cassette stuck - aiwa home audio system
Discussion in 'Electronic Repair' started by jmoeller18, Feb 27, 2005.
  1. jmoeller18
    jmoeller18 Guest
    after loading cassette tape from library into aiwa home audio system
    it won't play, eject, or do anything
    the 2nd tape deck won't play either
    i've tried resetting the unit (turn on while holding clear/off button)
    i took the side panels off, but i can't reach much
    please advise
    MODEL: NSXA777 ( CXNA777 ) on aiwa.com
    http://www.us.aiwa.com/default.asp?page=support&browse=yes&model=1369
    #1
    1. Advertisements
  2. jmoeller18
    b Guest
    button)
    > please advise
    firstly: do not think about forcing the cassette door!
    Look inside the unit. You need to hand rotate the capstan flywheel a
    bit,( a large-ish metal disc attached to the motor via a rubber drive
    belt.)That should release the powered deck mechanism and allow
    ejection.
    Then buy a new drive belt , so that problem does not recurr.
    Ben
    b, Feb 27, 2005
    #2
    1. Advertisements
  3. jmoeller18
    jmoeller18 Guest
    thanks! It worked immediately!
    jmoeller18, Feb 28, 2005
    #3
    1. Advertisements
Similar Threads
  1. Steven Patterson
    Aiwa cassette deck problem
    Steven Patterson, Oct 13, 2003, in forum: Electronic Repair
    1,671
    Rheilly Phoull
    Oct 13, 2003
  2. James ORourke
    1,387
    James ORourke
    Nov 29, 2003
  3. charity kerwin
    aiwa stuck on hold
    charity kerwin, May 12, 2004, in forum: Electronic Repair
    509
    charity kerwin
    May 12, 2004
  4. HandyMan
    1,198
    Arfa Daily
    Sep 20, 2005
  5. Dan
    AIWA mini system cassette problem
    Dan, Mar 25, 2006, in forum: Electronic Repair
    7
    888
    Arfa Daily
    Mar 28, 2006
Loading...
