Adding a *rechargeable* battery backup to a small device
Discussion in 'Electronic Design' started by nickjohnson, Dec 20, 2006.
  1. nickjohnson
    nickjohnson Guest
    Hello,
    Imagine you have a small device which is normally plugged into a wall,
    such as an alarm clock. You want to put a battery back-up into it, so
    if the wall power should ever fail (unplugged, outtage, etc), your
    device still functions. But, at the same time, you want the battery to
    be rechargeable. Ideally, the device will recharge the battery while
    plugged in, but switch to battery power when necessary.
    So, I don't know too much about how a battery charger works, but here's
    what I was thinking:
    Wall power leads into a typical power supply, yielding 9Vdc. Those
    9Vdc supply a battery charger which is always charging a rechargeable
    9V. The terminals of the 9V go through a 5V regulator to power the
    rest of the circuit. There is no direct route from the 9Vdc power
    supply and the 5V regulator.
    Does this sound like it would work?
    Is there a more common-practice topology for this sort of design?
    Anyone have links on how to design a battery charger?
    Nick
    #1
    1. Advertisements
  2. nickjohnson
    GregS Guest
    In article <>, "nickjohnson" <> wrote:
    >Hello,
    >Thanks,
    >Nick
    I bought my Sony clock many years ago because having a rechargable is the only
    way to go. Changing 9 volt batteries is not what I do. Imagine what that costs
    after 20 years.
    There are various voltages from 9 volt cells, depending on the number of cells
    used. That critical if driving signifant current into the cell.
    Sounds like that 5 volt thing would work, but is 5 volts really used
    typically?
    greg
    GregS, Dec 20, 2006
    #2
    1. Advertisements
  3. nickjohnson
    Rich Grise Guest
    Design a trickle charger for the optimum trickle charge voltage
    for your battery plus .7V. Connect it to the battery via a
    1N4004 diode, and run your circuit off the battery.
    Good Luck!
    Rich
    Rich Grise, Dec 20, 2006
    #3
  4. nickjohnson
    nickjohnson Guest
    Thanks Rich, this is exactly what I was looking for.
    Why the diode -- just to make sure the charger doesn't draw current
    from the battery?
    #4
  5. nickjohnson
    Tam/WB2TT Guest
    "nickjohnson" <> wrote in message
    news:...
    > Hello,
    > Thanks,
    > Nick
    You mention clock. Most clocks run off the AC line frequency; so, you need
    to supply timing to the circuit when the AC goes off. Most commercial
    digital clocks with battery backup use an RC oscillator to generate 60 (or
    50 ) Hz. These are typically set up to gain about 10 minutes/hour.
    Years ago I built a digital clock that ran off 11V, with a 9V backup battery
    The display ran off the 11V, the clock chip off a diode matrix that would
    use whichever voltage was higher. I included a crystal oscillator and
    countdown circuit to generate the line frequency.
    In the past, PCs used 5V with a 4.5V battery. Crystal was 32.768 KHz, which
    got counted down to 1 Hz.
    Tam
    Tam/WB2TT, Dec 20, 2006
    #5
  6. nickjohnson
    nickjohnson Guest
    This is interesting; I would have just expected them to use a crystal.
    Do they do this to reduce product cost, or is the AC line a better
    clock than a crystal?
    #6
  7. nickjohnson
    Rich Grise Guest
    > from the battery?
    Yup.
    (BTW, we bottom post here)
    Cheers!
    RIch
    #7
  8. nickjohnson
    Tam/WB2TT Guest
    news:...
    >> need
    >> (or
    AC line is a better clock than a cheap crystal. Power stations vary the
    frequency slightly to keep clocks accurate. Of course, that only works so
    long as you don't have a power outage.
    Tam
    #8
    1. Advertisements
Similar Threads
  1. KellyClarksonTV
    What makes non-rechargeable batteries non-rechargeable?
    KellyClarksonTV, Jul 8, 2004, in forum: General Electronics
    787
    Jerry Greenberg
    Jul 9, 2004
  2. mook Johnson
    Adding 2nd dc power input for a battery powered device.
    mook Johnson, Aug 7, 2006, in forum: Electronic Design
    3
    466
    Joerg
    Aug 8, 2006
  3. Replies:
    4
    1,059
  4. Replies:
    14
    930
  5. JonathanAnon
    Charging a rechargeable battery from another DC battery source..
    JonathanAnon, May 2, 2012, in forum: General Electronics Chat
    4
    666
    JonathanAnon
    May 3, 2012
Loading...
