Calculating Wind Uplift
Discussion in 'Photovoltaics' started by ken, Aug 13, 2006.
  1. ken
    ken Guest
    Does anyone here know a formula for calculating the uplift force
    on a ground-mounted array of solar panels? I assume it would
    use the area of the panels, angle from horizontal, wind speed,
    maybe soil bearing strength, etc. etc.
    ken, Aug 13, 2006
    #1
    1. Advertisements
  2. ken
    SJC Guest
    "ken" <> wrote in message news:p-sjc.supernews.net...
    Sort of depends on the angle and the wind direction. If they are mounted
    at 40 degrees and get wind from the backside, I would suspect that you
    would get plenty of force behind them in a 20 knot wind.
    SJC, Aug 13, 2006
    #2
    1. Advertisements
  3. ken
    daestrom Guest
    "Duane C. Johnson" <> wrote in message
    news:...
    > Hi Ken;
    > > the uplift force on a ground-mounted array of
    > > solar panels? I assume it would use the area of
    > It really doesn't mater what the aerodynamic forces
    > actually are. The National Building Code trumps
    > this.
    > The NBC basically specifies a wind load of 10 lbs of
    > force per square foot static load on a vertical
    > surface. I recommend adding an additional 5 lbs of
    > force per square foot for dynamic wind loading. I
    > understand these loadings are based on a wind speed
    > of 90 mph.
    The physics of it is the worst force on a blunt object is 0.5*rho/gc*V^2
    where rho is the density of air (about 0.074 lbm/ft^3), and V is the
    velocity. This assumes a drag coefficient of 1.0 and gives the answer in
    Force/area.
    So a 1 ft^2 in a 63 mph (92.4 fps) wind has a force of just about 10 pounds.
    (.5*0.074/32.2*92.4^2)
    Of course, if the panels are angled (very likely), then the local wind speed
    as it 'squeezes' between/ under/ around the panel could be higher, and hit
    the panels at almost any angle.
    I wouldn't worry so much about direct upward lift (the weight of the panel
    helps keep it down), but more about the side/ forward/ backward forces
    tending to push them over. The tensile strength of the supports to hold
    them down is probably a lot higher than the lateral bending strength to hold
    them upright.
    > Make the calculation with the panels in the worst
    > possible orientation. For failsafe reasons, you should
    > not allowed the use active systems to to ameliorate
    > the effects of the wind for this calculation.
    Agreed.
    daestrom
    daestrom, Aug 15, 2006
    #3
  4. ken
    ken Guest
    Thanks everyone -- as Duane surmised, it's all been covered in
    the Uniform Building Code. One of the rack mfrs (UniRac) has
    made a table of "design wind pressure" as a function of the
    official windspeed in your area and "exposure class", both of
    which your local bldg. dept. knows by heart. Mine happen to be
    70 mph and class B. Plug 'em into the table, out comes 10 pounds
    per sq.ft. Assume it's all straight up, and pour an equal weight
    of concrete as a foundation or piers. Keeps them happy, and keeps
    yer panels from blowing over (apparently :))
    -K
    ken, Aug 15, 2006
    #4
  5. ken
    Guest
    >actually are. The National Building Code trumps this.
    Would you have a chapter and verse? What is this
    "National Building Code" and where does it apply?
    >The NBC basically specifies a wind load of 10 lbs of force
    >per square foot static load on a vertical surface...
    >based on a wind speed of 90 mph.
    The basic velocity pressure is 0.00256V^2 psf, with V in mph,
    eg 21 psf at 90 mph.
    >... For failsafe reasons, you should not allowed the use
    >active systems to to ameliorate the effects of the wind
    You mean like, giant fans blowing in the other direction? :)
    Nick
    , Aug 16, 2006
    #5
  6. "Duane C. Johnson" <> wrote in message
    news:...
    > Hi Ken;
    > > covered in the Uniform Building Code. One of the
    > > rack mfrs (UniRac) has made a table of "design wind
    > > pressure" as a function of the official windspeed
    > > in your area and "exposure class", both of which
    > http://www.unirac.com/solarmount/sm_pdf/ii214.pdf
    > About page 5.
    > > Mine happen to be 70 mph and class B. Plug 'em into
    > > the table, out comes 10 pounds per sq.ft. Assume
    > > it's all straight up, and pour an equal weight of
    > > and keeps yer panels from blowing over
    > > (apparently :))
    > > -K
    > Duane
    Thanks for the link, should come in handy.
    Cheers
    Martine Riddle, Aug 17, 2006
    #6
  7. ken
    daestrom Guest
    <> wrote in message
    news:ebuv7v$...
    Google is your friend....
    http://www.google.com/search?hl=en&q="National+Building+Code"
    As to 'where does it apply', that is much like the National Electric Code.
    It depends on the AHJ (Area Having Jurisdiction).
    Many parts of the US have state/local building codes that endorse the NBC as
    part of themselves. NY for example has their own building code that adds
    more requirements than the NBC. Similarly, FL and CA have stricter codes
    when it comes to hurricane and earthquake design requirements respectively.
    YMMV...
    No, I think he was thinking more along the lines of a tracking system that
    would tilt parallel to the wind to reduce surface area, or some
    retraction/lowering mechanism to reduce exposed surface.
    Giant fans? You sometimes take the cake Nick. Only you would say something
    that outragous.
    daestrom
    daestrom, Aug 17, 2006
    #7
  8. <snip>
    Like these? www.bigassfans.com
    #8
  9. ken
    Guest
    daestrom <daestrom@NO_SPAM_HEREtwcny.rr.com> wrote:
    >> ... What is this "National Building Code" and where does it apply?
    >part of themselves...
    I don't think we've ever used NBC in PA. We just switched from BOCA to ICC.
    It looks like the ICC specifies 85 or 90 mph where I live west of Phila
    (the code official is supposed to read the 50-year wind map and fill in
    a blank.) Table R301.2(2) of the 2006 ICC for 1- and 2-family dwellings
    says a zone 3 roof edge (within 4' of a ridge at the end of a roof) would
    have 36.8 psf of uplift and a wall would have 14.6 psf of pressure in
    a 90 mph wind. These would be multiplied by 1.21 for a 15' mean roof height
    in exposure class C (open terrain) vs 1.0 for class B (urban and suburban)
    and 1.47 for class D (wind arriving over open water.)
    Nick
    , Aug 17, 2006
    #9
  10. ken
    Guest
    Martine Riddle <> wrote:
    ><snip>
    >Like these?
    http://www.bigassfans.com
    Not exactly, altho they certainly are big ceiling fans, 24 feet in diameter
    with a 2 HP motor turning 43 rpm and moving 338K cfm. Wow. What do they cost?
    Perhaps they can turn very slowly with the VFD drive, eg 1000 cfm at 0.13 rpm,
    ie 8 seconds per revolution?
    Nick
    , Aug 17, 2006
    #10
  11. ken
    Guest
    >... my rule of thumb was what my local building
    >inspector told me to use. He said the NBC, National
    >Building Code, was 10psi horizontal in 90mph.
    Hmmm... 1440 psf.
    >And, from the chart, on page 5, this suggests that
    >I would need to use about 15psi...
    Hmmm... 2160 psf.
    Nick
    , Aug 17, 2006
    #11
    1. Advertisements
Similar Threads
  1. Calum MacLean
    Calculating frequencies based on cycle counts
    Calum MacLean, Dec 8, 2004, in forum: General Electronics
    3,283
  2. StructureUnionWarrior
    Need Help Calculating Field in TEM Cell
    StructureUnionWarrior, Jan 18, 2005, in forum: General Electronics
    1,292
    Jan 18, 2005
  3. John G
    Re: Calculating LED voltage drop
    John G, Aug 9, 2003, in forum: Electronic Basics
    3
    5,126
    cpemma
    Aug 10, 2003
  4. Rheilly Phoull
    Calculating preferred resistor values
    Rheilly Phoull, Jan 15, 2004, in forum: Electronic Basics
    3
    714
    Rheilly Phoull
    Jan 16, 2004
  5. Mike H
    Calculating a SET resistor on an IC
    Mike H, May 26, 2004, in forum: Electronic Basics
    629
    Mike H
    May 27, 2004
Loading...
