Any info on Bendix-King autopilot servo connections/functions?
Discussion in 'Electronic Design' started by Peter, May 18, 2004.
  1. Peter
    Peter Guest
    I am trying to find out the signals used by the KFC225 roll servo. The
    generic part number is KS0271C. Most of the pins are pretty obvious
    from their names. I have a schematic showing the connections between
    the autopilot and the servo itself, but for example I don't fully
    understand the functions of the "input" and "input reference" inputs -
    presumably it is some kind of a differential input, but I don't know
    what the specs on the voltage swings is. Also there are some error
    signals which go back to the computer.
    The really puzzling thing is that during certain times at the power-up
    self test, and at all times afterwards, there is a 1.4kHz sinewave of
    about 100mV P-P superimposed onto the DC voltage on the "input" signal
    (the "reference" signal is clean though). I don't know if this is a
    fault of the computer, or whether it is intentional.
    Would anyone familiar with the basic principles of autopilots be able
    to shine any light on this?
    I would like to know this because I am trying to repair one whose
    power amp has burnt out, to keep as a standby.
    Peter.
    Return address is invalid to help stop junk mail.
    E-mail replies to but remove the X and the Y.
    Please do NOT copy usenet posts to email - it is NOT necessary.
    Peter, May 18, 2004
    #1
    1. Advertisements
Similar Threads
  1. Peter
    Honeywell KFC225 autopilot roll servo failure
    Peter, Sep 23, 2005, in forum: Electronic Design
    19
    1,048
    Peter
    Sep 28, 2005
  2. ratiodetector2
    1,033
    Hugh Prescott
    Sep 23, 2003
  3. Guest
    1,018
    Si Ballenger
    Oct 13, 2004
  4. FMV
    945
    Donn J. Sachs
    Apr 17, 2004
  5. Simmon
    5
    490
    Simmon
    Mar 4, 2014
Loading...
