Electronics Forums
Electronics Forums > Newsgroups > Energy Generation > Photovoltaics > suggestions for garage door?
Reply
Thread Tools Display Modes
danny burstein
Guest
Posts: n/a
      10-27-2009, 05:14 AM
I've got a neighbor, kind of.., who has a car garage with an
overhead door. No electric lines to it, so the door has to
be lifted manually.
Even with decent springs and counterweighting it's a big pain.
Running electricity to it would be a big pain and expense, so I
was thinking of a solar solution.
I've measured my own garage which does have an electric opener.
There's a steady background draw of 3 watts for the controls
and the safety "electric eye" at the door bottom. When the motor
is running it pulls about 600 watts for the 10 second cycle.
So I figure... if we take a reasonable worst case scenario
it'll get run through 5 cycles/day.
Power usage:
a: 3 watts times 24 hours => 0.072 kw-hr/day
b: 600 watts times (10*2*5) = 60 kw-sec /day
-> => 0.041 kw-hr/day
total: 0.11 kw-hr/day (110 watt-hr)
So far so good. If my math is right... then a 35 watt panel,
which back of envelope would get me 140 watt-hr/day (based
on getting the equiv. of 4 hours of direct sunlight), so I'd
have a bit to spare for inefficiencies and to keep the battery
charged on cloudy days or if the door gets used more.
(And if I can kill off the standby draw, even better).
The big problem is that overhead motor pulls that 600 watts,
with probably two or three times that at start up. Which
means using a big inverter...
But given the cost of running an electric line, this still
looks like a decent alternative.
Before I pull my hair out on this, has anyone had experience
and could offer a suggestion or two?
The biggest question, I guess, would be finding a DC motor
that would be usable in a garage lift assembly... The big
advantage is it would eliminate the need for the inverter.
Thanks.
__________________________________________________ ___
Knowledge may be power, but communications is the key
(E-Mail Removed)
[to foil spammers, my address has been double rot-13 encoded]
Ecnerwal
Guest
Posts: n/a
      10-27-2009, 01:04 PM
In article <hc634q$e24$(E-Mail Removed)>,
> be lifted manually.
....Then it's not set up right. Get a competent tech to set it up (or
replace it with something that has proper running gear.) I have a 10x10
foot 2 inch thick insulated door (a hefty item), and it's trivial to
pull up and down manually - which I've been doing for 5-1/2 years
without even needing adjustments since the initial setup.
Cats, coffee, chocolate...vices to live by
AES
Guest
Posts: n/a
      10-27-2009, 02:03 PM
I knew a semi-crazy handyman once who had cobbled together a garage door
counterweighted by a coupled of big rectangular buckets or water tanks
hung on a cable and pulley setup. When door was down and latched,
buckets were up, and a water pipe and valve arrangement filled 'em with
water. Release latch, buckets came down, door went up. When door
reached the up and latched position, buckets came to rest on a pad with
a upright bar that pushed open a spring-loaded valve in the bottom of
the bucket.; water went to a nearby flower bed.
Now all you need is enough power to automate this (and drive a small
pump, if you haven't got ordinary residential water pressure).
danny burstein
Guest
Posts: n/a
      10-27-2009, 07:43 PM
In <(E-Mail Removed)> T. Keating <(E-Mail Removed)> writes:
>Purchase a garage door opener with a battery backup and just power via
>a much larger +12 volt battery charged via a small solar panel..
>http://www.sears.com/shc/s/p_10153_12605_00953918000P
That's *exactly* perfect for my needs. Thanks.
(E-Mail Removed)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fast door heater for a frozen auto door phaeton Electronic Basics 5 11-24-2005 12:05 AM
Looking for advice/instruction for building garage door closer project mjohnson Electronic Basics 5 04-12-2005 04:44 PM
Normally closed contact switch and Garage door Moloney Electronic Basics 6 01-14-2004 11:51 PM
Door bell problem Brent Electronic Basics 6 01-05-2004 05:16 PM
Re: Mounting a magnetic door switch on Aluminum. Dr. Anton Squeegee Electronic Basics 0 08-10-2003 11:04 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
