Ashton GA80 guitar amp (Australia)
Discussion in 'Electronic Repair' started by N_Cook, Nov 11, 2009.
  1. N_Cook
    N_Cook Guest
    RoHS date of introduction for Australia ?
    Anyway 1/4 inch i/p socket too weak even for domestic use , breaking up in a
    few years ( within RoHS regime), no obvious datecodes except main electros
    seem to be 2000, otherwise maybe 2004 or 2005 IC dates. No-name flimsey junk
    , the type with 2 insulated change over contacts. On trying to work out the
    functions, apart from the tip contact/grounding setup there is a line to one
    of the isolated switches that grounds at plug inserted and o/c when removed
    , it goes DC connected to the base of a pnp transitor - function ?
    #1
    1. Advertisements
  2. N_Cook
    N_Cook Guest
    N_Cook <> wrote in message
    news:hder6j$jg8$-september.org...
    a
    junk
    the
    one
    removed
    If it kills the gain for bang-less plug insertion then it would only work
    for insertion , not removal, as that switch makes before tip makes/breaks
    ground
    N_Cook, Nov 12, 2009
    #2
    1. Advertisements
  3. N_Cook
    N_Cook Guest
    Gareth Magennis <> wrote in message
    news:8gQKm.112991$F%2...
    > "N_Cook" <> wrote in message
    > news:hdghi1$lb7$-september.org...
    > >> in
    > > a
    > >> electros
    > > junk
    > > the
    to
    > > one
    > > removed
    work
    makes/breaks
    > > ground
    > Maybe it mutes the reverb?
    > Gareth.
    Luckily the owner wanted a reliable input socket and was unconcerned about
    the loss of the plug-in de-thump cct. To replace the domestic headphone
    socket (has isolated switching) would have been a work up as 0 or 15V on
    that control line so could not use an effects pedal type ring switch action.
    And the ring switch for a normal stereo 1/4 inch jack is the wrong action
    for here anyway, requiring an inverter somewhere or one of those awkward and
    rare offset 1/4 inch switch actions. cct proper, holds off full gain for 0.5
    seconds or so after plug insertion, all the while removed 30dB or more gain
    drop via 15/-15V control into the first amp. Although no obvious PbF solder
    problems the original input socket had thin+wide blade pins going into holes
    of that wide diameter and loads of filler solder, asking for problems with
    ordinary solder let alone new-fangled
    Diverse Devices, Southampton, England
    electronic hints and repair briefs , schematics/manuals list on
    http://home.graffiti.net/diverse:graffiti.net/
    #3
  4. N_Cook
    N_Cook Guest
    More as a reminder to myself, for the next time this problem appears. A work
    around without having to cut into the existing cct to put in an inverter.
    Use a small SPDT relay (+emf diode) with power adapted from whatever
    convenient rail.
    Permanent ground on the flexing ring contact in a 1/4 inch TRS socket and
    the fixed ring- contact to the low side of the relay.
    N_Cook, Nov 13, 2009
    #4
  5. N_Cook
    N_Cook Guest
    news:hdj5bg$du7$-september.org...
    work
    > convenient rail.
    The added delay, due to relay action, only adding to the desired effect of
    delaying the removal of the gain suppression until after tip contact is made
    ( unless someone is very slow at plug-in)
    #5
  6. N_Cook
    N_Cook Guest
    Robert Macy <> wrote in message
    news:...
    ....snip...
    the answer I got was,
    "Not on the radar."
    RoHS printed on pcb overlay, and definitely grotty PbF-looking solder (but
    not any actual observable or twizzleable bad joints). No RoHS stickers on
    the outside, so presumably standard asian product internally, badged as Oz
    externally
    N_Cook, Nov 17, 2009
    #6
    1. Advertisements
Similar Threads
  1. fffcj
    Add a 9V guitar tuner to at tube amp .
    fffcj, Oct 23, 2004, in forum: Electronic Basics
    7
    813
    CFoley1064
    Oct 23, 2004
  2. Justa_me
    Whats the proper way to TS a SS guitar amp?
    Justa_me, Jan 18, 2005, in forum: Electronic Basics
    574
    Rheilly Phoull
    Jan 19, 2005
  3. bytraper
    477
    bytraper
    Oct 1, 2005
  4. phil.m
    old extension amp to guitar amp
    phil.m, Mar 26, 2013, in forum: Electronic Projects
    3
    545
  5. rover41
    ASHTON BSK-158 BUSKING AMP
    rover41, Jun 15, 2013, in forum: General Electronics Chat
    398
    davenn
    Jun 15, 2013
Loading...
