AC or DC Fuse
Discussion in 'General Electronics Chat' started by negash, Mar 18, 2010.
  1. negash
    negash
    Mar 18, 2010
    I like buy a fuse 15A but I don't know type of fuse depend on using ac or dc.
    There is defferenc type of fuse in between ac & dc voltage .Simply I side there is defferent between ac fuse & dc fuse
    #1
    1. Advertisements
  2. (*steve*)
    19,250
    Generally speaking -- for low currents, and moderate voltages -- no.
    If you are replacing a blown fuse, then getting one that has the same physical package and rating will be OK.
    If you were designing a circuit, then you would have to look at the ratings to determine if the type was suitable, but for already manufactured equipment that will not be an issue.
    I just *know* that "somebody" will jump on me for saying what I just said.
    That information is totally wrong if you're talking about 3000A fuses. Here is a discussion of areas where AC and DC fuses are different. Here is a manufacturer of such fuses, with some products that are specially designed for DC.
    And here is a discussion about AC/DC on fuse.tv :)
    (*steve*), Mar 19, 2010
    #2
    1. Advertisements
  3. neon
    neon VIP Member
    Oct 21, 2006
    1,324
    there is a difference in AC and DC fuses besides amps and volts An AC fuses is rated to the average value of .639 of the voltage since it flatuate back and forth. Never the less fuses are there not to protect the circuit in general but to stop fires. A 1 amp fuse can blow at 2 amps they are protection not guaratees. a 500 amp fuse the size of 2 inch may have a silver strip of yes 1/8 inch the rest is sand to colapse and control the ionization flush. even fast fuses are not guaranty of precise 1 amp blow protection.
    neon, Mar 25, 2010
    #3
    1. Advertisements
Similar Threads
  1. Junkmail789
    Fuse and LED design question
    Junkmail789, Oct 8, 2003, in forum: Electronic Basics
    31
    980
    Rich Grise
    Oct 20, 2003
  2. tempus fugit
    fuse with resistor in it?
    tempus fugit, Nov 10, 2003, in forum: Electronic Basics
    24
    3,723
    Ross Mac
    Nov 16, 2003
  3. BrianAlex
    5
    903
    hr(bob) hofmann@att.net
    Jan 6, 2009
  4. GreenTea
    Simple 50mA fuse, but not using a Fuse.
    GreenTea, Sep 1, 2010, in forum: Circuit Help
    24
    2,558
    (*steve*)
    Sep 19, 2010
  5. GeetarGal
    Can I replace a glass fuse with a ceramic fuse?
    GeetarGal, Mar 5, 2014, in forum: Electronics Repair
    4
    2,710
    Arouse1973
    Jun 28, 2015
Loading...
Share This Page
