3 phase power formula
Discussion in 'Electronic Basics' started by erthlink, Feb 25, 2004.
  1. erthlink
    erthlink Guest
    the three phase power formula goes like this:
    V * I * 1.732 * PF
    where V - voltage, I - current, PF - power factor
    a 3 phase generator set to 120/208 V with amperage values of 24A, 26A, 22A
    at each phase.. PF is 0.8
    which V value should i use? do i take the average current (I) or do i add
    them up?
    #1
    1. Advertisements
    > V * I * 1.732 * PF
    > them up?
    If the three currents listed are the 3 line to neutral currents (not
    line to line current) then you just use the single phase formula 3
    times and add the results. 120V*A*PF
    John Popelish
    John Popelish, Feb 25, 2004
    #2
    1. Advertisements
  3. erthlink
    Lord Erdel Guest
    which brings me to another question.. what am i measuring when i use a
    clamp-on ammeter? am i correct in stating this equation then?
    P = V[phase-ground] * ( I[phase1] + I[phase2] + I[phase3]) * PF * 1.732
    assuming i have the same phase voltages across the board of course..
    > John Popelish
    Lord Erdel, Feb 25, 2004
    #3
  4. erthlink
    Don Kelly Guest
    "erthlink" <> wrote in message
    news:DHS_b.20461$...
    > V * I * 1.732 * PF
    > them up?
    If the currents are the same in all 3 phases then use the line to line
    voltage (208V). Otherwise use 120*I*pf 3 times and add them up as John has
    indicated. Actually using 208*1.732*24A*pf will probalby be close enough for
    government work.
    Don Kelly
    remove the urine to answer
    Don Kelly, Feb 25, 2004
    #4
  5. erthlink
    Guest
    | V * I * 1.732 * PF
    | them up?
    Is that 0.8 PF the rating of the generator, or the actual load?
    | Phil Howard KA9WGN | http://linuxhomepage.com/ http://ham.org/ |
    | (first name) at ipal.net | http://phil.ipal.org/ http://ka9wgn.ham.org/ |
    , Feb 25, 2004
    #5
  6. erthlink
    Lord Erdel Guest
    0.8 is my arbitrary value for PF..
    #6
    1. Advertisements
Similar Threads
  1. yakobiana
    Different between 1 phase voltage and 3 phase
    yakobiana, Sep 23, 2003, in forum: Electronic Basics
    5
    1,198
    Baphomet
    Sep 24, 2003
  2. Lord Erdel
    Re: 3 phase power formula
    Lord Erdel, Feb 25, 2004, in forum: Electronic Basics
    1,840
    John Popelish
    Feb 25, 2004
  3. Takoma Park Volunteer Fire Department Postmaster
    Formula 3 phase amps from watts
    Takoma Park Volunteer Fire Department Postmaster, Jan 23, 2004, in forum: Electrical Engineering
    9
    1,583
    Operator Jay
    Jan 29, 2004
  4. Kissi Asiedu
    1 Phase or 3 Phase Power
    Kissi Asiedu, Oct 8, 2005, in forum: Electrical Engineering
    686
    Don Kelly
    Oct 10, 2005
  5. bobdxcool
    544
    ramussons
    Jun 17, 2014
Loading...
