25A 14V DC regulator
Discussion in 'Electronic Components' started by leppert@insight.rr.com, Jul 22, 2006.
  1. Guest
    Anyone have any ideas on a ready made DC/DC regulator that can take
    input voltages from around 10 volts to 14V and output a consistent
    14VDC (or adjustable in that range) at 25A or more? I'm not totally
    against building my own, so a component recommendation would be helpful
    also; however I would prefer a ready made solution. So far I've easily
    found some solutions but they are only good to around 3A or 5A, etc.
    Jonathan
    , Jul 22, 2006
    #1
    1. Advertisements
  2. PeteS
    PeteS Guest
    > Thanks,
    > Jonathan
    Will the output always be above the input or not?
    If it will, then you need a straight (adjustable) boost converter
    although not all converters can do Vout = Vin. You'll need to be
    careful about dropout. There are some adjustable OTS converters
    available in this range. Try this search for a decent outline
    'dc dc modules' at google.
    If the output will vary both above and below the input, then you would
    need to use perhaps a SEPIC [single-ended primary inductance converter]
    style device. There are a number of solutions in this area. National,
    TI, Maxim and Linear tech all make controllers designed for this type
    of application.
    If you need a converter that can go above and below the input, it's
    possible but unlikely you'll find a premade module.
    Cheers
    PeteS
    PeteS, Jul 23, 2006
    #2
    1. Advertisements
Similar Threads
  1. Hadry LittleWood
    changing my VMeter from 0.25A to 25A
    Hadry LittleWood, Sep 8, 2004, in forum: Electronic Basics
    5
    455
    R. Steve Walz
    Sep 9, 2004
  2. P Boy
    Looking for SRD210\14V\V4
    P Boy, Mar 6, 2006, in forum: Electronic Components
    424
  3. Ducky_Doug
    NEED VOLTAGE REGULATOR 14V 40 AMPS
    Ducky_Doug, Dec 20, 2004, in forum: Electronic Design
    9
    1,895
    Tony Williams
    Dec 24, 2004
  4. Hadry LittleWood
    Hadry LittleWood, Sep 8, 2004, in forum: Misc Electronics
    391
    R. Steve Walz
    Sep 9, 2004
  5. beanman
    14v 62A variable current circuit help!
    beanman, May 23, 2012, in forum: Electronic Projects
    7
    546
    beanman
    May 23, 2012
Loading...
Share This Page
