Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Switched capacitors
Reply
Thread Tools Display Modes
Switched capacitors
Robert Swinney
Guest
Posts: n/a
      08-13-2005, 11:47 AM
One of the commercial rotary phase converters uses "capacitor switching" for
variable load adjustment. Apparently, varying amounts of capacitance are
switched in/out to adjust voltage balance to accommodate load changes.
Switching is said to be done at "zero crossing", and the devices are said to
be CMOS. Can someone comment on what type of devices may be used.
Bob Swinney
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
difference in parameters when circuit switched on and when switched off krishna42099 Circuit Help 4 10-02-2012 09:13 AM
Re: is it possible to replace a 10 % Capacitors in place of 5% capacitors in Power Supply Bypass circuits Paul Keinanen Electronic Design 1 08-27-2009 08:45 PM
Re: is it possible to replace a 10 % Capacitors in place of 5% capacitors in Power Supply Bypass circuits David L. Jones Electronic Design 0 08-27-2009 06:30 AM
Switched-capacitor or switched-current? Luo XiaoZen Electronic Design 18 11-12-2005 01:23 AM
what's the different between switched capacitor and switched opamp technique? Boki Electronic Design 1 07-30-2003 06:29 AM
