AC relay chatter
Discussion in 'Circuit Help' started by Michael H, Sep 7, 2012.
  1. Michael H
    Michael H
    Sep 7, 2012
    Hello all,
    I have a pump control circuit that is causing relay chatter. It appears that R2 is getting enough current from the SSR timer to cause R2 to chatter. The circuit functions properly when the float F2 is in the high position, but when it's in the low position and F1 is made, that's when it chatters and actually causes the processing pump to pulsate. The reason for R2, is to control a solenoid valve to the open state, but only after the SSR timer times out.
    Any help is greatly appreciated.
    Circuit drawing attached
    Michael
    #1
    1. Advertisements
  2. Michael H
    shrtrnd VIP Member
    Jan 15, 2010
    2,889
    274
    Arizona
    I use a varistor across the relay input power circuit. A lot of people on this forum prefer
    using diodes.
    Google the problem and determine what you want to do.
    I've heard others complain that varistors (which electrically are back to back diodes)
    don't have the life expectancy of diodes, but I rarely experience problems. I suspect
    that they might be underrating them when they chose them for the application.
    It is important to remember that varistors are intended to limit voltage spikes in the
    relay coil back emf. Check the data sheets and design for peak voltage spikes,
    not RMS.
    That's my opinion, I expect you'll receive others. Good luck.
    shrtrnd, Sep 9, 2012
    #2
    1. Advertisements
Similar Threads
  1. .
    Relay chatter & voltage threshold
    ., Aug 28, 2003, in forum: Electronic Design
    4
    2,990
    Spehro Pefhany
    Sep 1, 2003
  2. Blippo
    Eliminate thermostat contact chatter
    Blippo, Dec 2, 2003, in forum: Electronic Repair
    7
    1,357
    Isaac Wingfield
    Dec 4, 2003
  3. thorntonforce
    Relay chatter problem
    thorntonforce, Apr 5, 2012, in forum: Electronic Projects
    3
    808
    thorntonforce
    Apr 5, 2012
  4. dssteven
    Relay Chatter
    dssteven, Aug 14, 2012, in forum: Electronic Projects
    8
    1,785
    GreenGiant
    Aug 14, 2012
  5. esoundinvestment
    24 volt ac relay chatter in parallel to doorbell
    esoundinvestment, May 13, 2014, in forum: Circuit Help
    5
    898
    shrtrnd
    May 14, 2014
Loading...
