Can I swap a NiMH with NiCad?
Discussion in 'Electronics Repair' started by thundermasmacho, Jul 22, 2011.
  1. thundermasmacho
    thundermasmacho
    Jul 22, 2011
    5
    I have a cordless WaterPik (M/N WP-360) and it no-longer holds a charge. I have a number of questions:
    1. What's the easiest way to determine if it's the battery or the charger that has gone tits-up?
    2. It currently uses a 2.4V 1300mAh NiMH battery pack, but I can only find NiCad's with the same specs and dimensions (small enough to fit in the unit).
    So, can I replace an NiMH with a NiCad? I know that NiCad is kind of obsolete now, and comes with a whole host of other issues and concerns, but they seem to be pretty cheap and easy to find.
    2a. Anyone know of a good place to find a NiMH with these specs?
    2b. If I use a NiCad instead, is there a danger in overcharging, or a fire, etc.?
    #1
    1. Advertisements
  2. thundermasmacho
    Resqueline
    Jul 31, 2009
    2,847
    1. Can't say w/o detailed information about the product and your resources.
    2.Yes.
    2a. What spec's? I've seen 2.4V & 1300mAh but there's more to a battery spec' than that.
    2b. No. If the charger is intelligent it might just stop charging a little too early.
    Resqueline, Jul 22, 2011
    #2
    1. Advertisements
  3. thundermasmacho
    thundermasmacho
    Jul 22, 2011
    5
    I don't have a lot of details on the battery or the device as I have long since lost the paperwork that came with it.
    However, here is the battery part number which may help:
    GP130AAHE2B1H
    Other info on the battery pack:
    NiMH Battery
    2.4V 1300mAh
    H9
    I guess you might call it a "2 AA Model" as it appears to be 2 AA batteries bound together.
    #3
  4. thundermasmacho
    Resqueline
    Jul 31, 2009
    2,847
    Ok, size AA is good info. I find the GP130AAHE cell datasheet but nothing on the assembled pack. Does it have solder flanges attached, and how are they configured?
    #4
  5. thundermasmacho
    thundermasmacho
    Jul 22, 2011
    5
    [​IMG]
    [​IMG]
    #5
  6. thundermasmacho
    shrtrnd VIP Member
    Jan 15, 2010
    2,737
    232
    Arizona
    Your charging circuit is for NiMH, I wouldn't swap NiCads for it, because the charging
    circuit parameters are different. The only reason you can't find 1300mAh NiMH's, is
    because they have considerably higher capacities these days. You can use any NiMH,
    that has a higher amp/hour capacity. If you're in the U.S., get the batteries from
    All Electronics Corp in Van Nyes, CA, ....or any other elec supply shop. This is any
    easy fix, you just need the right batteries or battery 'pack' (of two), that is readily
    available from many places.
    shrtrnd, Jul 22, 2011
    #6
  7. thundermasmacho
    thundermasmacho
    Jul 22, 2011
    5
    Brilliant!! Thank you so much.
    I have a couple more questions for you then:
    1. Just to clarify, 1300mAh means 1300 miliamps/hour correct?
    2. Does the voltage make a difference then? Higher? Lower? Or should I definitely find one that is 2.4V?
    Thanks again for all of your help.
    Cheers,
    -KS
    #7
  8. thundermasmacho
    TBennettcc VIP Member
    Dec 4, 2010
    292
    Cape Coral, FL, USA
    1300mAh means 1300 milliamp-hours. Which means it can supply a current of 1.3 amps (1300 milliamps) for one hour. Or 2.6 amps for 30 minutes (at least on paper). In real life, these things vary.
    Rechargeable battery cells are usually 1.2v, hence, two in series give you 2.4v. It shouldn't be hard to find a 2.4v battery pack.
    TBennettcc, Jul 22, 2011
    #8
  9. thundermasmacho
    thundermasmacho
    Jul 22, 2011
    5
    Thanks Tim, a really do appreciate it; my teeth and gums also thank you.
    If you'd like to learn more about being a drunkard who lives in Portland, then please tune into Funemploymnet Radio: http://funemploymentradio.com/
    Cheers,
    -Kenny
    #9
  10. thundermasmacho
    shrtrnd VIP Member
    Jan 15, 2010
    2,737
    232
    Arizona
    Like TBennettcc said, both NiCads and NiMH cells are typically designed for 1.2v.
    The reason your battery pack is composed of two cells, is to reach the 2.4V needed
    for your device. These days you're going to find replacement batteries at or above
    2400mA/Hr. All that means, is your between-charge times will be less, because of
    higher Amp Hour capacity of the newer batteries.
    shrtrnd, Jul 25, 2011
    #10
    1. Advertisements
Similar Threads
  1. KellyClarksonTV
    NiCad and NIMH
    KellyClarksonTV, Jun 4, 2004, in forum: General Electronics
    3
    645
    WDino
    Jun 7, 2004
  2. Mitch
    Can I replace NiCad with NiMH?
    Mitch, Mar 28, 2007, in forum: Electronic Basics
    8
    1,098
    Puckdropper
    Mar 30, 2007
  3. mc
    563
  4. SimonP
    Can a Nicad charger be used for NiMH batteries?
    SimonP, Sep 13, 2009, in forum: General Electronics Chat
    4
    1,586
    SimonP
    Sep 17, 2009
  5. moeburn
    Can I use a NiMH battery in a NiCad charger?
    moeburn, Jul 31, 2013, in forum: Electronic Projects
    9
    2,170
Loading...
