Calculate current in shunt resistor
Discussion in 'Electronics Homework Help' started by inlineskater, Jun 15, 2012.
  1. inlineskater
    inlineskater
    Jun 15, 2012
    13
    Ok using the following:
    Ish/Im = Rm/Rsh
    Rsh = shunt resistance
    Rm = meter resistance
    Ish = shunt current
    Im = meter current
    A moving coil ammeter has a coil resistance of 28.5 ohms and a shunt resistor of 1.6 ohms. When the 0-740 mA display reads it maximum, how much current flows through the shunt resistor?
    I need help on this. I have tried with calculating the voltage and power ... help :confused:
    #1
    1. Advertisements
  2. CocaCola
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Gurnee, Illinois - USA - North America - Planet Ea
    Homework?
    If so show your work and answers and someone will hopefully guide you from there...
    CocaCola, Jun 15, 2012
    #2
    1. Advertisements
  3. Laplace
    Laplace VIP Member
    Apr 4, 2010
    1,184
    167
    Tombstone, Arizona
    You have one equation and two unkown variables. What is the second equation?
    Laplace, Jun 16, 2012
    #3
  4. john monks
    john monks VIP Member
    Mar 9, 2012
    693
    Richmond, California
    This is not as much a mathematics problem as it is science problem. This is exactly why you should not be in trapped by memorizing formulas. You should be deriving all your formulas from definitions and scientific facts. If you cannot derive a formula you shouldn't be using it. Without looking at a formula tell me what happens when you apply a current to two resistances in parallel.
    john monks, Jun 16, 2012
    #4
  5. inlineskater
    inlineskater
    Jun 15, 2012
    13
    Solved
    Hello
    This is a math problem and it needed to be rearranged. I did it!:D
    I(sh) = (( Rm / Rs + Rm)). IT
    IT= Total current
    inlineskater, Jun 16, 2012
    #5
  6. john monks
    Mar 9, 2012
    693
    Sorry, I think you're missing the point. If all is you want is the answer you can do it using a formula. There are virtually an infinite number of combinations of parts and many types of parts involving inductors, capacitors, transistors, chemical batteries, and so forth, not just resistors. So are you going to memorize different formulas for all these different situations? Memorizing formulas is backwards. You must first understand the physics or the science and then wrap formulas around them. And if you do not understand how a resistor works get a resistor, a battery, and a multimeter and experiment with them. I design circuits for a living. I only rely on what I know about parts and data sheets. I see formulas on data sheets and I do not use them. I wrap my own numbers around the circuits based on what i know. If i relied only on formulas i never would be able to do my job. When I looked at your problem I realized instantly that you lacked understanding of the parts. So I say again that if you don't understand formula and you cannot derive if based on scientific fasts you should not be using it.
    #6
  7. inlineskater
    inlineskater
    Jun 15, 2012
    13
    No point was missed.
    #7
  8. inlineskater
    inlineskater
    Jun 15, 2012
    13
    Good Point and point taken, next time I will do a complete update to the problem. I was working from a mobile location while being on set.
    #8
  9. inlineskater
    inlineskater
    Jun 15, 2012
    13
    One equation and 2 variable. The expression needed to be arranged as posted. Next time around I shall post all the steps I have taken to solve for the unknown.
    Thank you
    #9
  10. Laplace
    Laplace VIP Member
    Apr 4, 2010
    1,184
    167
    Tombstone, Arizona
    From the wording of the question I can't tell whether the second equation should be (Im=740 mA) or (Im+Ish=740 mA).
    Laplace, Jun 17, 2012
    #10
  11. weird_dave
    weird_dave
    May 9, 2012
    36
    Edited because I was being daft.
    It's not obvious if the meter is 740mA with the shunt in place or if that's the 'standalone' reading without a shunt.
    weird_dave, Jun 17, 2012
    #11
    1. Advertisements
Similar Threads
  1. John
    6
    4,150
  2. TheGrovesy
    Transistor Base Resistor, how to calculate
    TheGrovesy, Jan 26, 2012, in forum: General Electronics Chat
    9
    2,722
    (*steve*)
    Jan 27, 2012
  3. inlineskater
    Calculate Shunt Resistance
    inlineskater, Jun 16, 2012, in forum: Electronics Homework Help
    670
    john monks
    Jun 16, 2012
  4. Gadgetastic
    To shunt or not to shunt?
    Gadgetastic, Jun 22, 2013, in forum: General Electronics Chat
    8
    547
    Gadgetastic
    Jun 23, 2013
  5. MadMechanic
    Homemade Shunt Resistor.
    MadMechanic, Jul 12, 2013, in forum: General Electronics Chat
    5
    875
    GonzoEngineer
    Jul 17, 2013
Loading...
