center tapped transformer
Discussion in 'Electronic Basics' started by billb, Feb 4, 2005.
  1. billb
    billb Guest
    I made this dice pyramid that I want to light from inside with
    incandescent bulbs and I bought this radio shack 12.6 volt xformer,
    but it has a "center tapped secondary" and I don't know what that
    means or how to wire it to power some 12 volt bulbs.
    can anybody help?
    billb
    billb, Feb 4, 2005
    #1
    1. Advertisements
  2. "billb" <> wrote in message
    news:cu13d1$jj6$...
    You just ignore the center-tap (do not connect it). I assume you know that
    the transformer current/power rating must not be exceeded or it will get too
    hot and self-destruct!
    Charles Schuler, Feb 5, 2005
    #2
    1. Advertisements
  3. dB
    dB Guest
    "billb" <> wrote in message news:<cu13d1$jj6$>...
    > can anybody help?
    The secondary winding has a centre tap (a connection in the middle) so
    that between either end of the secondary and the tap you would measure
    6 volts.
    Just ignore it and wire your bulbs to the other two secondary
    connections.
    dB, Feb 5, 2005
    #3
  4. billb
    billb Guest
    > connections
    ok, thanks!
    billb
    "dB" <> wrote in message
    news:...
    xformer,
    > > can anybody help?
    so
    measure
    > 6 volts.
    billb, Feb 5, 2005
    #4
    1. Advertisements
Similar Threads
  1. Center tapped transformer equations
    , Jan 30, 2006, in forum: Electronic Design
    7
    2,015
    Don Foreman
    Feb 1, 2006
  2. billb
    billb, Feb 4, 2005, in forum: Electronic Repair
    3
    846
    billb
    Feb 5, 2005
  3. pierre1
    Wiring center tapped transformer secondary for most power
    pierre1, May 1, 2011, in forum: General Electronics Chat
    4
    1,706
    pierre1
    May 2, 2011
  4. Gristle McThornbody
    Doubling a Center-Tapped Transformer
    Gristle McThornbody, Mar 14, 2012, in forum: General Electronics Chat
    436
    Gristle McThornbody
    Mar 14, 2012
  5. Anand P. Paralkar
    Center Tapped and Regular Transformer
    Anand P. Paralkar, Aug 27, 2012, in forum: Electronic Basics
    21
    1,223
    Fred Abse
    Sep 4, 2012
Loading...
Share This Page
