24vdc to 12vdc
Discussion in 'Electronic Basics' started by Chris Serra, Aug 2, 2003.
  1. Chris Serra
    Chris Serra Guest
    Hi all. I have a pretty simple question. I am looking at reducing 24vdc to
    12vdc. I am new to making circuits, but I fix video games for a living, so
    I know my way around most pcb's. I am not sure the best way to do it, using
    resistor, caps, or if a simple 7812 will do the trick. I am not looking for
    someone to make the circuit for me, but just nudge me in the right
    direction.
    Thanks alot.
    Chris Serra
    #1
    1. Advertisements
  2. Chris Serra
    tempus fugit Guest
    7812
    "Chris Serra" <> wrote in message
    news:...
    to
    so
    using
    for
    > direction.
    > Thanks alot.
    > Chris Serra
    tempus fugit, Aug 2, 2003
    #2
    1. Advertisements
  3. A couple of 5w 10 ohm resistors and a unijunction transistor would be more
    of a challenge with a 10 ohm pot off the collector of the unijunction
    transistor. (assuming the 24vdc potential has less than 503 ma of current
    and ignoring the 12v zener hanging off the emitter going to "ground" the
    negative pole) But then, I digress...
    "tempus fugit" <> wrote in message
    news:QuGWa.10447$...
    > 7812
    > news:...
    24vdc to 12vdc
    William Hayes, Aug 2, 2003
    #3
  4. Chris Serra
    Blake Guest
    > to
    > so
    There are two options - a linear or a switcher. A linear (7812-type)
    solution will dissipate power equivalent to 12V (the amount dropped) times
    the current your load will draw. With a big heatsink, you can drop a lot
    of power. You will have to do the math to be sure that the 7812 will not
    get too hot.
    A switcher will dissipate a lot less heat, maybe 5-30% the heat of the
    linear. There are some small switchers that you can drop in that are easy
    to design because the datasheet spells out what to do. But a divide-by-two
    switcher can be as easy as a 50% duty-cycle switch followed by an LC
    circuit.
    Blake
    Drop pants to reply by email
    Blake, Aug 2, 2003
    #4
  5. Chris Serra
    Leigh W3NLB Guest
    On Fri, 1 Aug 2003 23:41:47 -0400, "Chris Serra" <>
    >direction.
    >Thanks alot.
    >Chris Serra
    We need to know the current drain: minimum, average and maximum, if
    it varies. Can't design a regulator until we know that information.
    73 de Leigh W3NLB
    Leigh W3NLB, Aug 2, 2003
    #5
  6. Chris Serra
    Brian Lund Guest
    to
    so
    using
    for
    > direction.
    It depends on how much current you need, the 7812 is often a good choice,
    but for circuits requiring a lot of current you need something else. You can
    get the as 7812 as a low power model, it is called 78L12 and can maximally
    deliver 100 mA.
    http://www.el-supply.dk/elpix/7B.GIF
    The regular (TO220) can deliver 1-1.5A depending on the manufacturer.
    http://www.el-supply.dk/elpix/17B.GIF
    And for high-power requirements there is a 3A model in a TO3 package.
    http://www.el-supply.dk/elpix/23A.GIF
    Always remember to use a heatsink for the later two models as they do get
    pretty hot when they have enough load.
    Brian Lund
    Brian Lund, Aug 5, 2003
    #6
    1. Advertisements
Similar Threads
  1. 24vdc to 12vdc for remote deployment
    , Jan 24, 2005, in forum: Electronic Basics
    6
    816
    cabsandy
    Jan 24, 2005
  2. cabsandy
    Help needed with 24vdc to 12vdc
    cabsandy, Jul 21, 2007, in forum: Electronic Basics
    7
    996
    ehsjr
    Jul 22, 2007
  3. Chris Serra
    24vdc to 12vdc
    Chris Serra, Aug 2, 2003, in forum: Beginner Electronics
    4
    3,388
    Brian Lund
    Aug 5, 2003
  4. Joe G \(Home\)
    CCt to converter 24Vdc signals to 12Vdc signals
    Joe G \(Home\), Jun 8, 2010, in forum: Electronic Design
    852
    Grant
    Jun 8, 2010
  5. CalvinBB
    Convert 24VDC@250mA -> 12VDC@500mA
    CalvinBB, Aug 6, 2010, in forum: Circuit Help
    11
    2,967
    CalvinBB
    Aug 7, 2010
Loading...
