110V to 100V
Discussion in 'Misc Electronics' started by atasaka, Sep 5, 2003.
  1. atasaka
    atasaka Guest
    I made the mistake of bringing a fuzzy logic rice cooker back with me from
    Japan and thought I could use a converter I already had at home but when I
    looked at the specs on the cooker, it says 100V, 1100W, 20A. My converter
    is rated for under 100W. So I found someone selling a 110V to 100V step
    down transformer at 1500VA and 15A max. Is 1500VA the same as 1500W?
    Will the 5A make any difference? I'm pretty clueless when it comes to
    this stuff but want to make sure I don't do anything that will damage the
    cooker since its electronics are quite complex as far as rice cookers go.
    The seller is not a dealer so he is not sure either. Any help would be
    appreciated. Thanks!
    #1
    1. Advertisements
  2. atasaka
    DarkMatter Guest
    On Fri, 5 Sep 2003 01:58:14 -1000, atasaka <> Gave
    us:
    100V at 20A is 2kW. A single 120 volt line at 15 amps is only 1.8kW
    I'd find out what the thing really uses. Also, are you sure that
    your mains are at 110V? A 110 to 100 step down xfmr is only a 120 to
    109V conversion. The heating element in the cooker wouldn't mind so
    much, but the front end supply and control electronics for it may.
    Anyway, their 1100W claim doesn't jibe with their claim of a 20 Amp
    draw. One or the other is not correct. Either the unit only draws 1.1
    amps, or somebody doesn't know how to do the math in that japanese
    rice cooker factory. Maybe he was using fuzzy logic too! :]
    DarkMatter, Sep 5, 2003
    #2
    1. Advertisements
  3. atasaka
    Mjolinor Guest
    "Richard Crowley" <> wrote in message
    news:...
    > "atasaka" <> wrote in message
    > news:pine.GSO.4.56.0309050147270.4020@uhunix2...
    from
    I
    converter
    the
    go.
    > "VA" is the acronym for "volt-amps" and is generally equivalent
    > to "W" (watts). Calculated by multiplying the volts and amps.
    > I would just try the 1500VA transformer and monitor it to see if
    > it overheats in use.
    > The numbers "100V, 1100W, 20A" don't really compute.
    > I believe the 100V because that is the domestic standard
    > in Japan. And the 1100W *sounds* reasonable. But 1100W
    > at 100V is only 11A (1100W divided by 100V). Dunno where
    > the "20A" comes from. Maybe it is an indication that they
    > recommend using it on a dedicated 20A branch circuit.
    > Taking them at their word (at least the parts we choose to
    > believe :), it may draw only 11A in which case, the 15A
    > transformer would be adequate.
    AFAIK the tolerance of the power supply voltage SHOULD mean that it will
    work OK off 110. If it were mine I would certainly try it, maybe through a
    variac slowly if ti were very expensive but i am pretty certain it would be
    OK.
    That should get me a flaming :)
    Mjolinor, Sep 5, 2003
    #3
  4. atasaka
    Zak Guest
    It shouldn't be an expensive transformer by the way. You could use a 110
    to 10 volt transformer of 150 (or 200) VA.
    The tricK: the primary is wired to your 110 volts. The secondary is put
    in series with your 110 volts, so that it subtracts (measure this...).
    The transformer is asked to deliver 15 (or 20) amps at 10 volts. That's
    a 150 to 200 watt transformer.
    Thomas
    Zak, Sep 5, 2003
    #4
  5. atasaka
    atasaka Guest
    After reading your post, I looked at the rice cooker again and next to the
    20A in katakana characters, I think it reads "fuse" but I'm not too sure.
    Could this mean the rice cooker has a fuse built in that can handle up to
    20A? Thanks for everyone's help.
    atasaka, Sep 6, 2003
    #5
  6. atasaka
    Jerry G. Guest
    Your rice cooker will pull 11 Amps at 100 V and if you run it on 120 V
    it will pull about 13 amps. The reason for the 20 Amps being indicated,
    is that in Japan, the standard panel breaker for home kitchen appliance
    use is 20 Amps. Here in North America the standard is 15 Amps. As for
    the transformer, you should be okay with the 1500 VA unit.
    The cooker would probably work on 120 V, but it will be a bit hard on
    it. I would prefer to use the proper rated voltage. From 100 to 120 V
    there is a 20% difference. This is a lot for continuous use. Running
    the cooker on a higher voltage may definitely lower the life span of the
    unit.
    I am curious to know the company that made your rice cooker. Before
    Sony got in to the TV and electronics business, they were a rice cooker
    and small appliance manufacture. Infact, they were one of the best made.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Instruments http://www.zoom-one.com/glgtech.htm
    from
    I
    converter
    the
    go.
    Jerry G., Sep 6, 2003
    #6
  7. atasaka
    Mjolinor Guest
    "Jerry G." <> wrote in message
    news:bjbl7e$a7p$...
    > unit.
    I thouhght the original post said he wanted to run it from 110 volts but I
    can't find it to check?
    Mjolinor, Sep 6, 2003
    #7
  8. atasaka
    Mjolinor Guest
    news:...
    > "Mjolinor" wrote ...
    > > 110 volts but I can't find it to check?
    > Domestic power in North America is variously referred to as:
    > 110, 115, 117, 120 V. Likely varies even wider than that.
    > Don't try to calibrate your voltmeter from the power line!
    I must have missed the bit where he said he was in North America as well.
    #8
  9. atasaka
    Steven Guest
    > us:
    >> me from Japan and thought I could use a converter I already had at
    >> home but when I looked at the specs on the cooker, it says 100V,
    >> 1100W, 20A. My converter is rated for under 100W. So I found
    >> someone selling a 110V to 100V step down transformer at 1500VA and
    >> 15A max. Is 1500VA the same as 1500W? Will the 5A make any
    >> difference? I'm pretty clueless when it comes to this stuff but
    >> want to make sure I don't do anything that will damage the cooker
    >> be appreciated. Thanks!
    brrr. Wrong answer.
    100V at 20A is 2kVA and has to be multiplied with cos(phi) to get real power
    (in W or kW).
    For resistive loads cos(phi) = 1, so then -- and only the! -- the 2kVA =
    2kW.
    If cos(phi) = 0 (pure inductive or capacitive loads) the 2kVA = 0W. Nothing,
    zilch, nada
    Steven, Sep 6, 2003
    #9
  10. atasaka
    DarkMatter Guest
    On Sat, 06 Sep 2003 18:25:43 GMT, "Steven" <>
    Gave us:
    >> us:
    >brrr. Wrong answer.
    >(in W or kW).
    >2kW.
    >zilch, nada
    It is a purely resistive load, dipshit.
    DarkMatter, Sep 6, 2003
    #10
  11. "Steven" <> wrote in message news:<HEp6b.5261$-ops.be>...
    > > us:
    > brrr. Wrong answer.
    > (in W or kW).
    > 2kW.
    > zilch, nada
    Given that rice cookers today are pretty inexpensive, and power
    converters are not, I tend to believe that this guy would be well
    advised to simply purchase a new rice cooker!
    Harry C.
    Harry Conover, Sep 7, 2003
    #11
    Maybe it uses a 100VAC 20 amp heating element with a TRIAC in series,
    which never allows the full continuous 20 amps thru. I.e. it's really a
    PWM controlled heater. And it might actually draw 20A peak for
    fractions of a second.
    Lizard Blizzard, Sep 9, 2003
    #12
  13. Harry Conover wrote:
    [snip]
    > Harry C.
    Another thought. Advertise that you have a rice cooker that you brought
    from Japan recently and you're looking to trade for a U.S. one for
    someone who is going to Japan. Equivalent make, model, capacity, etc..
    #13
    1. Advertisements
Similar Threads
  1. Franks
    840
    Franks
    Oct 16, 2004
  2. TJ Hertz
    100V appliance on 110v power supply
    TJ Hertz, May 31, 2005, in forum: Beginner Electronics
    13
    1,394
    Rich Grise
    Jun 3, 2005
  3. TJ Hertz
    17
    807
    Scott Dorsey
    Jun 3, 2005
  4. TJ Hertz
    TJ Hertz, May 31, 2005, in forum: Electrical Engineering
    15
    1,961
    Rich Grise
    Jun 3, 2005
  5. TJ Hertz
    Electric shocks (was: 100V appliance on 110v power supply)
    23
    978
    Roy Q.T.
    Jun 4, 2005
Loading...
