Calculating the half power frequency
Discussion in 'Circuit Help' started by kdoug, Mar 1, 2011.
  1. kdoug
    kdoug
    Mar 1, 2011
    I would like to calculate the half power frequency of the circuit attached.
    I have combined the impedances of R2 and C1 with the 1/Z = 1/Z_1 + 1/Z_2 ... forumla. To get R2 / (R2*j*w*C + 1).
    Then use the voltage divider on this combination and R1 to find that,
    Vin / Vout = 1 / ( R1jwC + (R1/R2 +1) )
    I believe the gain now is |Vin / Vout| = 1 / sqrt( (R1wC)^2 + (R1/R2 + 1)^2 )
    At this point, I'm unsure how to proceed. The Internet has told me that the half power frequency occurs when | Vin / Vout | = 1/sqrt(2). If I set what's contained the the radical above equal to 2 and solve for w, I can find the frequency f. I turns out to 141.5 Hz which doesn't agree with a computer generated Bode plot.
    Can anyone suggest what I'm doing wrong?
    Sorry for the poor Maths formatting.
    Thanks for your time,
      File size:
      12.8 KB
      1,224
    kdoug, Mar 1, 2011
    #1
    1. Advertisements
  2. kdoug
    Laplace VIP Member
    Apr 4, 2010
    1,184
    167
    Tombstone, Arizona
    The gain of a network is Vo/Vi. The gain of this network is a function of frequency. Since this is a low-pass filter, the highest gain will be found at f=0 so the gain at the cutoff frequency will be half the power of the gain at zero frequency.
    An alternative method is to realize that the cutoff frequency of a simple low-pass filter is Fc=1/(2piRC) where C=C1 and R=R1| R2. My calculator says Fc=175 kHz. What does the computer generated Bode plot say?
    Laplace, Mar 2, 2011
    #2
    1. Advertisements
  3. kdoug
    kdoug
    Mar 1, 2011
    Thank you for the response, Laplace.
    I've attached the generated Bode plot. I've highlight the cursor representing your answer in green, and what I would have though the right answer is in red (70.7% of 5V, makes for a frequency of approx 325 kHz), though, what I think to be the right answer, appears to have occured after the main "break down" in the curve.
    It's likely I've misunderstood something again, or I'm not using my tools properly. I used PSpice to generate this Bode plot from the circuit I attached previously.
    Thanks for your time & help.
      File size:
      31.2 KB
      590
    kdoug, Mar 2, 2011
    #3
  4. kdoug
    Laplace VIP Member
    Apr 4, 2010
    1,184
    167
    Tombstone, Arizona
    Here are my calculations doing it the long way.
    Laplace, Mar 3, 2011
    #4
    1. Advertisements
Similar Threads
  1. martin griffith
    Five and half G's up and three and half G's down
    martin griffith, Oct 22, 2005, in forum: Electronic Design
    637
    Fred Bartoli
    Oct 22, 2005
  2. Kingcosmos
    Calculating power delivered by supply
    Kingcosmos, Feb 10, 2008, in forum: Electronic Basics
    8
    1,765
    Greg Neill
    Feb 26, 2008
  3. CharlesBlackstone
    9
    641
  4. Default User
    Question about calculating power factor...
    Default User, Jul 8, 2008, in forum: Electronic Design
    9
    988
    Default User
    Jul 10, 2008
  5. atec77
    Calculating Power Usage Costs
    atec77, Feb 18, 2008, in forum: Hobby Electronics
    4
    514
    Rob040
    Feb 19, 2008
Loading...
