32-pin PLCC programmer
Discussion in 'Electronic Design' started by Ozz, Oct 9, 2003.
  1. Ozz
    Ozz Guest
    ok guys i need to make a 32-pin PLCC programmer.. is it possible????
    and no i dont want to pay 100 bucks for one because i cheap ;)
    Ozz, Oct 9, 2003
    #1
    1. Advertisements
  2. Ozz
    Bill Sloman Guest
    (Ozz) wrote in message news:<>...
    Replace the PLCC with an ISP part.
    Bill Sloman, Nijmegen
    Bill Sloman, Oct 9, 2003
    #2
    1. Advertisements
  3. >ok guys i need to make a 32-pin PLCC programmer.. is it possible????
    Of course it is possible, especially if you value your time as
    $0.00/hour and are willing to spend $500 in components.
    But PLCC32 is a housing, not a particular chip. So exactly what chip
    do you want to program? Or do you have a DIP programmer and you want
    to make a PLCC adapter?
    Wouter van Ooijen
    http://www.voti.nl
    PICmicro chips, programmers, consulting
    Wouter van Ooijen, Oct 9, 2003
    #3
  4. Ozz
    Ozz Guest
    (Wouter van Ooijen (www.voti.nl)) wrote in message news:<4all.nl>...
    > Wouter van Ooijen
    > http://www.voti.nl
    im looking to program
    Amd
    AM29F040B
    here is a manual i found on it..
    http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/21445.pdf
    oh and the reason i dont want to buy a programmer really is because i
    have no use for it but just to program one chip..
    i was thinking of maybe using a cheaplpc programmer like the ones used
    to program the 32 pin xbox cheap mods but was told by someone it was
    not possible.
    Ozz, Oct 10, 2003
    #4
  5. Ozz
    Gary Tait Guest
    Whereas On 9 Oct 2003 21:54:17 -0700,
    (Ozz) scribbled:
    , I thus relpy:
    >> Wouter van Ooijen
    >> http://www.voti.nl
    >Amd
    >AM29F040B
    >not possible.
    From what it appears, the modchip for the Xbox uses an SST49LF020,
    which has the LPC programmability, while the 29F chip is exclusively
    parallel program, meaning you will have to make an 8 byte read/write
    bus, an up to 19 bit address bus, and the R/W/CE lines for it. Now,
    if you could, you could probably get the LPC version of the 29F040.
    If you are willing to work and/or spend money, you can build a
    programmer.
    Another option, if you are savvy enough, is to use a PC or other user
    upgradeable Flash appliance (Eg DVD player) and hot switch the roms
    at the right point,.
    You could also build an adaptor/ wire a socket to use the JTAG on
    something that uses that (such as a satellite receiver).
    Last resort would be to find a service that programs chips.
    Gary J. Tait . Email is at yahoo.com ; ID:classicsat
    Gary Tait, Oct 10, 2003
    #5
  6. Ozz
    Bubba Jones Guest
    >(Ozz) scribbled:
    >, I thus relpy:
    >>> Wouter van Ooijen
    >>> http://www.voti.nl
    >>Amd
    >>AM29F040B
    >>not possible.
    >programmer.
    You can build a flash programmer for the AM29F040 for about $50 based
    on circuit found at http://www.devrs.com/e/tools.php#toolprgr
    Select the link for "2001/07/09 - Frohwein-Sshua Flash Programmer"
    Modify the circuit for using a PLCC32 vs. DIP socket
    Make sure you use version 1.5 of software if you use 74HC595 chips.
    You may need to change BIOS setting in PC to make parallel port
    functional for use with programmer.
    Bubba
    Bubba Jones, Oct 10, 2003
    #6
  7. Ozz
    Ozz Guest
    Gary Tait <> wrote in message news:<>...
    > (Ozz) scribbled:
    > , I thus relpy:
    > >> Wouter van Ooijen
    > >> http://www.voti.nl
    > >Amd
    > >AM29F040B
    > >not possible.
    > programmer.
    know any good PC programs that i can use to backup and flash a chip?
    Ozz, Oct 11, 2003
    #7
  8. Ozz
    Gary Tait Guest
    Whereas On 10 Oct 2003 17:57:41 -0700,
    (Ozz) scribbled:
    , I thus relpy:
    >> (Ozz) scribbled:
    >> , I thus relpy:
    >> >> Wouter van Ooijen
    >> >> http://www.voti.nl
    >> >Amd
    >> >AM29F040B
    >> >not possible.
    >> programmer.
    Look into the BIOS flash programs for your motherboard manufacturer.
    Personally, I have been backing up roms using the BIOS extension
    socket on an old MFM HDD card, using Debug, or a Qbasic program (dos
    6.22 on a 386 though).
    Gary Tait, Oct 11, 2003
    #8
  9. Ozz
    mike Guest
    >>Wouter van Ooijen
    >>http://www.voti.nl
    > Amd
    > AM29F040B
    > not possible.
    Advertise for help on a local newsgroup.
    Go visit a university electronics lab.
    Ham radio club.
    Beg for help at a local chip distributor.
    You may have to make a PLCC to DIP adapter to use a generic
    programmer. You can buy 'em but you don't want to know what they cost.
    mike
    laptops and parts Test Equipment
    4in/400Wout ham linear amp.
    Honda CB-125S
    400cc Dirt Bike 2003 miles $550
    Police Scanner, Color LCD overhead projector
    Tek 2465 $800, ham radio, 30pS pulser
    mike, Oct 12, 2003
    #9
    1. Advertisements
Similar Threads
  1. Willy Kreim
    Inexpensive PLCC to DIP 32-pin adapter ??
    Willy Kreim, Sep 8, 2003, in forum: Electronic Basics
    683
    Willy Kreim
    Sep 8, 2003
  2. Richard Yan
    7
    1,793
    Leon Heller
    Aug 23, 2004
  3. Replies:
    1,178
  4. joseph
    PLCC 84 pin prototype adapter
    joseph, Jan 12, 2008, in forum: Electronic Design
    4
    1,278
    Tony Burch
    Jan 12, 2008
  5. Aldorus
    PLCC to PLCC thru-hole dip socket
    Aldorus, Mar 18, 2009, in forum: Electronic Design
    6
    973
    Aldorus
    Mar 19, 2009
Loading...
