Capacitance value?
Discussion in 'Electronic Basics' started by z, Nov 9, 2006.
  1. z
    z Guest
    I have opened my Sky Digibox which has stopped working
    and I am having problems reading capacitor values. For
    example, there are many blue blob type capacitors
    (ceramic dipped resin I guess) which I can't understand,
    for example, one has 221K
    I then took it out and measures 1.4nF if I remember
    correctly. What does 221K mean?
    p.s. it was rated at 2kv - is that a switching psu? anyone
    knows how to troubleshoot those?
    (panasonic tu-dsb20)
    z, Nov 9, 2006
    #1
    1. Advertisements
  2. Arlet
    Arlet Guest
    try google "capacitor codes" ?
    Arlet, Nov 9, 2006
    #2
    1. Advertisements
  3. z
    z Guest
    O.k. so what is 221K ?
    z, Nov 9, 2006
    #3
  4. Arlet
    Arlet Guest
    The first link on google "capacitor codes" points to
    http://xtronics.com/kits/ccode.htm, which says in the first couple of
    paragraphs:
    "Now, what about the three numbers? It is somewhat similar to the
    resistor code. The first two are the 1st and 2nd significant digits and
    the third is a multiplier code. Most of the time the last digit tells
    you how many zeros to write after the first two digits, but the
    standard (EIA standard RS-198) has a couple of curves that you probably
    will never see. But just to be complete here it is in a table."
    The single letter at the end is explained a bit further down the page.
    Arlet, Nov 9, 2006
    #4
  5. Eeyore
    Eeyore Guest
    It's the value in pF as follows. The first and second numbers are the first part
    of the value and the last digit is the number of trailing zeros.
    So 221 = 220 pF
    The K is a tolerance letter ( 10% ).
    The cap you mention sounds like a snubber cap in a switch mode psu.
    Graham
    Eeyore, Nov 10, 2006
    #5
    1. Advertisements
Similar Threads
  1. Jim Simmons
    Capacitance Meter Kit ???
    Jim Simmons, Jun 17, 2004, in forum: General Electronics
    726
    Jim Simmons
    Jun 18, 2004
  2. Boki
    capacitance symbos
    Boki, Jul 25, 2003, in forum: Electronic Basics
    568
  3. Naveed
    What is the capacitance value of a condenser?
    Naveed, Feb 16, 2006, in forum: Electronic Design
    14
    3,444
    Joseph2k
    Feb 23, 2006
  4. dietermoreno
    49
    5,661
    dietermoreno
    May 6, 2013
  5. P E Schoen
    Capacitance value for PIC crystal
    P E Schoen, Jun 6, 2013, in forum: Electronic Design
    27
    631
    Robert Macy
    Jun 9, 2013
Loading...
