Chip Malfunction PIC16F648A , date code 03142Y3
Discussion in 'Electronic Components' started by Grzegorz Zalot, Aug 18, 2003.
  1. We now know the cause of the problems with the PIC16F648A.
    The internal EEPROM writing procedure damages some bits in the port
    status register, most probably bit RP0 is affected. And seemingly this
    happens only if multiple interrupts occur during writing the EEPROM. However,
    this doesn't really matter, the chips are not usable anyway.
    Writing the EEPROM takes about 4 ms, too long to disable all interrupts
    during that time.
    regards
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
    mailto:
    #1
    1. Advertisements
  2. Hi Grzegorz,
    From where do you know that? Did Microchip say something?
    Can you post that too? It would be quite interesting....
    With "multiple interrupt", you say, you re-enable interrupts after
    you *entered* the interrupt service routine?
    You are aware that there are only 8 stack levels (IIRC) and your
    ISR code must be able to handle re-entrance, aren't you?
    Have you tried to disable interrupt source one by one to identify
    the interrupt that makes a problem?
    Curious,
    Wolfgang
    Wolfgang Mahringer, Aug 18, 2003
    #2
    1. Advertisements
  3. ........
    Still no ....
    NO !!!!!
    I know !!!
    Still no. I have not too much time .....
    Grzegorz Zalot
    complex ltd.
    mailto:
    #3
  4. Hi Grzegorz,
    > Still no ....
    > NO !!!!!
    Ah, ok. *phew*
    > I know !!!
    I don't remember, have you tried more chips? May be that one is
    defective for some reason...
    Not really helpful,
    Wolfgang
    #4
  5. Hallo Wolfgang Mahringer !:
    No, :-( .... Not only I have this problem ! This is like reproducible !
    > Not really helpful,
    I too ....
    N-HTH
    Grzegorz Zalot
    complex ltd.
    mailto:
    #5
  6. Grzegorz Zalot
    Tilmann Reh Guest
    Perhaps you missed the first thread about this problem, started
    on 18.07. by Grzegorz.
    He also used the 628 and 628A, both did perform perfectly without
    problems with exactly the same object code. The 648A however
    reproducibly showed these failures.
    Dipl.-Ing. Tilmann Reh
    Autometer GmbH Siegen - Elektronik nach Maß.
    http://www.autometer.de
    In a world without walls and fences, who needs Windows and Gates ?
    (Sun Microsystems)
    Tilmann Reh, Aug 18, 2003
    #6
  7. Hi Tilman,
    No, I haven't...
    Yes, I am aware of that...
    > The 648A however
    Thats why my question was: have you tried other (648's) chips?
    Wolfgang
    #7
  8. Hallo Wolfgang Mahringer !:
    >>The 648A however
    All chips at my distributor have the same date code ..... I wait from two months
    onto a new chips .....
    Grzegorz Zalot
    complex ltd.
    mailto:
    #8
  9. Hello Grzegorz,
    Well, you're getting your problem narrowed down.
    As I said in my reply to your original post, I will be very surprised if it
    turns out to be a silicon issue. I still strongly suspect your firmware. You
    should not have to disable interrupts for the entire cycle.
    Regards,
    Patrick Gomolchuk
    "Grzegorz Zalot" <> wrote in message
    news:...
    However,
    > during that time.
    > regards
    > Grzegorz Zalot
    > complex ltd.
    > mailto:
    Patrick Gomolchuk, Aug 18, 2003
    #9
  10. "Patrick Gomolchuk" <> wrote in message
    news:XRb0b.21883$...
    > Hello Grzegorz,
    it
    You
    I had a similar issue with PIC16F877 some time ago. I was using the PIC-C
    compiler from CCS. Their EEPROM-write routine did just that - turn off
    interrupts for the whole write period (actually, they sensed a "done" bit to
    terminate the process). Microchip's documentation says that you need to
    disable interrups only during the 55-AA trigger sequence, so I rewrote the
    routine to do just that, checking for "done" before starting a new write.
    Richard Henry, Aug 18, 2003
    #10
  11. Hallo Jan-Erik Söderholm !:
    > From the 16F627/628/648 data sheet (DS40044A) :
    > "Required Sequence" :
    > BCF INTCON, GIE ;Disable INTs.
    > MOVLW 55h ;
    > MOVWF EECON2 ;Write 55h
    > MOVLW AAh ;
    > MOVWF EECON2 ;Write AAh
    > BSF EECON1,WR ;Set WR bit
    > ;begin write
    > And later on the same page (page 91) :
    > "We strongly recommend that interrupts be disabled during this
    > code segment."
    Yes, during THIS SEQUENCE, and NOT during the EEPROM program cycle - the next
    4-8 ms !!!
    Grzegorz Zalot
    complex ltd.
    mailto:
    Grzegorz Zalot, Aug 19, 2003
    #11
  12. Hello Patrick Gomolchuk !:
    > Hello Grzegorz,
    I am not surprise :-( !!!
    This is NOT possible ! I have a special serial interface with ca. 0,1 ms cycle
    time. And the PIC16F873A works fine, but is too big and costs too much.
    Grzegorz Zalot
    complex ltd.
    mailto:
    #12
  13. Have you checked the chip errata? This may be a known issue. You could also
    call microchip and work with them. If its silicon, they'll want to know
    about it.
    Regards
    news:...
    > > Hello Grzegorz,
    it
    cycle
    > Grzegorz Zalot
    > complex ltd.
    > mailto:
    Robert Monsen, Aug 19, 2003
    #13
  14. Grzegorz Zalot
    Ben Bradley Guest
    In
    comp.arch.embedded,sci.electronics.components,sci.electronics.design,
    >news:...
    >> > Hello Grzegorz,
    >it
    >cycle
    >> Grzegorz Zalot
    >> complex ltd.
    >> mailto:
    >Gregorz,
    >I am bitbanging 2 channels with a comparable frequency on the 648a (some
    >with identical date code, got them from Digikey), as well as using every
    >other peripheral on this device pretty much to their maximum potentials. All
    >interrupts are used extensively, including the eeprom write-end interrupt. I
    >experience no such problems on this busy device. I hand code everything and
    >I see no such critical error. Although this successful application is not
    >sufficient proof, it does lead me to maintain that it is highly likely that
    >your code is at fault. The fact that your code works on other flavors of the
    >device does not mean much. Marginal code works marginally. I'd keep digging
    >if it is economically viable to do so. You should be able to trap this error
    >somehow.
    I'm not familiar with the pic and haven't followed all these
    threads, but I've done my share of embedded code.
    It could be useful if the 'problem code' on the 'problem
    microcontroller' can be reduced to the minimum amount of code that
    will produce the problem. This will either result in code that no
    longer has the proprietary application and can be shown to the
    manufacturer or posted publically, clearly demonstrating the problem
    to all, or in creating this minimum-problem-producing code the coder
    will find a problem in the code, fix it and go on.
    HTH, HAND, etc.
    >Regards,
    >Patrick Gomolchuk
    Ben Bradley, Aug 20, 2003
    #14
  15. Hello Patrick Gomolchuk !:
    > somehow.
    I have 3 circuits with this processor, and one works OK. But not only I have
    such problems - a different man in Poland has a similar problem. In this moment
    we look for exact causes.
    Software looks OK, because (fast) the same code works OK on 16F873.
    regards
    PS. You speak polish ???
    Grzegorz Zalot
    complex ltd.
    mailto:
    Grzegorz Zalot, Aug 20, 2003
    #15
  16. Grzegorz Zalot
    Brian Logan Guest
    I believe you could be right about a chip problem as I've recently learned of a
    problem of a similar nature in the PIC16F874A Rev. B0 errata sheet. The problem
    on those devices is that some instructions are being corrupted above 4MHz. In
    the errata sheet, Microchip advise customers to test a sample of at least 100
    units with their own code to see if the parts are suitable. The section from the
    errata sheet begins:
    "3. Module: Core
    Certain code sequence and placement may cause
    the corruption of a few bits in the instruction fetch
    when the part is used above 4 MHz. A corrupted
    instruction fetch will cause the part to execute an
    improper instruction and result in unpredictable
    outputs."
    Brian Logan
    Brian Logan, Aug 20, 2003
    #16
  17. Hello Brian Logan !:
    I know this problem (errata). One my circiut have a 4 MHz quartz, the second 12
    MHz. Then no this cause ....
    Grzegorz Zalot
    complex ltd.
    mailto:
    Grzegorz Zalot, Aug 21, 2003
    #17
  18. Hello Patrick Gomolchuk !:
    > Gregorz,
    > somehow.
    What compiler do you use ? We have HiTech the newest version. And you ?
    Different firm in PL which has this problems use HiTech also.
    Grzegorz Zalot
    complex ltd.
    mailto:
    Grzegorz Zalot, Aug 25, 2003
    #18
    1. Advertisements
Similar Threads
  1. Mike
    4
    695
    Franc Zabkar
    May 25, 2004
  2. Grzegorz Zalot
    Grzegorz Zalot, Aug 18, 2003, in forum: Electronic Design
    17
    1,075
    Grzegorz Zalot
    Aug 25, 2003
  3. c a l a n d e
    Date code decipher help
    c a l a n d e, Sep 2, 2006, in forum: Electronic Components
    3,160
  4. Henry Kolesnik
    Mallory date code ?
    Henry Kolesnik, Sep 22, 2008, in forum: Electronic Repair
    11
    3,247
    raypsi
    Sep 27, 2008
  5. Peter Leopold
    Yuasa production date code
    Peter Leopold, Aug 13, 2004, in forum: Security Alarms
    3,103
    Peter Leopold
    Aug 13, 2004
Loading...
