calculator for resistive divider using standard resistor values?
Discussion in 'Electronic Design' started by M. Noone, Dec 23, 2005.
  1. M. Noone
    M. Noone Guest
    Hi - I feel like I saw this somewhere but have since lost the link. It
    was a website where you could put in the ratio you want a resistive
    voltage divider to give, and it would give you combinations of standard
    resistor values that would yield that ratio.
    Anybody know of anything like this?
    Or are there any tricks to finding these values that I'm just not aware
    of?
    -M. Noone
    #1
    1. Advertisements
  2. M. Noone
    Ken Taylor Guest
    "M. Noone" <> wrote in message
    news:...
    > of?
    > Thanks,
    > -M. Noone
    Google. I actually used Altavista and used +resistor +combination
    +calculator and got hits. I'm sure it would work for you too.
    Cheers.
    Ken
    Ken Taylor, Dec 23, 2005
    #2
    1. Advertisements
  3. M. Noone
    Ken Moffett Guest
    Ken Moffett, Dec 23, 2005
    #3
  4. M. Noone
    Joerg Guest
    Joerg, Dec 23, 2005
    #4
  5. M. Noone
    M. Noone Guest
    Perfect - google turned up a different page than that one on the same
    website, but with different keywords. I think I used something like
    'resitor divider common value calculator'. Thanks!
    Ken Moffett wrote:
    > "Ken Taylor" <> wrote in news:DiZqf.10243$vH5.499299
    > @news.xtra.co.nz:
    > > +calculator
    > http://www.play-hookey.com/dc_theory/resistor_ratios.html
    #5
    > of?
    > Thanks,
    > -M. Noone
    Spreadsheet.
    Cheers!
    Rich
    Rich Grise, but drunk, Dec 24, 2005
    #6
  7. M. Noone
    Ken Taylor Guest
    Ken Taylor, Dec 24, 2005
    #7
  8. "M. Noone" <> writes:
    > of?
    > Thanks,
    > -M. Noone
    I once knocked up a C program that you are welcome to try, or perhaps
    expand on.
    It has a very lazy algorithm that searches all combinations of 2 and 3
    resistor dividers to find the closest match. You can customise the
    first line of main() to choose between e6, e12 or your own resistor
    value series. There are still plenty of configurations it does not
    try, such as three resistors in series. Also you have to get the
    correct power of 10 by yourself!
    John
    #include "stdio.h"
    #include "math.h"
    /* The E12 series */
    float e12_base[]= { 1.0, 1.2, 1.5, 1.8, 2.2, 2.7, 3.3, 3.9, 4.7, 5.6, 6.8, 8.2 };
    float e6_base[] = { 1.0, 1.5, 2.2, 3.3, 4.7, 6.8};
    float my_base[] = { 1.0, 1.5, 1.8, 2.2, 4.7, 6.8};
    /* program to find the optimum series-parallel combination of
    resistors, to get a given ratio */
    float xyz1(float x, float y, float z)
    return x/(1.0/(1.0/y+1.0/z));
    float xyz2(float x, float y, float z)
    return x/(y+z);
    int main(void)
    /* customise these three (6 or 12) */
    float * base_series=e12_base;
    int base_N=12;
    int decades=6;
    float target;
    int N=base_N*decades;
    int x,y,z;
    float min_error=1E30;
    float error;
    float ratio;
    int x_min, y_min, z_min;
    float series[N];
    int i;
    float decade=1;
    int n=0;
    for(i=0;i<decades;i++)
    for(x=0;x<base_N;x++)
    series[n] = base_series[x]*decade;
    printf("%f ",series[n]);
    n++;
    printf("\n");
    decade *= 10;
    printf("Resistor series-parallel calculator program!\n");
    printf("Calculates optimum combinations of resistors\n");
    printf("to acheive a target ratio of resistance R1/R2\n");
    printf("\n\n\nEnter target ratio (1.000-9.999):");
    scanf("%f", &target);
    printf("Target ratio is %f\n\n", target);
    /* algorithm: two-resistor divider (Rx, Ry): for each Rx, Ry in
    series, find minimum ratio Rx/Ry.
    for(x=0;x<N;x++)
    for(y=0;y<N;y++)
    ratio = series[x]/series[y];
    error = fabs(ratio-target);
    if(error<min_error)
    min_error=error;
    x_min=x;
    y_min=y;
    ratio=series[x_min]/series[y_min];
    printf("\n\nBest ratio with two resistors is %f\n",ratio);
    printf("Percentage error is %f%%\n",100*(1-target/ratio));
    printf("Ry=%f\n", series[y_min]);
    printf("Rx=%f\n", series[x_min]);
    min_error=1E30;
    /* algorithm: three-resistor divider (Rx, (Ry||Rz)) */
    for(x=0;x<N;x++)
    for(y=0;y<N;y++)
    for(z=0;z<N;z++)
    ratio = xyz1(series[x],series[y],series[z]);
    if(error<min_error)
    min_error=error;
    x_min=x;
    y_min=y;
    z_min=z;
    ratio = xyz1(series[x_min],series[y_min],series[z_min]);
    printf("\n\nBest ratio with 3 resistors (Rx, (Ry||Rz) is %f\n",ratio);
    printf("Rz=%f\n", series[z_min]);
    /* algorithm: three-resistor divider (Rx, (Ry+Rz)) */
    min_error=1E30;
    for(x=0;x<N;x++)
    for(y=0;y<N;y++)
    for(z=0;z<N;z++)
    ratio = xyz2(series[x],series[y],series[z]);
    if(error<min_error)
    min_error=error;
    x_min=x;
    y_min=y;
    z_min=z;
    ratio = xyz2(series[x_min],series[y_min],series[z_min]);
    printf("\n\nBest ratio with 3 resistors (Rx, (Ry+Rz) is %f\n",ratio);
    return 0;
    John Devereux
    John Devereux, Dec 24, 2005
    #8
  9. M. Noone
    Fred Bloggs Guest
    Oh well- forget it then!- waaaaa...ay too much thinking required....
    Fred Bloggs, Dec 24, 2005
    #9
  10. Fred Bloggs <> writes:
    John Devereux
    #10
  11. M. Noone
    M. Noone Guest
    Looks good - I'll hold on to that for the future. Thanks,
    -M. Noone
    > expand on.
    > John
    > #include "stdio.h"
    > #include "math.h"
    > return x/(y+z);
    > int main(void)
    > int base_N=12;
    > int decades=6;
    > float target;
    > int x,y,z;
    > float error;
    > float ratio;
    > float series[N];
    > int i;
    > float decade=1;
    > int n=0;
    > n++;
    > printf("\n");
    > decade *= 10;
    > for(x=0;x<N;x++)
    > for(y=0;y<N;y++)
    > if(error<min_error)
    > min_error=error;
    > x_min=x;
    > y_min=y;
    > min_error=1E30;
    > for(x=0;x<N;x++)
    > for(y=0;y<N;y++)
    > for(z=0;z<N;z++)
    > if(error<min_error)
    > min_error=error;
    > x_min=x;
    > y_min=y;
    > z_min=z;
    > min_error=1E30;
    > for(x=0;x<N;x++)
    > for(y=0;y<N;y++)
    > for(z=0;z<N;z++)
    > if(error<min_error)
    > min_error=error;
    > x_min=x;
    > y_min=y;
    > z_min=z;
    > return 0;
    > John Devereux
    M. Noone, Dec 24, 2005
    #11
  12. M. Noone
    Fred Abse Guest
    Re: calculator for resistive divider using standard resistor values?
    That's a bit restricted.
    "Electricity is of two kinds, positive and negative. The difference
    is, I presume, that one comes a little more expensive, but is more
    durable; the other is a cheaper thing, but the moths get into it."
    (Stephen Leacock)
    Fred Abse, Dec 24, 2005
    #12
  13. Re: calculator for resistive divider using standard resistor values?
    Fred Abse <> writes:
    Yes, my interest was in getting as close as possible with a *limited*
    range of part values.
    You can edit the program to put whatever sequence you like in. That's
    what the my_base array was for, just fill it in with E96 or whatever.
    John Devereux
    #13
  14. M. Noone
    Bob Monsen Guest
    > of?
    I wrote a javascript version a year of two ago:
    http://home.comcast.net/~rcmonsen/resistors.html
    Regards,
    Bob Monsen
    My dear, I used to think I was serving humanity’¡Ä and I pleasured in
    the thought. Then I discovered that humanity does not want to be
    served; on the contrary it resents any attempt to serve it."
    ~ Jubal Harshaw
    Bob Monsen, Dec 24, 2005
    #14
    > of?
    Yes, at http://www.ibrtses.com/products/index.html
    download http://www.ibrtses.com/products/teiler22.zip
    Rene
    Ing.Buero R.Tschaggelar - http://www.ibrtses.com
    & commercial newsgroups - http://www.talkto.net
    Rene Tschaggelar, Dec 26, 2005
    #15
  16. M. Noone
    Dave F. Guest
    Dave F., Jan 4, 2006
    #16
    1. Advertisements
Similar Threads
  1. dude
    3
    972
  2. Rick Nungester
    Standard Resistor Values: Why not a true geometric series?
    Rick Nungester, Oct 15, 2007, in forum: Electronic Design
    197
    4,205
    John Larkin
    Oct 24, 2007
  3. danny davis
    How to added up a Resistor Value using misc values
    danny davis, Jun 15, 2012, in forum: General Electronics Chat
    88
    3,305
    CocaCola
    Jun 28, 2012
  4. joeyb
    3
    660
    mechatronix
    Feb 18, 2013
  5. Angy15
    How to find resistances values in a voltage divider?
    Angy15, Dec 22, 2015, in forum: General Electronics Chat
    164
    Arouse1973
    Dec 22, 2015
Loading...
