Ballast failures
Discussion in 'Lighting' started by Andrew Gabriel, Aug 1, 2008.
  1. Some months back, the issue of electronic ballast reliability came up,
    and I said we lose quite a few at work. Yesterday, I got talking with
    the engineer who replaces them all. He has a box of the failed ones
    which he opens out of curiosity to see what went. We rummaged through
    them, and the most common failure by far (75%) was not one I had
    expected at all. It is that the PCB tracks have flashed over on the
    circuit board. This seems to happen in a variety of different places
    on the circuit boards. Perhaps a third of them are around the bridge
    rectifier diodes, but the others are all in different places, and
    not necessarily anywhere near the mains side of the circuit.
    Initially I though it might be a short to the case through the plastic
    insulator film all the ballasts wrap around the circuit board, but I
    took several of them out and the plastic is undamaged and the arcing
    hasn't gone to the metal case - it's between tracks on the PCB.
    There are several different makes and models of ballast, all
    similarly affected. They are around 6 years old. We lose around 2/week.
    The second most common is a burned out component on the board, either
    a non-polarised capacitor on the output side or the transformer
    itself.
    In a small number of cases, there is no physical damage visible.
    There are also lights in the building with magnetic ballasts.
    None of those has ever failed.
    Andrew Gabriel
    [email address is not usable -- followup in the newsgroup]
    #1
    1. Advertisements
  2. Andrew Gabriel
    Bob Guest
    "Andrew Gabriel" <> wrote in message
    news:4892626f$0$628$...
    > itself.
    > Andrew Gabriel
    A good possibility is the use of water based flux for the soldering. That's
    basically a weak acid - like citric acid. It's supposed to be rinsed off
    after the soldering is done. If traces of it remain, and there's enough
    moisture in the air, it's possible for a conductive path to be created -
    especially where there's several hundred volts to follow the path.
    Bob, Aug 2, 2008
    #2
    1. Advertisements
  3. Andrew Gabriel
    John Guest
    This is a common thing with "switch mode power supplies" which share common
    design ideas with electronic ballasts as opposed to analogue or linear
    designs or in the case of lamps, magnetic ballasts. My experience over 40
    years is that yes, they are more efficient , more compact but if you want
    reliability go linear in power supplies and magnetic for ballasts.
    John, Aug 2, 2008
    #3
  4. In article <g71drs$k53$>,
    "John" <> writes:
    Come to think of it, I've had a switched mode PSU board in a
    video recorder do this. I cleaned it all up, and it's been
    working OK for about 10 years since then (but now gets very
    little use.)
    Andrew Gabriel
    Andrew Gabriel, Aug 2, 2008
    #4
  5. Andrew Gabriel
    TKM Guest
    > itself.
    > Andrew Gabriel
    This harks back to the earlier days of electronic ballasts when
    manufacturers with little experience with PCBs or semiconductors tried to
    learn a lot in a short time. Unfortunately, there were several business
    failures in the process as lightning bolts, line surges, overheating and
    incorrect applications caused electronic ballasts to fail by the
    building-full. It may be comforting to return to the simpler design of
    magnetics; but, of course, there's a 30-40% adder in energy costs these days
    for the same illumination.
    As one who was formerly involved in lamp and ballast product service, I can
    say that this situation is scary for the ballast manufacturer; but it's time
    for a "six sigma" approach to find out what's wrong. My first thought is
    that line surges or overheating are at work and that can go to improper
    circuit design or improper application -- or both (which is the worst case).
    Potentially, there's a product service claim, of course. What's the
    warranty situation? Every ballast manufacturer has a Failues vs. Time curve
    for production ballasts. Match that with your installation experience and
    that becomes the basis for warranty negotiations. Fortunately, someone has
    kept the failed ballasts (hopefully with the install and failure dates).
    Not so good is that they've already been tampered with so the manufacturer
    won't be able to analyze them properly.
    Terry McGowan
    TKM, Aug 2, 2008
    #5
  6. Andrew Gabriel
    Guest
    Got any URLs to linear power supplies for my PC?
    |WARNING: Due to extreme spam, googlegroups.com is blocked. Due to ignorance |
    | by the abuse department, bellsouth.net is blocked. If you post to |
    | Usenet from these places, find another Usenet provider ASAP. |
    | Phil Howard KA9WGN (email for humans: first name in lower case at ipal.net) |
    , Aug 3, 2008
    #6
    1. Advertisements
Similar Threads
  1. thomas
    transistor failures
    thomas, Aug 6, 2004, in forum: Electronic Basics
    3
    411
    Watson A.Name - \Watt Sun, the Dark Remover\
    Aug 7, 2004
  2. karthik
    Failures of Solid State relays
    karthik, Jan 10, 2006, in forum: Electronic Basics
    529
    karthik
    Jan 10, 2006
  3. karthik
    355
    karthik
    Jan 10, 2006
  4. mercer7
    10
    2,230
    Homer J Simpson
    Nov 27, 2006
  5. Replies:
    3
    1,819
Loading...
