AC Adapter -- AAA battery replacement?
Discussion in 'Electronic Basics' started by danr_18@yahoo.com, Jan 4, 2008.
  1. Guest
    I don't know the best place to post this, but is there some way of
    "plugging in" an electronic device which accepts AAA batteries, but
    doesn't have an AC adapter power jack (without opening up /
    soldering)?
    That is, there are AC adapters which have 9V battery plugs, but I've
    never seen anything which fits into AAA (or AA) battery compartments
    (which I don't get, since the batteries are a standard size).
    , Jan 4, 2008
    #1
    1. Advertisements
  2. HC
    HC Guest
    > soldering)?
    > Thanks
    Hey, Danr, what I've done in the past is just find the right power
    supply for the device and then "southern-engineer" an adapter. I've
    done an old "boom box" in the '80's when they were called that. It
    required 8 D-cell batteries which is 1.5 volts x 8 = 12 volts and
    since I wanted to run it in the car (I was a kid and I wanted to
    listen to my stuff while my parents drove Florida) I cut a wood dowel
    rod and ran one wire to a screw at the end of one rod and one wire to
    a screw at the end of the the other rod. Then I cut the two dowel
    rods (so they would fit in sorta like batteries (one goes in and hits
    the positive lead, one goes in an compresses the spring at the
    negative end), and put them in (each dowel rod was roughly the length
    of four D-cell batteries) cut in half to make four pieces of wood, two
    with screws in the end with wires attached, so the rods filled in the
    space of the batteries. Then I ran the wires to a cig lighter
    adapter. Done!
    Much more recently I did a similar mod for a Creative Labs Zen Nano
    Plus 1 GB. It runs on one 1.5 volt AAA battery but I was using it in
    my shop to provide audio source to my big stereo out there. I hated
    having to feed it AAA batteries so frequently and I had a surplus of
    D-cell batteries so a mod was in order. I took a Bic Round Stic pen
    (I love those pens, it was a sacrifice) and cut it down to length to
    fit in the AAA socket/pocket of the Zen. I then put some phone wire
    (solid core, thin (maybe 24 ga?)) wire between then tip and the butt
    and ran them to a D-cell battery. It worked. The pen held the wires
    against the contacts and viola! Power! The D-cell ran for weeks at
    my usage rates instead of days.
    All that said, basically, what you need is a way to "southern-
    engineer" your device. There is not, that I know of, a commercial way
    to connect a power supply into the battery cavity of a device. What
    you can do, though, is simply find the right power supply and then
    find a way to lodge the conductors against the pickups in the device
    (be careful of polarity (make sure you get + to + and - to -). You
    could just try pinching the wires from your alternative source into
    the springs/coils pickups of the device (I did) but it doesn't seem to
    work so well (my attempts SUCKED; kept breaking contact
    intermittently).
    Hope this helps you. When you find a solution that works for you,
    please post back to let us know and help us all.
    --HC
    HC, Jan 4, 2008
    #2
    1. Advertisements
  3. Guest
    > > soldering)?
    > > Thanks
    > adapter. Done!
    > intermittently).
    > --HC
    This is exactly what I did for my sons Sandisk player to use a larger
    longer lasting battery. Cut a 3/8-inch dowel rod to length, apply
    copper foil to both ends and a 4-40 screw to the '+' end. solder
    twisted pair somewhere along the sides and run it to the larger cell
    contained in a belt holder. Worked like a charm and I didn't have to
    buy a gazillion AAA cells! File a small notch into the battery door
    where the wires come out.
    good luck.
    al
    , Jan 4, 2008
    #3
    1. Advertisements
Similar Threads
  1. fuspam
    4
    1,856
    Dimitrij Klingbeil
    Sep 25, 2003
  2. Doug Warner
    Ultra compact AAA battery holders?
    Doug Warner, Feb 18, 2005, in forum: Electronic Design
    537
    Boris Mohar
    Feb 18, 2005
  3. AAA Battery Eliminator
    , Oct 26, 2005, in forum: Electronic Design
    5
    3,546
    Kryten
    Oct 27, 2005
  4. AAA Battery for MP3 Player
    , May 15, 2006, in forum: Misc Electronics
    8
    526
    Boozo
    Jun 19, 2006
  5. Acme
    4
    547
Loading...
