110V timer
Discussion in 'Electronic Design' started by Rob, May 27, 2007.
  1. Rob
    Rob Guest
    I bought a 110v rotary timer and wired it to an outlet. Now I can turn the
    dial and it will turn off the outlet in 60 minutes.
    The timer cost $21, that seems pretty high. I have seen cheap timer IC, but
    they take low voltage. Does anyone know where I could buy the necesarry
    parts to do the same thing for a lot less. I need to make quite a few of
    these.
    Rob
    Rob, May 27, 2007
    #1
    1. Advertisements
  2. Rob
    D from BC Guest
    >these.
    >Thanks,
    >Rob
    Just AC off in 60 minutes...??
    I'll guess..
    Triac + RC cct..
    D from BC
    D from BC, May 27, 2007
    #2
    1. Advertisements
  3. Rob
    Jasen Guest
    > these.
    that price is high, I bet you can get 24 hour outlet timers for automatic
    start/stop of appliances for less than $5, (I've seen them for NZ$8)
    possibly the easiest way to build your 60 minute timers may be to grab a
    bunch of those (as they already have the switch etc... in them) and modify them.
    Bye.
    Jasen
    Jasen, May 27, 2007
    #3
  4. "Jasen" <> wrote in message
    news:f3ba82$ii2$-a-geek.org...
    >> the
    >> but
    >> of
    >> these.
    > modify them.
    Such timers are often available surplus at places like www.mpja.com,
    www.herbach.com, or AllElectronics. They are also found in older and
    cheaper microwave ovens, so you could go to a dump and scrounge a bunch for
    free.
    If you are building them for your own use, you can get by with a solid
    state relay, driven by a simple circuit (a PIC would be my choice), but you
    can do it with a 555 timer, maybe with a large RC, but even better with a
    counter. You can use a wallwort for power.
    If you intend to sell them, you probably will need to build them per UL
    standards and have them tested.
    Paul
    Paul E. Schoen, May 27, 2007
    #4
  5. Rob
    Gary Tait Guest
    "Rob" <r> wrote in news:4658e6c9$0$3183$:
    > turn the dial and it will turn off the outlet in 60 minutes.
    > IC, but they take low voltage. Does anyone know where I could buy the
    > necesarry parts to do the same thing for a lot less. I need to make
    > quite a few of these.
    > Thanks,
    > Rob
    You will need to get them approved, likely, depending on your situation.
    Gary Tait, May 29, 2007
    #5
    1. Advertisements
Similar Threads
  1. Mr. J D
    8
    4,996
    jasen
    Aug 17, 2006
  2. Roy
    110V Timer Switch
    Roy, Oct 30, 2003, in forum: Electronic Design
    12
    1,184
  3. Replies:
    5
    1,698
    Matt M.
    Apr 1, 2007
  4. Franks
    860
    Franks
    Oct 16, 2004
  5. elshorbagy01
    convert 110v dc to 110v Ac
    elshorbagy01, Apr 13, 2016, in forum: General Electronics Chat
    3
    200
    Gryd3
    Apr 13, 2016
Loading...
