Electronics Forums
Electronics Forums > Members Area > For Sale / Wanted > Wanted: Stepper motor
Closed Thread
Thread Tools Display Modes
Junior Member
      05-10-2011, 05:38 PM
Hi!
I'm looking for a mitsumi m35sp-9t Stepping Motor for use in an HP M2727 MFP printer. The apparently come in several flavors: I need a 10 OHM, with a 5-pin connector, not the ribbon cable version. If anyone can help I'd be very grateful. These things are incredibly un-findable. I can be reached at (E-Mail Removed).
Mike
Junior Member
      01-15-2012, 02:04 AM
Is this the scanner motor? If so it has a high failure rate. Look for Q3984-60186-B. This is unconfirmed data I received from someone else. After you replace it you may have to swap out the formatter also. Motors I have seen were frozen solid had to use a vice grip on em to even get them to move. They may have sat too long in a dock and may have gotten damp.
Senior Member
      01-15-2012, 02:20 AM
I have one of these, but it is not a unipolar stepper. Mine is a 4 wire bipolar 11Ohms. This is the one you don't need?
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Arduino and Motor Shield controlling a stepper motor. yowillyjj Project Logs 0 04-22-2012 01:40 AM
Which motor is better stepper or dc motor mrel Electronic Projects 1 10-24-2010 04:22 PM
Stepper Motor Driver VS stepper motor controller robotdigg Microcontrollers and Programming 0 05-21-2010 09:40 AM
Stepper motor driver issues (Electronics Goldmine stepper motor G14197) Vignesh Ganesan Electronic Design 10 08-08-2006 09:15 PM
Floppy Drive Stepper Motor control prizark General Electronics 0 07-05-2003 08:55 PM
