Can I charge my laptop with a 60W adapter instead of a 90W adapter?!
Discussion in 'Electronic Repair' started by mc.preist@gmail.com, Jan 6, 2007.
  1. Guest
    I have a laptop, and my adapter doesn't work.
    My laptop needs a 90W adapter. My friend has a 65W adapter of the same
    brand (it's a dell). Is it okay to charge your battery with another
    type of charger without turning the computer on?!
    Thanks!
    , Jan 6, 2007
    #1
    1. Advertisements
  2. iws Guest
    <> wrote in message
    news:...
    > Thanks!
    If the output voltage is the same and the connector is configured the same
    then there should be no problem. I do it with my thinkpads and their
    different adapters all the time.
    iws, Jan 6, 2007
    #2
    1. Advertisements
  3. JANA Guest
    If the connector is exactly matched, and the voltage is exactly the same, it
    should work. Most likely the battery will take longer to charge.
    Do not run your computer with your friend's adaptor. Only charge the
    battery, if it is electrically compatible as mentioned above. Because its
    wattage rating is lower, the lifespan of the lower wattage adaptor will be
    reduced, or have a strong possibility of being damaged if you run a device
    that requires a higher wattage.
    JANA
    _____
    <> wrote in message
    news:...
    Thanks!
    JANA, Jan 6, 2007
    #3
  4. James Sweet Guest
    > Thanks!
    So long as the voltage is within 10% or so and the polarity is the same,
    it should work fine. Do keep an eye on the temperature of the adapter to
    make sure it isn't getting too hot though.
    James Sweet, Jan 6, 2007
    #4
  5. My understanding is that it will work fine but the CPU will throttle
    back. My experience with a D800 was that even with the 90W adaptor it
    still throttled back.
    >Thanks!
    Joe Leikhim K4SAT
    "The RFI-EMI-GUY"©
    "Treason doth never prosper: what's the reason?
    For if it prosper, none dare call it treason."
    "Follow The Money" ;-P
    **THE-RFI-EMI-GUY**, Jan 7, 2007
    #5
    1. Advertisements
Similar Threads
  1. zooeb
    resistence of 60W glow lamp
    zooeb, Jan 14, 2005, in forum: Electronic Basics
    5
    468
  2. Nick
    Can I use a 27C040 eprom instead of 27C020?
    Nick, Mar 26, 2005, in forum: Electronic Components
    7
    912
  3. Franc Zabkar
    Sanken S-40W, S-60W, ECG1354, NTE1354
    Franc Zabkar, May 9, 2006, in forum: Electronic Components
    2,298
    Franc Zabkar
    May 9, 2006
  4. Greg L.
    Can't charge my laptop battery
    Greg L., Sep 5, 2006, in forum: Electronic Repair
    3
    1,102
    Greg L.
    Sep 5, 2006
  5. David Virgil Hobbs
    is total charge always simply +charge + -charge?
    David Virgil Hobbs, Apr 17, 2004, in forum: Misc Electronics
    4
    1,039
    Carl Farrington
    Apr 18, 2004
Loading...
