Adding subwoofer to desktop ACS340
Discussion in 'Electronic Repair' started by RichK, Jun 10, 2006.
  1. RichK
    RichK Guest
    Hi Guys,
    I would like to add a small subwoofer to my desktop PC speakers. The
    speakers are pretty good on their own, but extra base would be nice.
    Came by an Altec Lansing ACS340 subwoofer, which was part of a 3-speaker
    set. All the controls were in the small L&R speakers. Don't really want to
    reproduce the tone controls.
    Been looking for a schematic for the ACS340, but nowhere to be found. Would
    like to adapt it as independent sub with my present speakers. Any ideas?
    Regards,
    RichK
    RichK, Jun 10, 2006
    #1
    1. Advertisements
  2. RichK
    Simoc Guest
    Take a signal from them, filter out the higher frequencies, and amplify
    it to suitable for the subW.
    Simoc, Jun 10, 2006
    #2
    1. Advertisements
  3. RichK
    RichK Guest
    "Simoc" <> wrote in message
    Well, the line input is in the subW, from which it normally goes to the L&R
    speakers. The amp is really in the subW, only the controls are normally in
    the L&R speakers (well one of them).
    With a schematic, I might be able to do some surgery :)
    RichK
    RichK, Jun 11, 2006
    #3
  4. RichK
    Simoc Guest
    > speakers.
    Hmm.. you probably mean that signal is normally fed there from L&R
    spkrs?
    Then, I think that u just need to feed line signal to the input :) I
    don't think that you really need any other controls than volume in the
    subw, since it plays only sub-low-range.
    Simoc, Jun 12, 2006
    #4
  5. Simoc wrote:
    > > speakers.
    > spkrs?
    The master volume control is on the right speaker, along with the
    power switch (on the back), a LED power indicator and the bass and
    treble controls. The left speaker is just that, a speaker.
    I have the two small ACS340 speakers, but not the subwoofer if the OP
    needs them.
    I have two other Altec Lansing subwoofer models, but I don't know if
    the small ACS340 speakers can be used with the ACS 295 or ACS 250 sub
    woofers.
    My sig file can beat up your sig file!
    Michael A. Terrell, Jun 13, 2006
    #5
  6. I'd guess these are similar to my ASC 45's and my ACS 45.1's with the input
    on the sub and the volume control on the sattelite speakers, but yours
    having an analog control instead of digital (knob instead of push
    buttons)... I'm not sure how the handled that but the 45's and the 45.1's
    have a simple pinout only using 5 wires. It is a type of din connector that
    looks simiar to a ps-2 mouse or keyboard connector.
    If your connector is a 5 pin connector I believe this should be the proper
    wiring for it.
    2 / * _ * \ 3
    1 \ * |_| * / 4
    \ * / 5
    GND
    pin 1 speaker R
    pin 2 speaker L
    pin 3 speaker DOWN volume bottom
    pin 4 speaker UP volume bottom
    pin 5 LED Green
    - Mike
    news:...
    >> L&R
    >> speakers.
    > spkrs?
    Michael Kennedy, Jun 13, 2006
    #6
  7. RichK
    RichK Guest
    Hi Mike,
    Thanks for posting the pinouts for the 45's. The ACS340 has a 9-pin
    connector. Functions include on-off, vol, base, trbl, LED.
    I was able to find the schematic of the power amp chip, but not for the
    whole system. Altec Lansing does not provide it.
    Having a pintout for ACS340, such as you have given would allow me to
    "hardwire" the bas/trbl to a fixed value add a switch for power (maybe pot
    for vol)
    Regards,
    RichK
    ----- Original Message -----
    Newsgroups: sci.electronics.repair
    Sent: Monday, June 12, 2006 10:07 PM
    Subject: Re: Adding subwoofer to desktop ACS340
    input
    that
    > wiring for it.
    > 2 / * _ * \ 3
    > 1 \ * |_| * / 4
    > \ * / 5
    > GND
    > pin 1 speaker R
    > pin 2 speaker L
    > pin 5 LED Green
    > - Mike
    RichK, Jun 13, 2006
    #7
  8. RichK
    RichK Guest
    "Michael A. Terrell" <> wrote in message
    > needs them.
    E-mailed you direct, but no answer so far. You have a block on your
    Earthlink address.
    RichK
    RichK, Jun 15, 2006
    #8
    > > needs them.
    > Earthlink address.
    > RichK
    I allowed it through, but I can't read it on this computer. I check
    the suspect folder every day, but i have a different account set up on
    this computer. I'll reply tommorow morning.
    Michael A. Terrell, Jun 16, 2006
    #9
    1. Advertisements
Similar Threads
  1. Dubs
    16
    703
    Rich Grise
    Sep 2, 2004
  2. FS or Trade: Schroff Desktop Rack Cabinet
    , Feb 27, 2005, in forum: Electronic Components
    524
  3. Don Lancaster
    Need XC377B/365 video desktop camera pinouts
    Don Lancaster, Apr 13, 2004, in forum: Electronic Design
    370
    Don Lancaster
    Apr 13, 2004
  4. Dubs
    10
    1,291
    Paul Burridge
    Aug 30, 2004
  5. mac-g3
    Need Altec Lansing ACS340 power supply help
    mac-g3, Aug 3, 2008, in forum: Electronic Repair
    2,663
    mac-g3
    Aug 3, 2008
Loading...
