4-Bit Divisor Implementation Using Logic Gates
Discussion in 'Electronic Design' started by Junaid Uppal, Oct 25, 2004.
  1. Junaid Uppal
    Junaid Uppal Guest
    Hello Everyone,
    I am currently working on a project to implement 4-bit division using
    logic gates / registers etc ( Basic Level DLD Stuff ). I've been
    searching online / offline for a lot of time now but haven't found
    anything that can help me implement my circuit. Can anyone help me out
    in making this circuit please? some pointers / logic diagrams or
    anything.
    Thanks & Regards
    Junaid Uppal
    #1
    1. Advertisements
  2. Junaid Uppal
    Andrew Holme Guest
    Junaid Uppal wrote:
    > Hello Everyone,
    > anything.
    > Thanks & Regards
    > Junaid Uppal
    Try something like
    http://www.google.com/search?q=division+restoring+quotient+remainder
    This page has some really neat Java applet demos
    http://tima-cmp.imag.fr/~guyot/Cours/Oparithm/english/Divise.htm
    Andrew Holme, Oct 25, 2004
    #2
    1. Advertisements
  3. "Junaid Uppal" <> schreef in bericht
    news:...
    > Hello Everyone,
    > anything.
    > Thanks & Regards
    > Junaid Uppal
    Well,
    Guess you're not supposed to find a divisor but to build one. Besides your
    question is not very clear. A four bit divisor? To carry out a division you
    need a dividend and a divisor to obtain a quotient. Are all of them four
    bits? Then you make a truthtable with the dividend and the divisor on the
    input side and the quotient on the output side. That table will have 2^8
    entries. You can list the logic gate solution directly from that table but I
    guess you're supposed to minimise the circuit by using Karnaugh maps, Quine
    McClusky or some other tool.
    In practice I'd write a little program (quick and dirty in Basic) to
    calculate the required outputs and write them in an EPROM but I guess you're
    not allowed to do it that way. A real modern approach is using programmable
    logic.
    As four bits divisors are not very practicle most of the times and this kind
    of "table lookup" becomes quickly too large for even eight bit numbers, most
    real divisors are made using shift registers and a subtractor. A good
    textbook should treat this stuff. I have a (Dutch) one that has some
    examples. May be you should not stick on the internet only but have a look
    in a (technical) library as well.
    petrus bitbyter
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.778 / Virus Database: 525 - Release Date: 15-10-2004
    petrus bitbyter, Oct 25, 2004
    #3
    >anything.
    Should be plenty on the web for this, I'd imagine. Combinatorial methods would
    use a set of compare and mux stages, one pair of these for each output result
    bit, plus a little more stuff. Sequential methods would use a single
    subtractor, shifter, and a little glue. But the methods are basic stuff. Have
    you looked?
    Jon
    Jonathan Kirwan, Oct 26, 2004
    #4
  5. Junaid Uppal
    Junaid Uppal Guest
    I actually need to implement *any* division algorithm for an input of
    4bit binary numbers and yes i can use shift registers , counters and
    all of them but not eproms and stuff. So do you have any pointer to
    that , i am sorry,i've been trying a lot to look around , figure out
    and implement a circuitory but wasnt successful at all even after
    looking at books!
    Regards
    -uppal
    "petrus bitbyter" <> wrote in message news:<K2efd.84650$>...
    > news:...
    > > Hello Everyone,
    > > anything.
    > > Thanks & Regards
    > > Junaid Uppal
    > Well,
    > logic.
    > petrus bitbyter
    Junaid Uppal, Oct 26, 2004
    #5
  6. Junaid Uppal
    Rich Grise Guest
    > looking at books!
    Well, you can achieve the same effect as an eprom look-up table with
    some logic chips.
    Are you allowed to use diode logic? Tell 'em you're going _really_
    retro - then cheat.
    Unfold a ROM.
    Figuring out how do do this will add much more to your reasoning
    power than having it shown to you.
    There are two, four-bit inputs - how many possible sets of input
    states are there? Could you translate each of these product terms
    to a quotient and remainder with a few gating diodes?
    You _do_ know how to build a diode AND gate, don't you? ;-)
    Have Fun!
    Rich
    Rich Grise, Oct 26, 2004
    #6
    >looking at books!
    Look in "HDL Chip Design," as it includes both combinatorial and sequential
    methods. (and their schematics)
    Jon
    #7
  8. Junaid Uppal
    Andrew Holme Guest
    These circuits generate the answer in 1 clock cycle.
    Alternatively, you could do a sequential divider using registers,
    counters, shift registers e.t.c. This is standard long division, as
    you do it with pencil and paper, but in binary e.g.
    00011
    0100 ) 01100
    0100
    00100
    0100
    You need shift registers, a binary subtractor (or comparator), and
    counters.
    Andrew Holme, Oct 26, 2004
    #8
  9. Junaid Uppal
    Marlboro Guest
    (Junaid Uppal) wrote in message news:<>...
    > Hello Everyone,
    > anything.
    > Thanks & Regards
    > Junaid Uppal
    Sound like school homework,
    Marlboro, Oct 26, 2004
    #9
    I think everyone posting in response realizes this, too, and has been a little
    circumspect about providing a solution, while including some words for a search
    or books for more study.
    Jon
    #10
    1. Advertisements
Similar Threads
  1. Davy
    4
    441
    Fred Bartoli
    Oct 28, 2005
  2. eric
    4 bit divisor with flip-flop ?
    eric, Feb 3, 2004, in forum: Electronic Design
    15
    679
  3. Davy
    4
    679
    Fred Bartoli
    Oct 28, 2005
  4. sjgallagher2
    Need a simple latch circuit using logic gates
    sjgallagher2, Feb 19, 2013, in forum: Electronic Projects
    3
    810
    Harald Kapp
    Feb 19, 2013
  5. mcsoftware
    18
    296
    mcsoftware
    Dec 6, 2015
Loading...
