About 2SC2071/2SA939 and 2SB649/2SD669
Discussion in 'Electronic Repair' started by KaLe, Aug 3, 2007.
  1. KaLe
    KaLe Guest
    Please tell me, can I replace 2SC2071/2SA939 with 2SB649/2SD669?
    Those 2SC2071/2SA939 are working as pre-driver transistors in one old
    Sansui stereo receiver, and because I cant find it any more for buy (and
    I have found non-working one 2SC2071 and two 2SA939), I wish to replace
    all 2SC2071/2SA939 with this Hitachi 2SB649/2SD669. Can I do this, but
    the most important to me is keeping original Sansui sound.
    Comments are welcome!
    Regards!
    KaLe, Aug 3, 2007
    #1
    1. Advertisements
  2. David Farber
    David Farber Guest
    "KaLe" <> wrote in message
    news:-com.hr...
    > Regards!
    According to my 1986 Transistor manual these are the ratings.
    2SC2071:
    250V Vcbo
    220V Vceo
    50ma Ic
    1 watt Pc
    Beta 150
    2SD669:
    180V Vcbo
    120V Vceo
    1.5A Ic
    20W* Pc
    Beta 60-320
    2SA939:
    -250V Vcbo
    -220V Vceo
    -50ma Ic
    1W Pc
    Beta 150
    2SB649:
    -180V Vcbo
    -120V Vceo
    -1.5A Ic
    1W Pc
    Beta 60-320
    * I'm not quite sure how the 2SB649 is only rated at 1 watt while the 2SD669
    complement is rated at 20 watts. Also notice that these substitutes have a
    lower breakdown voltage than the originals.
    Good luck.
    David Farber
    David Farber's Service Center
    L.A., CA
    David Farber, Aug 3, 2007
    #2
    1. Advertisements
  3. KaLe
    KaLe Guest
    Dana Fri, 3 Aug 2007 14:33:57 -0700 na news grupi sci.electronics.repair
    osoba pod imenom David Farber je napisala...
    > Good luck.
    Thank you for that information David. About collector power dissipation
    different between 2SB649 and the 2SD669; they are talking about two kind
    of Pc, one is normal Pc and one is Pc with mark * and notice Tc = 25
    degrees C, that Pc with * is 20 W, and Pc without * is 1 W.
    I do not need that high breakdown voltage, 180 Volts is quite enough,
    because they will work as predrivers in audio receiver Sansui G8000.
    But I am wondering about that big difference between collector current,
    2SC2071/2SA939 have only Ic 50mA and 2SB649/2SD669 have 1.5A, how big
    difference?!? Is it really good value, did you checked?
    Regards!
    KaLe, Aug 4, 2007
    #3
  4. Guest
    > > Good luck.
    Tamb=25C vs Tcase = 25C wont explain that much difference. You dont
    use 20w trannies as drivers in a tr amp.
    Also your betas are different, 60 may be not enough.
    > Regards!
    I wouldnt choose a 20w tr as a driver. It may well work tho.
    NT
    , Aug 4, 2007
    #4
  5. KaLe
    KaLe Guest
    Dana Sat, 04 Aug 2007 09:09:42 -0700 na news grupi
    osoba pod imenom je napisala...
    But in datasheet you can read two different values for Pc (collector
    power dissipation). First Pc data is really 1W and second Pc data has
    notice "Value at Tc=25" and that second Pc has 20W.
    No problem about that, beta is for my model with mark "C" from 100 -
    200.
    I wil not use them as drivers, I will use them as pre-drivers instead
    2SA818/2SC1628 or instead 2SA939/2SC2071.
    Please take a look at http://tinyurl.com/2xgp3o and you will see that
    G8000 has as drivers 2SA968/2SC2238.
    Regards!
    KaLe, Aug 5, 2007
    #5
    1. Advertisements
Similar Threads
  1. One Two
    5
    959
    Mark Fergerson
    Dec 27, 2003
  2. Rob
    1,418
  3. martin griffith
    Five and half G's up and three and half G's down
    martin griffith, Oct 22, 2005, in forum: Electronic Design
    626
    Fred Bartoli
    Oct 22, 2005
  4. Mike Noone
    21
    1,003
    joseph2k
    Dec 22, 2006
  5. Charles
    Hammers and guns and Jim and Michael
    Charles, Jan 13, 2013, in forum: Electronic Design
    131
    1,611
Loading...
