antenna power feed
Discussion in 'Electronic Basics' started by nav, Mar 3, 2006.
  1. nav
    nav Guest
    hi all
    i would be thankful for ur help on power coupling issues in antenna (rf
    section )
    i need to design a coil for the frequency concerned (f=1/(2pi sqr
    root(lc)) and feed the power to antenna.
    the problem comes in getting correct inductance coil designing and
    testing its value
    and secondly
    why the point of tapping power for antenna needs to be done at
    particular point on coil (i.e. like, one and half turns from positive
    feed)
    thanking you all.
    nav, Mar 3, 2006
    #1
    1. Advertisements
  2. nav
    Bob Myers Guest
    "nav" <> wrote in message
    news:...
    > hi all
    > section )
    A coil for what? Coupling to the antenna? If so, coupling
    WHAT to the antenna. Loading an antenna element?
    Acting as an RF choke in a ground connection? You're
    not exactly giving a lot of context for someone to work with,
    here.
    Bob M.
    Bob Myers, Mar 3, 2006
    #2
    1. Advertisements
  3. nav
    Andrew Holme Guest
    news:...
    > hi all
    > section )
    > testing its value
    > and secondly
    > feed)
    > thanking you all.
    The choice of inductance is often driven by the required Q. This may be
    somewhat arbitrarily chosen e.g. anywhere between Q=5 and Q=10 for a class
    C transistor PA stage.
    A tapped coil is an auto-transformer. The tapping point controls loading.
    If you put the tapping in the middle, the transformation ratio is 4:1.
    The dynamic impedance of the (transformed) antenna load across the whole
    coil, the loaded-Q and the inductance are related:
    Loaded Q = R / wL
    w = omega = 2*pi*f
    Andrew Holme, Mar 3, 2006
    #3
    1. Advertisements
Similar Threads
  1. nav
    antenna power feed
    nav, Mar 3, 2006, in forum: Electronic Basics
    452
  2. wreckless1
    817
    wreckless1
    May 27, 2004
  3. Replies:
    920
  4. Gary Schafer
    More on Reflected power on antenna feed lines
    Gary Schafer, Nov 24, 2003, in forum: Boat Electronics
    451
    Gary Schafer
    Nov 24, 2003
  5. Chas
    DVD power feed to disc motor?????
    Chas, Dec 17, 2011, in forum: Beginner Electronics
    2,262
Loading...
