Brother Multi Function (MFC) Fax/Printer/Scanner Maintenance Mode?
Discussion in 'Electronic Repair' started by John Freund, Sep 12, 2003.
  1. John Freund
    John Freund Guest
    I have two Brother machines:
    MFC 9600
    MFC 4550
    I was able to acquire a copy of the service manuals for each. The manual
    provides instructions for entering the "Maintenance Mode", however it does
    not seem to work on either machine does anyone have any insight to this.
    For bother the instructions are basically the same:
    Press the following buttons within 2 seconds:
    "Function", "*", "2" , "8", "6", "4". The unit will sound a long beep and
    display "Maintenance".
    Either I am doing something wrong, or I have incorrect instructions. Has
    anyone tried this and has it worked?
    John Freund
    #1
    1. Advertisements
  2. James Horne
    James Horne Guest
    "John Freund" <> wrote in message
    news:x2n8b.164286$...
    > MFC 9600
    > MFC 4550
    does
    and
    > Thanks
    > John Freund
    Yes it does work....enter the key sequence more quickly. I'm not sure where
    they got the 2 seconds from because from experience you have to do it within
    about a 1/2 second....will take a few tries to get it right (Hint: use more
    than one finger )
    James
    James Horne, Sep 13, 2003
    #2
    1. Advertisements
  3. John Freund
    John Freund Guest
    James
    It work just like you said. I just had to key in the sequence very quickly.
    Thank you, Thank you, Thank you .... I am forever grateful!
    May your next problem be easily solved!
    John Freund
    where
    within
    more
    > than one finger )
    > James
    John Freund, Sep 13, 2003
    #3
    1. Advertisements
Similar Threads
  1. Franc Zabkar
    Copier, Printer, Fax and MFC Cross Reference Guide
    Franc Zabkar, Aug 20, 2008, in forum: Electronic Repair
    872
    Franc Zabkar
    Aug 20, 2008
  2. Kate Fights, I Cry
    Brother MFC 3240C printer problem and summer heat and inkjets
    Kate Fights, I Cry, May 29, 2005, in forum: Hobby Electronics
    437
    Kate Fights, I Cry
    May 29, 2005
  3. Kate Fights, I Cry
    Brother MFC 3420C Printer Problem
    11
    790
    Colin C
    Jun 2, 2005
  4. Brother MFC 9420CN Color Laser Printer
    , Feb 22, 2010, in forum: Electronic Repair
    4
    2,723
  5. skdaddle
    Brother MFC 9420CN Printer/Fax/Copier Issue
    skdaddle, Jun 11, 2010, in forum: Electronics Repair
    728
    skdaddle
    Jun 11, 2010
Loading...
Share This Page
