AC CAPACITOR FOR AC MOTOR CONNECTION
Discussion in 'Electronics Repair' started by BlinkingLeds, Apr 1, 2013.
  1. BlinkingLeds
    BlinkingLeds VIP Member
    Feb 23, 2013
    180
    Greece
    Hi. A friend of mine has an remote controlled garage door. It has a 4 lead 350W AC motor. It has 2 relays to control the rotation direction of the motor
    The wires connections are as follows:
    1. Green/Yellow => Ground
    2. Gray => 240v through a 4a fuse and a transparent control relay
    3. Brown => off position of the white relay which takes power from the transparent
    4. Black => on position of the white relay
    It also has an AC capacitor that supposed to be connected to the motor (parallel or series, i have no idea).
    A few years back the capacitor blew up (he doesn't remember it's capacitance but he thinks it was about 12uf) and my friend replaced it with 16uf (was that a mistake?) it worked ok until yesterday when the capacitor , the 4a fuse and the pcb traces from the relays to the motor connectors blew up. He disconnected the capacitor which was rated for 250v (too little tolerance isn't it?) I bought him a 450v one but now i don't know how to connect it...
    Can you shed some light on this?
    Best regards and thanks in advance!
    #1
    1. Advertisements
  2. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,696
    217
    Arizona
    Manufacturers color-code their own systems.
    What's the make and model of your garage door opener?
    It'll help a lot in identifying the wiring.
    shrtrnd, Apr 1, 2013
    #2
    1. Advertisements
  3. BlinkingLeds
    Feb 23, 2013
    180
    Greece
    I can go and check the motor at my friend's house tomorrow
    if that helps, the board is labeled:
    COMUNE where the gray wire goes
    APRE and CHIUDE where the two other wires go.
    Actually i'm not sure if both brown and black wires connect to the pcb maybe one of them is connected via the capacitor? but it doesn't make sense.
    #3
    1. Advertisements
Similar Threads
  1. boki
    884
  2. David Farber
    Small capacitor across a big capacitor.
    David Farber, Aug 21, 2003, in forum: Electronic Repair
    5
    943
    Sam Lloyd
    Sep 27, 2003
  3. Robowang
    Capacitor Start, Capacitor Run Motor
    Robowang, Oct 15, 2006, in forum: Electronic Repair
    13
    2,543
    Robowang
    Oct 18, 2006
  4. Vincent
    Thermistor in dual speed motor connection
    Vincent, Oct 22, 2003, in forum: Electrical Engineering
    13
    711
    ripper
    Oct 25, 2003
  5. mm
    2,246
Loading...
