two MOS aren't
    in saturation! I'wrong? Why?
    Can you explain me the case of Vin as an ideal current generator!
    Thank's for your patience, and once more sorry for my english!
    Francesco
    Per rispondermi in privato togliere i numeri!
    Francesco, Jun 25, 2006
    #3
    1. Advertisements
Similar Threads
  1. Francesco
    Francesco, Jun 23, 2006, in forum: Electronic Basics
    493
    Francesco
    Jun 23, 2006
  2. Winfield Hill
    cmos-logic -- low dynamic power dissipation
    Winfield Hill, Sep 1, 2005, in forum: Electronic Design
    11
    814
    Winfield Hill
    Sep 3, 2005
  3. Replies:
    1,110
  4. Francesco
    Francesco, Jun 24, 2006, in forum: Misc Electronics
    607
    Francesco
    Jun 24, 2006
  5. andrea
    help with cmos tg dynamic shift register
    andrea, Nov 13, 2010, in forum: Electronics Homework Help
    39
    4,591
    andrea
    Nov 17, 2010
Loading...
